  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.7k Views 2 Watching
  • korttomaK
    korttomaK
    korttoma
    So the correct instructions should have been:
    pin 14 (DS) to Arduino pin 6
    pin 12 (RCLK) to Arduino pin 7
    pin 11 (CLK) to Arduino pin 8
    pin 16 (Vcc) to + 5 volt
    pin 8 (GND) to ground
    relay 1-6 to pin 15 (Q0), 1 (Q1), 2 (Q2), 3 (Q3), 4 (Q4) and 5 (Q5) the other relay pins connected to ground
    Please @BartE correct me if I'm wrong since I have no personal experience from this kind of setup.
    • Tomas
    • V
      V
      vampircik
      collected is not working. the controller displays the switch, but it does not control the Arduino.
      • V
        V
        vampircik
        includes buttons, it is displayed on the controller, with only relay nothing happens
        • V
          V
          vampircik
          • korttomaK
            korttomaK
            korttoma
            Do you get anything in the serial monitor for your Relay Node?
            • Tomas
            • V
              V
              vampircik
              send: 18-18-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
              send: 18-18-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
              read: 0-0-18 s=255,c=3,t=6,pt=0,l=1,sg=0:M
              repeater started, id=18, parent=0, distance=1
              send: 18-18-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:RelaySix
              send: 18-18-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
              send: 18-18-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=0,c=2,t=2,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=2,c=2,t=2,pt=0,l=0,sg=0,st=ok:
              send: 18-18-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
              send: 18-18-0-0 s=3,c=2,t=2,pt=0,l=0,sg=0,st=fail:
              send: 18-18-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=fail:
              send: 18-18-0-0 s=4,c=2,t=2,pt=0,l=0,sg=0,st=fail:
              send: 18-18-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=fail:
              send: 18-18-0-0 s=5,c=2,t=2,pt=0,l=0,sg=0,st=fail:
              find parent
              send: 18-18-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
              read: 0-0-18 s=0,c=1,t=2,pt=0,l=1,sg=0:0
              send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
              Incoming change for sensor:0, New status: 0
              read: 0-0-18 s=1,c=1,t=2,pt=0,l=1,sg=0:0
              send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
              Incoming change for sensor:1, New status: 0
              read: 0-0-18 s=2,c=1,t=2,pt=0,l=1,sg=0:0
              send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
              Incoming change for sensor:2, New status: 0
              read: 0-0-18 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              parent=0, d=1
              Switch #1 to 1
              Switch #2 to 1
              Switch #3 to 1
              Switch #4 to 1
              Switch #5 to 1
              Switch #1 to 0
              send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #1 to 1
              Switch #2 to 0
              send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #2 to 1
              Switch #0 to 1
              Switch #0 to 0
              send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #3 to 0
              send: 18-18-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #3 to 1
              Switch #4 to 0
              send: 18-18-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #4 to 1
              Switch #5 to 0
              send: 18-18-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
              Switch #5 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #5 to 0
              Switch #5 to 1
              Switch #5 to 0
              Switch #5 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #5 to 0
              Switch #5 to 1
              Switch #3 to 0
              Switch #3 to 1
              Switch #3 to 0
              Switch #3 to 1
              Switch #3 to 0
              Switch #3 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #4 to 0
              Switch #4 to 1
              Switch #5 to 0
              Switch #5 to 1
              Switch #0 to 1
              Switch #0 to 0
              Switch #0 to 1
              Switch #0 to 0
              Switch #2 to 0
              Switch #2 to 1
              Switch #2 to 0
              Switch #2 to 1
              Switch #1 to 0
              Switch #1 to 1
              Switch #1 to 0
              Switch #1 to 1
              • V
                V
                vampircik
                this is what I have now happened. includes a button, turn on the relay, reclosing button, there is no result
                • V
                  V
                  vampircik
                  individual libraries should be shipped to the chip?
                  • V
                    V
                    vampircik
                    This post is deleted!
                    • BartEB
                      BartEB
                      BartE
                      wrote on last edited by BartE
                      #30
                      @vampircik i see that with some help from korttoma you manage to find the correct pins setting. @korttoma thx for your help.
                      korttoma is right about the pin 11, i should have added this link with more background info
                      The sketch is designed for push buttons and not for toggle switches and will respond when releasing a button press.
                      In your movie i see that switching on and off via MySensors (mouse clicks) works but the button presses not (always) only switching off.
                      I found an error in my sketch on line 131
                      // Store new switch value
                      switches[id].currentStatus = (switchValue ? 0 : 1);
                      the correct line should be
                      // Toggle relay status
                      switches[id].currentStatus = (switches[id].currentStatus ? 0 : 1);
                      note: I've updated the sketch in the original post as well
                      • V
                        V
                        vampircik
                        BartE Thank you. everything worked.
                        • V
                          V
                          vampircik
                          I made my monetary investment. though not particularly large
                          • V
                            V
                            vampircik
                            Connect the power supply to the relay which should be governed by the device stops working
