  3. 12 volt downlight dimmer
ledswitch dimmerarduino
3 Posts 3 Posters 4.1k Views 3 Watching
  • HomerH
    HomerH
    Homer
    Hey!
    I have just installed lots of 12v LED downlights and would like to dim these. Each bulb is 7 watt and I have 2 bulbs attached to each driver. Will the same setup for the strips also work in this situation?
    • T
      TimO
      Hi!
      I'm using IRLIZ44N logic level mosfets together with the LED Dimmer Example in the MySensors library. Works like a charm.
      • BartEB
        BartEB
        BartE
        @Homer I've made a 2 double LED dimmer as well works very good and can easily be extended with more dimable leds.
        See my project here
