  3. gw.present(sensor, S_LIGHT) - hangs on 4th sensor
10 Posts 4 Posters 3.9k Views 3 Watching
  • afulkiA
    afulkiA
    afulki
    I edited the RelayActuator sketch to include 4 relays, on pins 3 to 6. I was having an issue controlling them so dug further, I can only see 3 of the 4 sensors in MYSController and added some serial debugging to the sketch to pinpoint where things are going wrong.
    This is the output:
    send: 2-2-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 2-2-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
    send: 2-2-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-2 s=255,c=3,t=15,pt=0,l=1,sg=0:0
    read: 0-0-2 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=2, parent=0, distance=1
    send: 2-2-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:Desk Power Relay
    send: 2-2-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    Init Sensor : 1, pin 3
    before present...
    send: 2-2-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    before pinMode...
    Sensor configured - OK!
    Init Sensor : 2, pin 4
    before present...
    send: 2-2-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    before pinMode...
    Init Sensor : 3, pin 5
    before present...
    send: 2-2-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    before pinMode...
    Init Sensor : 4, pin 6
    before present...
    The code was modified as follows:
        Serial.print("Init Sensor : ");
        Serial.print(sensor);
        Serial.print(", pin ");
        Serial.println(pin);
        Serial.println("before present...");
        gw.present(sensor, S_LIGHT);
        Serial.println("before pinMode...");
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
        Serial.println("Sensor configured - OK!");
        Serial.println();
    On the 4th sensor, it never gets past the present line.
      How do you power your sensor, and what capactítor(s) are you using? (Step 5 in http://forum.mysensors.org/topic/666/how-to-ask-for-help )
      Adding a 100-250ms delay after each present seems to help people, you could see if that helps in your case as well.
      • afulkiA
        afulkiA
        afulki
        HI, thanks for the prompt reply.
        I'm powering it via the 3.3v pin on an Arduino Nano (which is powered from the USB). I have a capacitor across the RF board (470uF).
        I added the delay(250) after the present, and the 4th completed this time (after about 2-3s).
        • BartEB
          BartEB
          BartE
          @afulki What did you change in the default sketch i've tried to reproduce you issue with this sketch
           * Version 1.0 - Henrik Ekblad
          #include <MySigningNone.h>
          #include <MyTransportNRF24.h>
          #include <MyTransportRFM69.h>
          #include <MyHwATMega328.h>
          #define NUMBER_OF_RELAYS 4 // Total number of attached relays
          //MyTransportRFM69 radio;
          //MySigningNone signer;
          MyHwATMega328 hw;
          MySensor gw(radio, hw);
            gw.begin(incomingMessage, AUTO, false);
            gw.sendSketchInfo("Relay", "1.0");
            // Fetch relay status
              Serial.println();
            gw.process();
            if (message.type==V_LIGHT) {
               // Change relay state
               // Store state in eeprom
               // Write some debug info
               Serial.print(message.sensor);
          And my serial monitor shows this output
          send: 11-11-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
          send: 11-11-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
          send: 11-11-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
          sensor started, id=11, parent=0, distance=1
          send: 11-11-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
          send: 11-11-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          before present...
          send: 11-11-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          before pinMode...
          before present...
          send: 11-11-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          before pinMode...
          before present...
          send: 11-11-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          before pinMode...
          before present...
          send: 11-11-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
          before pinMode...
          Just before this line
          i see 2 more lines in your log , did you add something before the for loop?
          afulkiA 1 Reply Last reply
          • afulkiA
            afulkiA
            afulki
            Hi BartE,
            This is the source, I switched around the relay high low, the name of the sketch and the false on the begin statement. I have no idea where those two extra lines come from, but will try to track them down.
            #define RELAY_1  PD3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            #define RELAY_ON 0  // GPIO value to write to turn on attached relay
            #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
            MyHwATMega328 hw;
              gw.sendSketchInfo("Desk Power Relay", "1.0");
                delay(250);
              gw.process();
            • sundberg84S
              Could be unrelated but if all fails I had this issue with a normal reed switch sensor. Worked great for some time but always dead sooner or later. Never found out what the problem was but uploaded same sketch to another hardware and everything was ok.
              • sundberg84S sundberg84
                afulkiA
                afulkiA
                afulki
                @sundberg84
                I switched out both the radio and the nano, it seems to be the nano, the new one initialized fine with both radios. As a software guy my first response should have been that it was a hardware issue! :smiling_imp:
                Thanks for the help!
                Gary
                • BartEB BartE
                  MyHwATMega328 hw;
                      Serial.println();
                    gw.process();
                  before present...
                  before pinMode...
                  before present...
                  before pinMode...
                  before present...
                  before pinMode...
                  before present...
                  before pinMode...
                  afulkiA
                  afulkiA
                  afulki
                  @BartE
                  I added some extra logging (yes even more) and the 2 extra lines are sent during the gw.begin, I think the
                  send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
                  Is telling the gateway about the arduino node (could be wrong still looking through the code).
                  Gary
                  • afulkiA
                    afulkiA
                    afulki
                    I spoke too soon, it's back to not initializing the 4th output, or rather no doing returning from gw.present();
                    • afulkiA
                      afulkiA
                      afulki
                      I added a lot more debug output and find that it gets stuck in here:
                      	while( ! ( get_status()  & ( _BV(TX_DS) | _BV(MAX_RT) ))) {
                      		#if defined (FAILURE_HANDLING)
                      			if(millis() - timer > 75){
                      				errNotify();
