  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    So gateway with nrf and W5100 is working as it should as an ethernet gateway? Then the W5100 is working with the gateway.
    What is the hardware configuration that you can't get to work? Rfm69 and W5100? Together with the samd GW?
    (just trying to figure out what is going on :))
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      alexsh1A
      alexsh1A
      alexsh1
      @tbowmo No, sensebender GW is working with nrf24l01+ as a serial GW, but not with W5100 as ethernet GW.
      Interesting observation - I cannot ping the IP any more if I load the ethernet sketch. For your understanding the sensebender GW was never working with W5100 with either nrf or rfm69. Something going wrong around W5100.
      I'll hook up W5100 shield to Arduino nano to test it - I have a suspicion about it. However, even without W5100 connected, sensebender GW is showing IP as 0.0.0.0 (I set IP 10.1.1.150). Why?
      • tbowmoT
        tbowmoT
        tbowmo
        If the ethernet library can't initialize the W5100, it will just write IP address as 0.0.0.0.
        Can you please turn on verbose compile logging in arduino? (file -> Settings, set a checkmark at show verbose output during compilation, and choose "all" in Compiler warnings)
        I just want to make sure that it is using the correct ethernet library.
        • tbowmoT tbowmo
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo I have verbose on already.
          I think you hit the nail on the head:
          Linking everything together...
          "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-gcc"  "-LC:\Users\Alex\AppData\Local\Temp\arduino_build_753079" -Os -Wl,--gc-sections -save-temps  "-TC:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\variants\mysensors_gw/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\sketch\GatewayW5100.ino.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Dhcp.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Dns.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\Ethernet.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetClient.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetServer.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\EthernetUdp.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\utility\socket.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Ethernet\utility\w5100.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\Wire\Wire.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\libraries\SPI\SPI.cpp.o" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/core\core.a" -Wl,--end-group
          "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.bin"
          "C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom  "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.elf" "C:\Users\Alex\AppData\Local\Temp\arduino_build_753079/GatewayW5100.ino.hex"
          Multiple libraries were found for "Ethernet.h"
           Used: C:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\libraries\Ethernet
           Not used: C:\Program Files (x86)\Arduino\libraries\Ethernet
          Using library Ethernet at version 1.1.2 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\MySensors\hardware\samd\1.0.5\libraries\Ethernet
          Using library MySensors at version 2.2.0-beta in folder: C:\Users\Alex\Documents\Arduino\libraries\MySensors
          Using library Wire at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\Wire
          Using library SPI at version 1.0 in folder: C:\Users\Alex\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.12\libraries\SPI
          Sketch uses 45512 bytes (17%) of program storage space. Maximum is 262144 bytes.```
          • tbowmoT
            tbowmoT
            tbowmo
            It is using "our" ethernet driver, which it should be.. The default arduino ethernet driver is hardwired to SERCOM0 for SPI, while we have it on SERCOM1.
            I'll try to bring up one of my own gateways with W5100 later today.
            • tbowmoT
              tbowmoT
              tbowmo
              @alexsh1
              Below is the startup log from my Gateway with W5100 and RFM69 attached:
              0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGS--,VER=2.2.0-beta
              0;255;3;0;9;TSF:LRT:OK
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSF:WUR:MS=0
              0;255;3;0;9;TSM:INIT:TSP OK
              0;255;3;0;9;TSM:INIT:GW MODE
              IP: 192.168.1.66
              0;255;3;0;9;MCO:BGN:STP
              As seen, the W5100 is initialized with ip address,
              Telnet to the Gateway is also working:
              thomas at thomas-ThinkPad-L450 in ~
              >telnet 192.168.1.66 5003
              Trying 192.168.1.66...
              Connected to 192.168.1.66.
              Escape character is '^]'.
              200;255;4;0;0;FFFFFFFFFFFFFFFF0300
              200;255;0;0;17;2.2.0-beta
              200;255;3;0;6;0
              200;255;3;0;11;Sensebender Micro
              200;255;3;0;12;1.4
              200;1;0;0;6;
              200;2;0;0;7;
              200;1;1;0;0;23.3
              200;2;1;0;1;46
              200;255;3;0;0;81
              The above is with the stock example sketch from mysensors (right now latest development branch though). The only things I changed, was to enable RFM69, instead of NRF24, and set a different IP address, to match my network settings.
              Everything else is running as is, delivered from the mysensors examples..
              • tbowmoT tbowmo
                @alexsh1
                IP: 192.168.1.66
                200;255;3;0;6;0
                200;255;3;0;12;1.4
                200;1;0;0;6;
                200;2;0;0;7;
                200;1;1;0;0;23.3
                200;2;1;0;1;46
                200;255;3;0;0;81
                alexsh1A
                alexsh1A
                alexsh1
                @tbowmo if you take off the W5100 shield, does it still come up with IP please:
                IP: 192.168.1.66
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @alexsh1
                  This log is without ethernet shield attached
                  IP: 0.0.0.0
                  • tbowmoT tbowmo
                    @alexsh1
                    IP: 0.0.0.0
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @tbowmo Thanks - I am assuming that I have a faulty W5100 shield in this case. Unfortunately, I have received a wrong replacement shield enc28j60 instead of W5100. Do you know if Sensebender GW would work with
                    #define MY_GATEWAY_ENC28J60
                    The one I have does not have AMS1117-3.3 on board and must be fed with 3.3V instead of 5v
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      #270
                      @tbowmo The problem has been identified. I have used a hot fan to re-sit W5100 on the network shield.
                      AND
                      0;255;3;0;9;2430 MCO:BGN:INIT GW,CP=RNNGS---,VER=2.2.0-beta
                      0;255;3;0;9;2477 TSF:LRT:OK
                      0;255;3;0;9;2487 TSM:INIT
                      0;255;3;0;9;2497 TSF:WUR:MS=0
                      0;255;3;0;9;2512 TSM:INIT:TSP OK
                      0;255;3;0;9;2522 TSM:INIT:GW MODE
                      0;255;3;0;9;2532 TSM:READY:ID=0,PAR=0,DIS=0
                      0;255;3;0;9;2542 MCO:REG:NOT NEEDED
                      IP: 10.1.1.200
                      0;255;3;0;9;3852 MCO:BGN:STP
                      0;255;3;0;9;3862 MCO:BGN:INIT OK,TSP=1
                      Still cannot ping it, which means there is still a problem with the shield.
                      It is of a poor quality and does have multiple bridges around W5100 like this:
                      I found a similar problem here:
                      https://electronics.stackexchange.com/questions/156147/are-solder-bridges-on-chips-always-bad
                      At least I know where the problem is.
                      Thanks @tbowmo
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #271
                        @alexsh1
                        Great, that we found the problem, and thanks for reporting back here on the forum :)
                        I haven't tried with other ethernet controllers, than the W5100, And the socket for W5100 is supplied with 5V directly.
                        Also, I do not know if they are pin compatible?
                        alexsh1A 2 Replies Last reply
                        • tbowmoT tbowmo
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          #272
                          @tbowmo I think they are pin compatible but unfortunately take different voltage. On arduino board, somebody told me that enc28j60 can tolerate 5V. It seems to be the case, as mine survived w5100 socket
                          EDIT: From the enc28j60 datasheet
                          • Operating Voltage of 3.1V to 3.6V (3.3V typical)
                          • 5V Tolerant Input
                          • tbowmoT tbowmo
                            @alexsh1
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @tbowmo I can confirm now that everything is working fine after I tested the Sensebender GW with the third (yes, third!!!) shield. Thanks Thomas for your help!
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @tbowmo The pinout is identical.
                              W5100
                              ENC28J60
                              I can modify ENC28J60 shield (reduce voltage to 3.3V) and test it with the sensebender GW, but it does require hardware mod
                              • nitroburnN
                                nitroburnN
                                nitroburn
                                Question,
                                "To use the serial port in the mysx connector, you should use Serial1 in your sketches, as the default Serial is connected to the USB serial device"
                                What pins is the serial port in the mysx connector, I see no mention of it other than that line. I want to mirror the serial data sent to my controller via the USB port to the the serial port in the mysx connector that will then be attached to a bluetooth SPP device. Just want another way to view the radio traffic.
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  #276
                                  @nitroburn
                                  Have you seen the documentation for MysX connector: https://www.mysensors.org/hardware/mysx?
                                  (hint, look for Data To Module, and Data From Module :))
                                  AnticimexA 1 Reply Last reply
                                  • tbowmoT tbowmo
                                    @nitroburn
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @tbowmo @nitroburn
                                    Actually, it is even more clearly specified than that as DTM and DFM means Data To MCU and Data From MCU. "module" is not explicitly defining what "side" you mean. The MCU is clearly defined so DTM and DFM leavs no doubt on the direction and function of the pin.
                                    • nitroburnN
                                      nitroburnN
                                      nitroburn
                                      @tbowmo @Anticimex Thanks, I was stupidly searching for the wrong combination of terms and hadn't seen DTM DFM used so I was naively looking for the word serial or UART rather than USART when I did a search. Thought I was missing something and didn't read the mysx page close enough after briefly searching it.
                                      Thanks for clearing that up. #define MYSX_D1_DFM (00ul) & #define MYSX_D2_DTM (01ul) didn't stand out to me as serial connections.
                                      • scalzS scalz
                                        @alexsh1
                                        woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                                        Enjoy :)
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @scalz Can somebody edit the descriptive text for this Gateway. Under 'Secure IiT Radio Network' is quoted 'Hope RF RFM69HCW' whereas under 'Setup and use' is correctly quoted RFM69(H)W.
                                        Guess who had ordered the incorrect 'CW' module for this Gateway....
                                        tbowmoT 1 Reply Last reply
                                        • zboblamontZ zboblamont
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @zboblamont
                                          Sorry about that, it sneaked through the reviews.. I have updated the page, so others don't fall into the same pitfall..
