  3. Vera
  4. include a sensor a second time?
6 Posts 3 Posters 2.6k Views 2 Watching
  • H
    H
    hyla
    while experimenting with Vera, UI7 and MySensors I have included a temperature sensor with a Dallas DS1820 sensor.
    Since it didn't give me any temperature values I wanted to deinstall it and then include it again.
    So I removed the device (actually three devices: one called "Arduino Node", one Voltage which appears as "Multimeter" and the actual temp sensor). When I tried to reinclude it the device was not found. When changing the sensor's internal
    NODE_ID to a fresh unused number that worked again. So first question: how can I remove a device from Vera UI7 completely, that is including the "used up" NODE_ID?
    And how can I make the sensor work ;) as re-including didn't help with my original problem?
    Christoph
      Reset Vera. It sometimes caches stuff..
      • Dave DanD
        Dave DanD
        Dave Dan
        Reset Vera means reconfigure everything again right?
          No, just cut the power and let it reboot.
          • Dave DanD
            Dave DanD
            Dave Dan
            Isn't it rebooting-like every day like 3 am or something like that ?? (I think I saw something like that somewere or just need to sleep little more :$ )
              Yes, true, it does. Interesting way of solving unstableness of a product BTW ;)
