  3. livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz
135 Posts 31 Posters 135.4k Views 44 Watching
  • Nca78N Nca78
    @wallyllama said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
    livolo glass plate -eu -uk
    Maybe but I'm missing your point ?
    I still need to buy the switch to have the box + main power/relay board.
    @achurak1 said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
    They use PIC16F690 chip for the dimmable switch versions: http://www.microchip.com/wwwproducts/en/PIC16F690
    They use the same PIC16F690 in all the switches but what is interesting is to know to which pins of the connector it is connected, and what is connected on the main/ac board to control the dimmers.
    If someone has the 2 way switches I'm interested to know what ics are connected to the A and B connectors and to which pins those ics are connected to on the 2x7 pins connectors.
    Markhill
    @Nca78 I have 2 way switch for 1 gang, 2 gang and 3 gang. Will take a picture for you guys soon
    • Nca78N Nca78
      @Nca78, does that mean I can send high from arduino to this electrode thus imitating the touch? If so, would it be easier to do that or send the high/low directly to the HC238 (to A0 - A2)? It seems that in the first case I can also easily control the dimming function by keeping high for a few seconds. Is there a way to control dimming directly through HC238?
      I think you can simulate the press by setting the pin to a high level, it will cheat the capacitance measurement and should generate a "click". But I take no responsibility for that :P
      I don't think the dimmer is using an HC238, which is a decoder that takes 3 pins as input and sets one of it's outputs high, it's convenient for the relays they use but not suitable for a dimmer. They are probably using PWM for that. I have no dimmer switch here, I ordered one but I still need time to receive it...
      So if you want to control a dimmer livolo switch at the moment, try to simulate touches on the buttons and the mcu on their sensor board will do the job for you.
      And an unrelated question, will you be able to sell these replacement PCBs you're working on right now and when? I'm not sure I will have enough patience to solder arduinos/radios to dozens of the switches, so I'd rather buy your plug-n-play solution if the price is reasonable.
      I will be able to sell them if they work fine on the long term, but that will need at least one month in the wall to be sure, then another month to order and get the fixed PCB (got some improvements to make already...).
      I want to get the dimmer swith also to have a look and if possible make a PCB compatible with both normal switch and dimmer.
      For the price I have no idea, either I get them done in China but I don't think there will be enough volume and it takes a lot of time to prepare (but that's an interesting process to learn :)), or I make them myself which takes a lot of time and logistics to assemble, test, ship. BOM is already around 10 US$ so I don't think it could go below 20US$ for final board. That would make the final swith around 10$ more than the radio version of livolo switch, as with my pcb you can just buy the cheapest switches, without radios.
      A
      A
      achurak1
      @Nca78 I have a probably very stupid question. Why is it every time I'm trying to solder my arduino in parallel to the pins A0-A2 everything basically stops working - the lights would go on, but not off, dimmer would stop working either or the lights would just start flickering like crazy. What am I missing here? Is that somehow related to pull-up/down resistors? I tried both modes on arduino, INPUT to just listen what's going on when I'm touching the button and OUTPUT to actually control stuff, but both gave me the same results - nothing :(
      Nca78N 1 Reply Last reply
      • Nca78N
        Nca78N
        Hello, just published my first version for the US/AU switch.
        https://forum.mysensors.org/topic/6489/livolo-3-buttons-us-au-switch-adapter/2
        Still needs some improvements, so no gerbers at the moment.
        • A achurak1
          Nca78N
          Nca78N
          Sorry I forgot to reply to your question...
          I ordered a dimmer and checked it, it has another PIC on the "main" board so I think it's not that easy to control, I suppose the PIC on the "main" board manages PWM, and it receives instructions from the PIC on the "sensor" board, we need to know how they communicate.
          • Nca78N Nca78
            @Markhill it cannot work, this board needs external power because the ESP8266 he is using is too power hungry, the switch cannot provide enough power. And this board is sized for EU switch it will not work with US or US/AU switch.
            I'm working on 3 buttons and 4 buttons version with atmega and nrf24, power from the swith is enough so it's just a plug&play replacement. I'm testing the 3 buttons switch at the moment (same layout than 1 button in which only the center button is connected). It will be cheaper than 15$ if you solder it yourself, if you don't want to do smd soldering we can probably find a solution for pre-assembled boards.
            A
            A
            alexus
            @Nca78
            hello. Is there a connection example with ESP?
            • A alexus
              @Nca78
              Nca78N
              Nca78N
              @alexus said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
              @Nca78
              Somewhere on youtube it seems, but using external power supply. It doesn't sound like a good idea to try to draw over 100mA from a power supply that was designed to provide less than 10, especially when a MySensors board can provide exactly the same functionality as a plug-in replacement of the livolo sensor board.
              • wallyllamaW
                wallyllamaW
                wallyllama
                My goal would be to connect an arduino to the data pin on the power board and use the library to control livolo direct without a radio. The problem I have is that when i connect ground to ground on an ftdi I get magic smoke all over. Inuse my. Volt meter and sure enough the gnd pin is connected directly to the live input. Im guessing gnd and +3v "float" around the AC in some fashion.
                Has anyone sucessfully bypassed the radio? Im thinking t may work if i power the arduino off the livolo power supply, or from a battery, but then if i connect that to an rs485 or other device with a real ground, kapow! At least that is what i am thinking will happen.
                On a side note I have a regular, 2way, and remote switch, all the same revision and all US style, and from what I can tell the difference for 2way is a diode (d2) and a resettable fuse (r10). It lookes like there is basically a primative modem that sends/recieves the same data as the radio. (The radio is receive only, but 2 way has to be, well 2 ways). The "modem" is connected to "B" and "A" is connected to live and "gnd", which is why I think the dc voltage sort of floats on the ac.
                mtiutiuM M 2 Replies Last reply
                • wallyllamaW wallyllama
                  mtiutiuM
                  mtiutiuM
                  mtiutiu
                  @wallyllama
                  In order to have isolation why not use an optocoupler from arduino to send logic high or low to the livolo relays board? This way they won't share the same gnd and no more issues of this kind in theory. But this means adding the optocoupler as an extra component..but I don't think this is a big issue and it should be cheap also.
                  wallyllamaW 1 Reply Last reply
                  • mtiutiuM mtiutiu
                    @wallyllama
                    wallyllamaW
                    wallyllamaW
                    wallyllama
                    @mtiutiu i usually need help with the obvious. Thank you.
                    mtiutiuM 1 Reply Last reply
                      mtiutiuM
                      mtiutiuM
                      mtiutiu
                      @wallyllama
                      What do you mean? You don't know how the wiring goes? I can provide a simple wiring diagram not a problem if that's needed.
                      • wallyllamaW
                        wallyllamaW
                        wallyllama
                        I meant that using an optocoupler was an obvious solution, and I should have thought of it.
                        • Andrei Călin TătarA
                          Andrei Călin TătarA
                          Andrei Călin Tătar
                          I managed to do some reverse engineering on the livolo dimmer switch. It seems that the touch MCU talks to the dimmer MCU via USART (idle: low, 19200 bps, 1 start, 1 stop, 8 data). Each 20 msec the dimmer MCU sends a byte that shows the level of the dimmer and the touch MCU replies with a byte that has bit 0 set to one if touch is present, rest of the bits are all 0 (except for each 10th reply, when all the other bits are 1).
                          Also the 433MHz radio signal is decoded by the touch MCU not by the dimmer MCU.
                          • Andrei Călin TătarA Andrei Călin Tătar
                            wallyllamaW
                            wallyllamaW
                            wallyllama
                            @Andrei-Călin-Tătar said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
                            The touch mcu does this for non dimming temote modules also. I think it uses mostly the same system for the 2way switches also.
                              Andrei Călin TătarA
                              Andrei Călin Tătar
                              I decided in the end to completely remove both MCUs and replace them with one mega328p, at42qt1010 and one nrf24l01. The problem is that it must be really power efficient. Once the light goes close to full power, the current drops significantly. I also noticed on the PCB space for a battery and a transistor that controls when it's connected to the power supply. Do the switches that come with RF modules have the battery location (B1 I think) populated?
                                wallyllamaW
                                wallyllamaW
                                wallyllama
                                @Andrei-Călin-Tătar b1 is the buzzer. When you hold a touch pad down for more than 5 seconds, the switch goes into learning mode and the buzzer makes a sound.
                                Andrei Călin TătarA 1 Reply Last reply
                                  Andrei Călin TătarA
                                  Andrei Călin TătarA
                                  Andrei Călin Tătar
                                  @wallyllama ah, that makes sense. thanks for the info!
                                    Andrei Călin TătarA
                                    Andrei Călin Tătar
                                    OK, here is what I managed to get working so far. I didn't use mysensors in the end but the sketch can be adapted. I must admit it's not the cleanest code.
                                    So, I removed both microcontrollers from the base and the touch panel. I added a AT42QT1010 for touch detection (10k resistor, 47nF cap) and also replaced the led resistors from the touch panel with 2.2k ones (the light was too dimm, now it's a bit too bright :D ).
                                    Rest of the mods should be easy to see from the images. I didn't roll my own PCBs since I needed to adapt only 6 switches.
                                    Features in the sketch: manual dimmer mode (works the same as the normal switch, just with control and brightness report); manual on/off mode (switches on/off on the start of a touch; the brightness can be set - default 100); manual disabled; when changing the brightness it goes through a ramp, it doesn't go directly to max or min. The modes, brightness, etc. can be changed via RF.
                                    Base mod: https://photos.app.goo.gl/ZGojnlm2ocBEaucp2
                                    Touch panel mod: https://photos.app.goo.gl/UpG2UuMtK2qa6q4h1
                                    And the sketch code: https://github.com/andrei-tatar/SensorsNetwork/blob/master/LightDimmer/LightDimmer.ino
                                      A
                                      A
                                      achurak1
                                      @Andrei-Călin-Tătar - How did you solve the problem with the power? I tried powering arduino from the built-in 3V connection, but it only worked to turn the lights on. Once on, I almost couldn't communicate with the arduino anymore (like 1 attempt from 20 would be successful).
                                      • A achurak1
                                        Andrei Călin TătarA
                                        Andrei Călin TătarA
                                        Andrei Călin Tătar
                                        @achurak1 - I limited the max brightness. At full brightness, the triac is off for 2.9ms (out of 10msec for 50Hz). That gives enough time to recharge the circuit for the arduino but it limits the power delivered to the light bulbs to about 80-90%. If I would go more than that I would get unstable results. The circuit isn't able to keep it's 3V at full brightness without an arduino connected.
                                          A
                                          A
                                          achurak1
                                          @Andrei-Călin-Tătar - Understood, thanks! Why did you need a new touch sensor, could you reuse the existing one?
