  3. Weather station
Weather station
5 Posts 2 Posters 3.1k Views 2 Watching
  • A
    A
    Acachinero
    wrote on last edited by Acachinero
    This post is deleted!
    • A
      A
      Acachinero
      • A
        A
        Acachinero
        Is the Arduino correctly connected to the reed switch?
        AWIA 1 Reply Last reply
        • A Acachinero
          AWIA
          AWIA
          AWI
          @Acachinero A lot of questions.. you would be better of one of the Arduino forums. This forum is about the MySensors Network.
          but anyway: You can connect the reed switch direct to an arduino pin and ground. And write a sketch that enables the INPUT_PULLUP on the respective pin.
          After that you can have your sketch count the changes and spit it out on the serial monitor. I suggest you find an arduino tutorial.
          • A
            A
            Acachinero
            Hi Awi, thanks for your answer! As you can see on my previous photos I have already connected the reed switch to my arduino on pin 9 and gnd after that I have typed pinMode (REED, INPUT_PULLUP); on my skecth. Following one of the project i have found which says
            flipping the bucket a couple of times, I should see the counter in my serial monitor click-up, if not check the wiring. Therefore after following these instructions I can see no signs at all. I was wondering if my conexion to the reed switch is done correctly or it may be affected to my windows (Im working with windows 10) I see a clicking in my arduino board after uploading the sketch but I see nothing when flipping the bucket in order to track the movement of the tipping bucket.
