  3. The new Atmega328PB
The new Atmega328PB
29 Posts 8 Posters 14.7k Views 7 Watching
  • S Samuel235
    @GertSanders, I'm pretty sure there is a software serial port work-around. So if you wanted to have the SPI ports AND the two serial ports, you could use digital pins for serial2 and then enable the software serial port as serial port 2. That way, correct me if i'm wrong, you would end up with 2 serial ports and 2 SPI ports. Again, i'm not 100% certain on this topic though, I'm out of my depths, its given me some information and a lot of interest in learning about the ports even more now though, thank you!
    Not sure if this gives you any other possibilities, but this is the NewSoftSerial solution that enables you to have a software serial port. http://arduiniana.org/libraries/newsoftserial/
    GertSandersG
    GertSandersG
    GertSanders
    @Samuel235
    This library is actually part of Arduino IDE 1.x and can be used for the purpose of using other pins as serial ports. But the atmega328pb has two hardware serial ports possible. The question is if I need them. In my case I prefer an extra SPI port over all the ADC pins (4 analog inputs is more then enough im my case).
    The datasheet of the atmea328pb is quite an interesting read indeed.
    S 1 Reply Last reply
    • GertSandersG GertSanders
      @Samuel235
      Samuel235
      @GertSanders said:
      I In my case I prefer an extra SPI port over all the ADC pins (4 analog inputs is more then enough im my case).
      I think you have just answered your own question. If it suits your situation more, then go for the extra SPI port. I don't see where 2 seeial ports would be any use in any situation other than a gateway tbh. But thats my opinion :)
      I might make the datasheet my next morning read over my breakfast ;)
      MySensors 2.1.1
      • tbowmoT
        tbowmoT
        tbowmo
        @Samuel235 @GertSanders
        Consider a RS485 network, with a node that needs to talk with a sensor / actuator via rs232.. Then dual UARTS is quite usable :)
        But I admit, it's a very rare situation..
        • tbowmoT tbowmo
          GertSandersG
          GertSandersG
          GertSanders
          @tbowmo
          It seems two SPI devices connected to the mcu is more common (ethernet and nrf24, or flash and nrf24).
            @tbowmo
            Samuel235
            @GertSanders talking about that, i may add some flash to my latest sensor board. Just a thought.
            MySensors 2.1.1
            • tbowmoT
              tbowmoT
              tbowmo
              @GertSanders
              You can always multiplex the spi bus, and have multiple devices share it (unless it's a buggy w5100 module..)
              • Nca78N
                Nca78N
                Hello, did anyone happen to use this new chip in the end ?
                Or did it arrive too late ?
                YveauxY 1 Reply Last reply
                • Nca78N Nca78
                  YveauxY
                  YveauxY
                  @Nca78 I did test it for Atmega328p compatibility which looked just fine.
                  Not sure what the current state is regarding support for the extra peripherals though.
                  Nca78N 1 Reply Last reply
                  • YveauxY Yveaux
                    Nca78N
                    Nca78N
                    @Yveaux ok thank you I will have a look at what is available in the arduino ports.
