  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @alexsh1
    Below is the startup log from my Gateway with W5100 and RFM69 attached:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGS--,VER=2.2.0-beta
    0;255;3;0;9;TSF:LRT:OK
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    IP: 192.168.1.66
    0;255;3;0;9;MCO:BGN:STP
    As seen, the W5100 is initialized with ip address,
    Telnet to the Gateway is also working:
    thomas at thomas-ThinkPad-L450 in ~
    >telnet 192.168.1.66 5003
    Trying 192.168.1.66...
    Connected to 192.168.1.66.
    Escape character is '^]'.
    200;255;4;0;0;FFFFFFFFFFFFFFFF0300
    200;255;0;0;17;2.2.0-beta
    200;255;3;0;6;0
    200;255;3;0;11;Sensebender Micro
    200;255;3;0;12;1.4
    200;1;0;0;6;
    200;2;0;0;7;
    200;1;1;0;0;23.3
    200;2;1;0;1;46
    200;255;3;0;0;81
    The above is with the stock example sketch from mysensors (right now latest development branch though). The only things I changed, was to enable RFM69, instead of NRF24, and set a different IP address, to match my network settings.
    Everything else is running as is, delivered from the mysensors examples..
    alexsh1A 1 Reply Last reply
    • tbowmoT tbowmo
      @alexsh1
      IP: 192.168.1.66
      200;255;3;0;6;0
      200;255;3;0;12;1.4
      200;1;0;0;6;
      200;2;0;0;7;
      200;1;1;0;0;23.3
      200;2;1;0;1;46
      200;255;3;0;0;81
      alexsh1A
      alexsh1A
      alexsh1
      @tbowmo if you take off the W5100 shield, does it still come up with IP please:
      IP: 192.168.1.66
      • tbowmoT
        tbowmoT
        tbowmo
        @alexsh1
        This log is without ethernet shield attached
        IP: 0.0.0.0
        • tbowmoT tbowmo
          @alexsh1
          IP: 0.0.0.0
          alexsh1A
          alexsh1A
          alexsh1
          @tbowmo Thanks - I am assuming that I have a faulty W5100 shield in this case. Unfortunately, I have received a wrong replacement shield enc28j60 instead of W5100. Do you know if Sensebender GW would work with
          #define MY_GATEWAY_ENC28J60
          The one I have does not have AMS1117-3.3 on board and must be fed with 3.3V instead of 5v
          • alexsh1A
            alexsh1A
            alexsh1
            #270
            @tbowmo The problem has been identified. I have used a hot fan to re-sit W5100 on the network shield.
            AND
            0;255;3;0;9;2430 MCO:BGN:INIT GW,CP=RNNGS---,VER=2.2.0-beta
            0;255;3;0;9;2477 TSF:LRT:OK
            0;255;3;0;9;2487 TSM:INIT
            0;255;3;0;9;2497 TSF:WUR:MS=0
            0;255;3;0;9;2512 TSM:INIT:TSP OK
            0;255;3;0;9;2522 TSM:INIT:GW MODE
            0;255;3;0;9;2532 TSM:READY:ID=0,PAR=0,DIS=0
            0;255;3;0;9;2542 MCO:REG:NOT NEEDED
            IP: 10.1.1.200
            0;255;3;0;9;3852 MCO:BGN:STP
            0;255;3;0;9;3862 MCO:BGN:INIT OK,TSP=1
            Still cannot ping it, which means there is still a problem with the shield.
            It is of a poor quality and does have multiple bridges around W5100 like this:
            I found a similar problem here:
            https://electronics.stackexchange.com/questions/156147/are-solder-bridges-on-chips-always-bad
            At least I know where the problem is.
            Thanks @tbowmo
            • tbowmoT
              tbowmoT
              tbowmo
              #271
              @alexsh1
              Great, that we found the problem, and thanks for reporting back here on the forum :)
              I haven't tried with other ethernet controllers, than the W5100, And the socket for W5100 is supplied with 5V directly.
              Also, I do not know if they are pin compatible?
              alexsh1A 2 Replies Last reply
              • tbowmoT tbowmo
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                #272
                @tbowmo I think they are pin compatible but unfortunately take different voltage. On arduino board, somebody told me that enc28j60 can tolerate 5V. It seems to be the case, as mine survived w5100 socket
                EDIT: From the enc28j60 datasheet
                • Operating Voltage of 3.1V to 3.6V (3.3V typical)
                • 5V Tolerant Input
                • tbowmoT tbowmo
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo I can confirm now that everything is working fine after I tested the Sensebender GW with the third (yes, third!!!) shield. Thanks Thomas for your help!
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    @tbowmo The pinout is identical.
                    W5100
                    ENC28J60
                    I can modify ENC28J60 shield (reduce voltage to 3.3V) and test it with the sensebender GW, but it does require hardware mod
                    • nitroburnN
                      nitroburnN
                      nitroburn
                      Question,
                      "To use the serial port in the mysx connector, you should use Serial1 in your sketches, as the default Serial is connected to the USB serial device"
                      What pins is the serial port in the mysx connector, I see no mention of it other than that line. I want to mirror the serial data sent to my controller via the USB port to the the serial port in the mysx connector that will then be attached to a bluetooth SPP device. Just want another way to view the radio traffic.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #276
                        @nitroburn
                        Have you seen the documentation for MysX connector: https://www.mysensors.org/hardware/mysx?
                        (hint, look for Data To Module, and Data From Module :))
                        AnticimexA 1 Reply Last reply
                        • tbowmoT tbowmo
                          @nitroburn
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @tbowmo @nitroburn
                          Actually, it is even more clearly specified than that as DTM and DFM means Data To MCU and Data From MCU. "module" is not explicitly defining what "side" you mean. The MCU is clearly defined so DTM and DFM leavs no doubt on the direction and function of the pin.
                          • nitroburnN
                            nitroburnN
                            nitroburn
                            @tbowmo @Anticimex Thanks, I was stupidly searching for the wrong combination of terms and hadn't seen DTM DFM used so I was naively looking for the word serial or UART rather than USART when I did a search. Thought I was missing something and didn't read the mysx page close enough after briefly searching it.
                            Thanks for clearing that up. #define MYSX_D1_DFM (00ul) & #define MYSX_D2_DTM (01ul) didn't stand out to me as serial connections.
                            • scalzS scalz
                              @alexsh1
                              woops, yes i made it but forgot the upload. it's now uploaded here https://www.mysensors.org/hardware/sensebender-gateway#design-files
                              Enjoy :)
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @scalz Can somebody edit the descriptive text for this Gateway. Under 'Secure IiT Radio Network' is quoted 'Hope RF RFM69HCW' whereas under 'Setup and use' is correctly quoted RFM69(H)W.
                              Guess who had ordered the incorrect 'CW' module for this Gateway....
                              tbowmoT 1 Reply Last reply
                              • zboblamontZ zboblamont
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @zboblamont
                                Sorry about that, it sneaked through the reviews.. I have updated the page, so others don't fall into the same pitfall..
                                • magpernM
                                  magpernM
                                  magpern
                                  Is it really correct that orange, green and red led should light constantly when powered on. On some activity from the sensors the leds blink, but goes to full constant light directly.
                                  An other thing, inclusion button. In sketch this is commented out, should it?
                                  For me it is like GW is in constant inclusion mode. Gateway seams to work, it shows up in controller, and as soon as a sensor is powered up, it automatically also appears in controller... feels very unsecure. Just give power to a random sensor and it is in my controller.
                                    @Magnus-Pernemark
                                    You can reverse the led behaviour by defining:
                                    Presentation messages is always forwarded to controller. Inclusion mode must be implemented/supported by the controller for it to work.
                                    magpernM 1 Reply Last reply
                                      @Magnus-Pernemark
                                      magpernM
                                      magpernM
                                      magpern
                                      @hek Thanks, I'll try that. The controller is Domoticz. Does Domoticz have a flaw when it comes to inclusion? (I guess it must have, since any random sensor gets included automatically).
                                      AnticimexA alexsh1A 2 Replies Last reply
                                      • magpernM magpern
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @Magnus-Pernemark I am not sure domoticz support inclusion at all.
                                        • magpernM magpern
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Magnus-Pernemark inclusion mode is not for Domoticz but for Vera. For Domoticz if you want to secure your sensors you need to use signing between the sensors and the GW and reject any sensor without signing
