include a sensor a second time?
while experimenting with Vera, UI7 and MySensors I have included a temperature sensor with a Dallas DS1820 sensor.
Since it didn't give me any temperature values I wanted to deinstall it and then include it again.
So I removed the device (actually three devices: one called "Arduino Node", one Voltage which appears as "Multimeter" and the actual temp sensor). When I tried to reinclude it the device was not found. When changing the sensor's internal
NODE_ID to a fresh unused number that worked again. So first question: how can I remove a device from Vera UI7 completely, that is including the "used up" NODE_ID?And how can I make the sensor work ;) as re-including didn't help with my original problem?
Christoph
