  3. RelayWithButtonActuator (6 channel)
33 Posts 3 Posters 15.9k Views 2 Watching
  • V
    V
    vampircik
    includes buttons, it is displayed on the controller, with only relay nothing happens
    • V
      V
      vampircik
      • korttomaK
        korttomaK
        korttoma
        Do you get anything in the serial monitor for your Relay Node?
        • Tomas
        • V
          V
          vampircik
          send: 18-18-0-0 s=255,c=0,t=18,pt=0,l=3,sg=0,st=ok:1.5
          send: 18-18-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          read: 0-0-18 s=255,c=3,t=6,pt=0,l=1,sg=0:M
          repeater started, id=18, parent=0, distance=1
          send: 18-18-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:RelaySix
          send: 18-18-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
          send: 18-18-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=0,c=2,t=2,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=2,c=2,t=2,pt=0,l=0,sg=0,st=ok:
          send: 18-18-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
          send: 18-18-0-0 s=3,c=2,t=2,pt=0,l=0,sg=0,st=fail:
          send: 18-18-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=fail:
          send: 18-18-0-0 s=4,c=2,t=2,pt=0,l=0,sg=0,st=fail:
          send: 18-18-0-0 s=5,c=0,t=3,pt=0,l=0,sg=0,st=fail:
          send: 18-18-0-0 s=5,c=2,t=2,pt=0,l=0,sg=0,st=fail:
          find parent
          send: 18-18-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
          read: 0-0-18 s=0,c=1,t=2,pt=0,l=1,sg=0:0
          send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
          Incoming change for sensor:0, New status: 0
          read: 0-0-18 s=1,c=1,t=2,pt=0,l=1,sg=0:0
          send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
          Incoming change for sensor:1, New status: 0
          read: 0-0-18 s=2,c=1,t=2,pt=0,l=1,sg=0:0
          send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:0
          Incoming change for sensor:2, New status: 0
          read: 0-0-18 s=255,c=3,t=8,pt=1,l=1,sg=0:0
          parent=0, d=1
          Switch #1 to 1
          Switch #2 to 1
          Switch #3 to 1
          Switch #4 to 1
          Switch #5 to 1
          Switch #1 to 0
          send: 18-18-0-0 s=1,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #1 to 1
          Switch #2 to 0
          send: 18-18-0-0 s=2,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #2 to 1
          Switch #0 to 1
          Switch #0 to 0
          send: 18-18-0-0 s=0,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #3 to 0
          send: 18-18-0-0 s=3,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #3 to 1
          Switch #4 to 0
          send: 18-18-0-0 s=4,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #4 to 1
          Switch #5 to 0
          send: 18-18-0-0 s=5,c=1,t=2,pt=1,l=1,sg=0,st=ok:1
          Switch #5 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #5 to 0
          Switch #5 to 1
          Switch #5 to 0
          Switch #5 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #5 to 0
          Switch #5 to 1
          Switch #3 to 0
          Switch #3 to 1
          Switch #3 to 0
          Switch #3 to 1
          Switch #3 to 0
          Switch #3 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #4 to 0
          Switch #4 to 1
          Switch #5 to 0
          Switch #5 to 1
          Switch #0 to 1
          Switch #0 to 0
          Switch #0 to 1
          Switch #0 to 0
          Switch #2 to 0
          Switch #2 to 1
          Switch #2 to 0
          Switch #2 to 1
          Switch #1 to 0
          Switch #1 to 1
          Switch #1 to 0
          Switch #1 to 1
          • V
            V
            vampircik
            this is what I have now happened. includes a button, turn on the relay, reclosing button, there is no result
            • V
              V
              vampircik
              individual libraries should be shipped to the chip?
              • V
                V
                vampircik
                • BartEB
                  BartEB
                  BartE
                  wrote on last edited by BartE
                  #30
                  @vampircik i see that with some help from korttoma you manage to find the correct pins setting. @korttoma thx for your help.
                  korttoma is right about the pin 11, i should have added this link with more background info
                  The sketch is designed for push buttons and not for toggle switches and will respond when releasing a button press.
                  In your movie i see that switching on and off via MySensors (mouse clicks) works but the button presses not (always) only switching off.
                  I found an error in my sketch on line 131
                  // Store new switch value
                  switches[id].currentStatus = (switchValue ? 0 : 1);
                  the correct line should be
                  // Toggle relay status
                  switches[id].currentStatus = (switches[id].currentStatus ? 0 : 1);
                  note: I've updated the sketch in the original post as well
                  • V
                    V
                    vampircik
                    BartE Thank you. everything worked.
                    • V
                      V
                      vampircik
                      I made my monetary investment. though not particularly large
                      • V
                        V
                        vampircik
                        Connect the power supply to the relay which should be governed by the device stops working
