  3. MySensors Raspberry port suggestions
96 Posts 14 Posters 64.5k Views 17 Watching
    marceloaqno
    Code Contributor
    #81
    Update: Added support for status leds (RX/TX/ERR), you can enable it in examples_linux/mysGateway.cpp file.
    E 1 Reply Last reply
    • ikkeTI
      ikkeTI
      ikkeT
      Continuing the learning here, new questions... Thanks so far, I've now got the temp/hum/door messages sent and received from sensebender micro to raspi2. The next thing I would like to do is to send the messages as mqtt to the next box hosting some controller.
      How to get the mysGateway to send the stuff forward as mqtt? I tried to look into Makefile, MyConfig.h and such, but didn't quite figure out yet how to do that. Any pointers?
      So I'd like to have the following: sensebender -> radio -> raspi2 -> some box hosting the controller. Perhaps even outside of home, so routable traffic e.g. to OpenShift.com.
      Should I now somehow configure and build mysGateway to send stuff as MQTT, or pipe the traffic somehow to mqtt like mosqitto? How is this normally done if the controller server is not running on the gateway Raspi?
      Thanks for the patience, I'm just getting into all this interesting stuff :)
      mfalkviddM H 2 Replies Last reply
      • ikkeTI ikkeT
        @ikkeT I haven't tried but using nodered should be fairly simple and very flexible. This discussion might be useful: https://forum.mysensors.org/topic/2802/flow-to-turn-serialgateway-into-mqtt-serialgateway/
        • ikkeTI ikkeT
          H
          H
          hawk_2050
          @ikkeT you can build the Raspberry Pi mysGateway as either Serial, Ethernet or MQTT by using appropriate commandline parameters with the configure script. Just do ./configure --help and you'll get a list of all the options available. Once you've chosen your options and run configure then you 'make'. An example of a set of options that will generate an MQTT Gateway is:
          ./configure --my-debug=enable --my-gateway=mqtt --my-rf24-channel=100 --my-rf24-pa-level=RF24_PA_LOW --my-controller-ip-address=127,0,0,1 --my-port=1883
          --my-mqtt-client-id=MyGW2 --my-mqtt-publish-topic-prefix="MyGW2out" --my-mqtt-subscribe-topic-prefix="MyGW2in"
          In this case my MQTT Broker is Mosquitto and is on the same Raspberry Pi hence the use of 127,0,0,1 for the specified --my-controller-ip-address. Change that as appropriate to your intended setup.
          Hope that helps.
          ikkeTI 1 Reply Last reply
          • M marceloaqno
            @ericvdb That's right. I hope to add support for RFM69, Serial and software signing very soon.
            To use, clone the raspberryPi port for MySensors 2.0:
            git clone https://github.com/marceloaqno/MySensors.git
            cd MySensors
            To configure it, take a look at the options available within configure:
            ./configure --help
            For other options, you may have to edit the sample file example_linux/mysGateway.cpp, and uncoment what you need.
            Once done, run:
            make
            sudo make install
            To run the gateway you need to be root or use sudo:
            sudo msyGateway -h
            For wiring, follow this guide:
            https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x
            W
            W
            wergeld
            @marceloaqno I have been trying to build this out by first building the RF24 library using the following:
            git clone https://github.com/TMRh20/RF24.git
            cd RF24
            make
            sudo make install
            However, this fails on the make command:
            Makefile:17: Makefile.inc: No such file or directory
            [Running configure]
            [SECTION] Detecting arm compilation environment.
              [OK] arm-linux-gnueabihf-gcc detected.
              [OK] arm-linux-gnueabihf-g++ detected.
            [SECTION] Detecting target machine.
            [OK] machine detected: SoC=BCM2836, Type=RPi2, CPU=armv7l.
            [SECTION] Detecting DRIVER
              [OK] DRIVER detected:RPi.
            [SECTION] Detecting OS.
              [INFO] OS detected:LINUX.
            [SECTION] Preparing configuration.
            [SECTION] Saving configuration.
            [OK] Finished.
            arm-linux-gnueabihf-g++ -fPIC -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -Ofast -Wall -pthread  -c RF24.cpp
            cc1plus: error: bad value (cortex-a7) for -mtune switch
            Makefile:40: recipe for target 'RF24.o' failed
            make: *** [RF24.o] Error 1
            I am not sure what to do here. Looks like the gcc does not support the cortex-a7? I am trying to run this on my RPi 2 B.
            M 1 Reply Last reply
            • W wergeld
              cd RF24
              make
              sudo make install
              [Running configure]
              [OK] Finished.
              marceloaqno
              Code Contributor
              #86
              @wergeld I'm not sure why you are having this error, perhaps your version of gcc it's old? Did you try to update it?
              You can skip the installation of TMRh20/RF24, it is no longer necessary to build RPi port.
              W 1 Reply Last reply
              • M marceloaqno
                W
                W
                wergeld
                I have tried to update gcc but apt-get says it is already at latest version. I am upgrading to Jessie now as it has gcc 4.9 (I was running Wheezy with gcc 4.6).
                Is there an updated build instruction set? I am planning on using this as a serial gateway with Domoticz on same RPi.
                • H hawk_2050
                  Hope that helps.
                  ikkeTI
                  ikkeTI
                  ikkeT
                  @hawk_2050 thanks for the reminder! I recalled it was somehow configurable, but I forgot it was through . /configure options. I'll try after getting pir working also.
                  • W wergeld
                    marceloaqno
                    Code Contributor
                    @wergeld I updated the building instructions:
                    https://forum.mysensors.org/topic/2759/mysensors-raspberry-port-suggestions/26
                    • M marceloaqno
                      W
                      W
                      wergeld
                      Success! Upgraded to Jessie and build worked fine. Now to reconnect my radio to the RPi pins directly to test.
                      • W wergeld
                        W
                        W
                        wergeld
                        Okay, using an RPi2B upgraded to Jessie from Wheezy I have successfully built and set the mysGateway as a daemon. My configuration was:
                        ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway --my-rf24-pa-level=RF24_PA_LOW
                        This was immediately available in Domoticz under Hardware. I re-added the 2 nodes and away I went!
                        Full command list:
                        cd MySensors
                        make
                        sudo make install
                        sudo mysGateway -b
                        In Domoticz it lists this gateway as running:
                        MySensors Gateway USB
                        Version: 2.0.1-beta
                        So far very happy with this setup. No wires and no extra arduino needed for serial gateway. Just the NRF+RPi interfacing via:
                        https://www.openhardware.io/view/100/Raspberry-PI-NRF24l01-hat
                        • E
                          E
                          ericvdb
                          @marceloaqno
                          what am I doing wrong here?
                          root@raspberrypi:/downloads/MySensors# ./configure --my-gateway=mqtt --my-mqtt-client-id=msgw --my-mqtt-publish-topic-prefix=mspub --my-mqtt-subscribe-topic-prefix=mssub --my-controller-ip-address=10.0.10.4 --my-port=1883
                          [OK] machine detected: SoC=BCM2835, Type=RPi, CPU=armv6l, REV=000d.
                          [OK] init system detected: systemd
                          [SECTION] Cleaning previous builds.
                          [OK] Finished.
                          root@raspberrypi:/downloads/MySensors# make
                          cc  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/log.o drivers/Linux/log.c
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/noniso.o drivers/Linux/noniso.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Print.o drivers/Linux/Print.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetClient.o drivers/Linux/EthernetClient.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/SerialPort.o drivers/Linux/SerialPort.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/Stream.o drivers/Linux/Stream.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/IPAddress.o drivers/Linux/IPAddress.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/compatibility.o drivers/Linux/compatibility.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o drivers/Linux/EthernetServer.o drivers/Linux/EthernetServer.cpp
                          g++ -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DLINUX_ARCH_RASPBERRYPI -Ofast -g -Wall -Wextra -DMY_PORT=1883 -DMY_CONTROLLER_IP_ADDRESS=10,0,10,4 -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mssub\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mspub\" -DMY_MQTT_CLIENT_ID=\"msgw\"  -I. -I./core -I./drivers/Linux -I./drivers/RPi -MMD -c -o examples_linux/mysGateway.o examples_linux/mysGateway.cpp
                          In file included from ./MySensors.h:287:0,
                                           from examples_linux/mysGateway.cpp:60:
                          ./core/MyTransport.cpp: In function âvoid transportProcessMessage()â:
                          ./core/MyTransport.cpp:535:61: error: no matching function for call to âmin(uint8_t, unsigned int)â
                            const uint8_t msgLength = min(mGetLength(_msg), MAX_PAYLOAD);
                          ./core/MyTransport.cpp:535:61: note: candidates are:
                          In file included from /usr/include/c++/4.9/bits/char_traits.h:39:0,
                                           from /usr/include/c++/4.9/ios:40,
                                           from /usr/include/c++/4.9/ostream:38,
                                           from /usr/include/c++/4.9/iostream:39,
                                           from examples_linux/mysGateway.cpp:20:
                          /usr/include/c++/4.9/bits/stl_algobase.h:240:5: note: template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
                               min(const _Tp& __a, const _Tp& __b, _Compare __comp)
                          /usr/include/c++/4.9/bits/stl_algobase.h:240:5: note:   template argument deduction/substitution failed:
                          ./core/MyTransport.cpp:535:61: note:   deduced conflicting types for parameter âconst _Tpâ (âunsigned charâ and âunsigned intâ)
                          /usr/include/c++/4.9/bits/stl_algobase.h:194:5: note: template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)
                               min(const _Tp& __a, const _Tp& __b)
                          /usr/include/c++/4.9/bits/stl_algobase.h:194:5: note:   template argument deduction/substitution failed:
                          ./core/MyTransport.cpp: In function âbool transportSendWrite(uint8_t, MyMessage&)â:
                          ./core/MyTransport.cpp:826:82: error: no matching function for call to âmin(unsigned int, const uint8_t&)â
                            bool result = transportSend(to, &message, min(MAX_MESSAGE_LENGTH, totalMsgLength));
                          ./core/MyTransport.cpp:826:82: note: candidates are:
                          ./core/MyTransport.cpp:826:82: note:   deduced conflicting types for parameter âconst _Tpâ (âunsigned intâ and âuint8_t {aka unsigned char}â)
                          Makefile:46: recipe for target 'examples_linux/mysGateway.o' failed
                          make: *** [examples_linux/mysGateway.o] Error 1
                          • E ericvdb
                            @marceloaqno
                            [OK] Finished.
                            marceloaqno
                            Code Contributor
                            @ericvdb update your files from mysensors repository, this was fixed in #594
                            • M marceloaqno
                              E
                              E
                              ericvdb
                              // Flash leds on rx/tx/err
                              //#define MY_DEFAULT_ERR_LED_PIN 12 // Error LED pin
                              //#define MY_DEFAULT_RX_LED_PIN 16 // Receive LED pin
                              //#define MY_DEFAULT_TX_LED_PIN 18 // Transmit LED pin
                              What do I put there? RPi pin numbers or GPIO numbers?
                              • E ericvdb
                                marceloaqno
                                Code Contributor
                                @ericvdb In any type of pin configuration for the RPi, always use the physical pin number.
                                  marceloaqno
                                  Code Contributor
                                  The RPi port was merged into mysensors official repository :tada: (thank you to everyone who helped with this process :clap: ). For future discussion, please use this this topic.
