  3. Signing or encrypting the data
38 Posts 9 Posters 13.3k Views 9 Watching
  • M Offline
    M Offline
    meddie
    i thin it is very important that the messages which will be send from nodes or from gateway are signed, or encrypted.
    Can somebody explain how to do this with the new api for beginners. I am not really good in this, and would be happy to get explained how to go on for dummies.
    Thank you
    Greets Eddie
    • mfalkviddM Offline
      First you need to determine if you want signing or encryption. A good place to start is answering "why" (instead of what).
      When you have decided, go to http://forum.mysensors.org/topic/1021/security-introducing-signing-support-to-mysensors for signing and http://forum.mysensors.org/topic/2005/software-aes-encryption-for-nrf24/1 for encryption.
      • C Offline
        C Offline
        carlierd
        @mfalkvidd : why not using both signing and encryption ? I am using both (encryption with RFM69) and really want to know if I am a little bit 'paranoiac' ;)
          You might not be paranoid enough. A lot of what your sensors do can probably be deduced from the timing of the messages, even if the messages are encrypted.
          So by using encryption you might think that you are more protected than you really are. I think that is a dangerous situation.
          It is all about the why. If the why is "I don't want other people to turn on and off my lights/lock/heat/stereo" the answer is not encryption.
          If the why is "I don't want someone dedicated to map my life to figure out when I'm home, what room I am in when I'm home, when I listen to music, what time I get up in the morning, etc" the answer is not encryption.
          If the why is "Because I want to be cool and I think encryption is makes me cool" then yes, the answer is encryption.
          C M 2 Replies Last reply
            C Offline
            C Offline
            carlierd
            :laughing:
            So using both is the solution. I don't want someone read my data (presence, alarm status, etc.) and I don't want someone able to open my garage door. No ?
            David.
              No. It is quite likely that someone who is interested in that data will be able to figure it out even if you are using encryption. If you think encryption makes it impossibe to figure out what time you come home each day, what time you go to bed and turn on the alarm, what time you get up and turn off the alarm, etc, you think you are more secure than you really are.
              • C Offline
                C Offline
                carlierd
                Ok but it's true for all wireless system and encryption just give you a better security but as all system it's not perfect.
                For me, the security of my sensors are the same as my door. My door is strong but not unbreakable. It's just strong enough to avoid anybody entering my house easily. It's possible to break it but you need time and specific tool.
                For my sensors it's the same, you could learn my usage but it will cost a lot of effort and time for ..... nothing else my 5 years old TV and some panties ;)
                David
                  M Offline
                  M Offline
                  meddie
                  OK, i thought, when encrypted, that nobody else can read the messages.
                  I dont want be cool :-), i really want to be safe, that nobody can turn on/off anything, or read the states of my sensors to get the informations you wrote above.
                  The sensors can give a really sensitive information. Because when somebody can read the states maybe he can recontruct your day. And then he knows exactly when you are not at home.
                    Yes, that's exactly my point. If you think encryption makes it impossible to see when you are home, you've been misled.
                    If someone can look out their window and see you come and go, they can map your day.
                    If someone can see through your windows when lights are on, they can map your day.
                    If someone can see when your sensors send messages, they can map your day.
                    Using encryption will not change that.
                    There are some benefits to encryption, but encryption does not solve all problems.
                    • M Offline
                      M Offline
                      meddie
                      I would preffer to sing and encrypt the messages. So it sure that the data is from correct node/controller, and is not faked. And encrypted and so not readable for third.
                      But i would to use OTA too, and if i have correct understood, then its not possible. Because the bootloader needs the data unencrypted.
                      Please correct me when i am false.
                      i wish some how to's for dummies. Signing, Encrypting and OTA.
                      It would be the perfect System, sure and future-proof.
                      • M Offline
                        M Offline
                        meddie
                        OK, 100% safety you will never get, but its more safer then to send messages readable for everyone.
                        • A Offline
                          A Offline
                          Anticimex
                          If there is anything in the documentation about signing that is unclear just let me know. I have tried to write it in a manner that makes it accessible to anyone. And I totally support @mfalkvidd in his stance on encryption. It is essentially pointless in a mysensors context. If you stream audio or video it would make sense but for sensor data, considering the predictability of that data, encryption makes you no safer in any sense. It merely obfuscate the data slightly.
                          • M Offline
                            M Offline
                            meddie
                            please dont get angry with me, and correct if i am wrong. But when a sensor sends a message that a window is opened. And somebody can read this message then he konws that the window is not closed.
                            When the message is signed then i know that the message is correct and comes from cerrect node. But the message is readable for "everyone" (is it right?)
                            So everybody can read your sates. (is it right too?)
                            When messages are singed and encrypted, then this anybody who can "listen" cant read the messages. He can still receive them but he cant start anything with them. He has only the info that one of the sensors has send data, but dont get the content of the data
                            A 1 Reply Last reply
                            • M meddie
                              A Offline
                              A Offline
                              Anticimex
                              @meddie What's preventing anyone from walking up to your window and feeling if it is locked or not?
                              Or look at it this way:
                              1 = open, 0 = locked. If sent in clear text, an eavesdropper sees '1' or '0'. Now, assuming he knows which is what, then he knows the window is opened or closed. But that is really not important information.
                              So what do you get by encrypting that data? Well, you achieve "some certainty" that an eavesdropper don't know if you just locked your window. But he will know for sure you did something with the window at that point in time. And there is a 50% chance, you locked the window.
                              Now, that being said; encryption is supported for both NRF24 and RFM69 radios, so if it makes you feel better, just enable it. It won't makes things worse. But signing provides a far greater security value than encryption, so if you really care about security, you should prioritize signing.
                              R 1 Reply Last reply
                              • M Offline
                                M Offline
                                meddie
                                Yes you have 100% right. I think the combination of signing and encrypting should be the better choice.
                                But is IT right that ota wont work if encrypting?
                                • A Offline
                                  A Offline
                                  Anticimex
                                  That depend on what bootloader you use. If you use MYSbootloader, then it won't work as it is the bootloader that manages the radio. But if you use dualoptiboot, the OTA solution is radio independent as the firmware is transferred in a "mysensors context" and stored on external flash before rebooting and then the dualoptiboot bootloader moves that firmware to internal flash. So with dualoptiboot, it should be possible to encrypt the data.
                                  But note that in both cases, signing won't be used for performance reasons. The checksum of the firmware will be signed though.
                                  It is in the pipeline to support SHA256 checksumming the firmware and sign that checksum for greater security (it currently uses crc). But it is not yet in place. @tekka is our core team OTA developer, he might fill you in on the details on OTA with respect to signing and encryption and which variant supports what.
                                  A M 2 Replies Last reply
                                  • A Anticimex
                                    A Offline
                                    A Offline
                                    ahmedadelhosni
                                    wrote on last edited by ahmedadelhosni
                                    @Anticimex If I remember well, It was mentioned in a conversion between you and mfalkvidd that even if I am using dualOptiboot and the messages are singed then I am not fully secured.as a hacker can easily flash a new bootloader with no signing support. This will happen currently as OTA doesn't support signing and this is currently in the development phase by tekka as far as I know.
                                    • A ahmedadelhosni
                                      A Offline
                                      A Offline
                                      Anticimex
                                      @ahmedadelhosni well, that depends on what level of security you seek. Messages are signed if you configure your nodes properly. Just not stream type payloads. But the messages to initiate and finalize OTA are signed. The discussion I had with mfalkvidd concerned the use of crc which is a checksum easier spoofed than for instance sha256.
                                      • A Anticimex
                                        M Offline
                                        M Offline
                                        meddie
                                        OK, nice to hear that its possible. When i have to put an external flash and a dualoptibootloader, then its not the problem.
                                        What do mean, i didnt understand. Can you explain this please.
                                        Thank you very much!
                                        Greets Eddie
                                        • A Anticimex
                                          R Offline
                                          R Offline
                                          Rasenheizung
                                          Maybe it's my bad English or I really haven't understood it correctly.
                                          Signing: Verifies the sender and receiver are known.
                                          Encryption: Encodes the message so it's only readable for you.
                                          So in conclusion, if I'm signing my messages I'm only getting my messages and only I am able to read my messages. So no third party can give me wrong messages and can't read my messages? He also should not be able to read if I'm playing with my door/window nore if I'm opening or closing it.
