  3. Signing or encrypting the data
38 Posts 9 Posters 14.0k Views 9 Watching
  • M meddie
    @Anticimex said:
    That depend on what bootloader you use. If you use MYSbootloader, then it won't work as it is the bootloader that manages the radio. But if you use dualoptiboot, the OTA solution is radio independent as the firmware is transferred in a "mysensors context" and stored on external flash before rebooting and then the dualoptiboot bootloader moves that firmware to internal flash. So with dualoptiboot, it should be possible to encrypt the data.
    OK, nice to hear that its possible. When i have to put an external flash and a dualoptibootloader, then its not the problem.
    But note that in both cases, signing won't be used for performance reasons.
    What do mean, i didnt understand. Can you explain this please.
    Thank you very much!
    Greets Eddie
    AnticimexA
    AnticimexA
    Anticimex
    @meddie a signature takes up part of the available payload space. For nrf24 it is 27 bytes. For a signature to be efficient it needs to be reasonably large, say have the available payload. That leaves have the amount left for binary data. OTA require MANY packages to transfer a typical sketch. For each package a nonce exchange will take place. For this reason, signing is not used for streams. And it does not have to be. A stream should always be checksummed in order to be fully validated. A signature only needs to cover that checksum.
    ahmedadelhosniA 1 Reply Last reply
    • R Rasenheizung
      @Anticimex said:
      @meddie What's preventing anyone from walking up to your window and feeling if it is locked or not?
      Or look at it this way:
      1 = open, 0 = locked. If sent in clear text, an eavesdropper sees '1' or '0'. Now, assuming he knows which is what, then he knows the window is opened or closed. But that is really not important information.
      So what do you get by encrypting that data? Well, you achieve "some certainty" that an eavesdropper don't know if you just locked your window. But he will know for sure you did something with the window at that point in time. And there is a 50% chance, you locked the window.
      Now, that being said; encryption is supported for both NRF24 and RFM69 radios, so if it makes you feel better, just enable it. It won't makes things worse. But signing provides a far greater security value than encryption, so if you really care about security, you should prioritize signing.
      Maybe it's my bad English or I really haven't understood it correctly.
      Signing: Verifies the sender and receiver are known.
      Encryption: Encodes the message so it's only readable for you.
      So in conclusion, if I'm signing my messages I'm only getting my messages and only I am able to read my messages. So no third party can give me wrong messages and can't read my messages? He also should not be able to read if I'm playing with my door/window nore if I'm opening or closing it.
      AnticimexA
      AnticimexA
      Anticimex
      @Rasenheizung well, I thought I just explained why encryption is pointless in this case. Unless the attacker is exceptionally stupid, he will be able to deduce the content of a simple message, encrypted or not, by just examining the traffic over a period of time. It is dangerous to underestimate your adversary so that is why I do not recommend encryption only I'd you care about security. But as I said, if you feel better with it, just use it. But don't expect your data to be truly private just because you obfuscate it.
      M 1 Reply Last reply
      • AnticimexA Anticimex
        meddie
        @Anticimex
        no, 100% safety wll never be possible. But i would feel me better when i know that the messages are not so easy readable for someone who has a mysensors too.
        I have some weeks ago read in the FHEM Forum, there has a user build a second gateway just for testing, and as he started them the whole sensors has sended the data twice to both gateways. The logical
        I didnt try this, but it's scary when it is so easy possible to read the sensors.
        • sundberg84S
          @meddie This is not uncommon, build yourself a 433mhz gateway and you will receive every 433 message in that gateway range... also a bit scary since many home alarms and other security things use 433mhz.
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            wrote on last edited by ahmedadelhosni
            #25
            Please bear with me. I just want to be sure I understand it well.
            "For this reason, signing is not used for streams." Means that signing is not used when uploading a sketch. Does this lead to a hacker replacing my sketch ?
            Checksum will make sure that the sketch is transferred correctly to avoid data corruption, NOT security, correct ?
            So you propose that a signature must be added with the checksum for security, correct ??
            So in brief. OTA is not secured at the moment and the code can be replaced easily with an unsigned one, correct ?
            Thanks.
            AnticimexA 1 Reply Last reply
            • AnticimexA
              AnticimexA
              Anticimex
              You are perfectly correct. But if you reach my level of paranoia, you will find that encryption provides little comfort. But you may use it to your hearts content of course.
              • ahmedadelhosniA ahmedadelhosni
                Thanks.
                AnticimexA
                AnticimexA
                Anticimex
                No, I stated that the sketch is checksummed and that checksum is signed. So no, a hacker won't (probably) be able to replace your sketch. Lest he is able to produce one that yields the exact same checksum AND manages to inject it so that the signed checksum is arrived in a timely manner for the receiver to take it into account.
                Checksum will make sure that the sketch is transferred correctly so to avoid data corruption, correct ?
                "Sure" in this aspect is a very relative term. But yes, that is it's purpose.
                No, I say it is added if signing is enabled. But please be aware that the current version of MYSBootloader does not support signing. Future versions will do.
                No, as I said, dualoptiboot should be secure. But the use of CRC as checksum is not as secure as SHA256 would be, so the security is not as good as it can be.
                ahmedadelhosniA M 2 Replies Last reply
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @Anticimex Great. now it is very clear :) Thanks a lot
                  I will order all ICs soon and test this in real life :)
                    meddie
                    @ahmedadelhosni
                    Fine, please let stay me informed, because i am very interested too.
                    • M meddie
                      @ahmedadelhosni
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      #30
                      @meddie Sure. Maybe by the end of that month I may begin in OTA process.
                      I hope I can find good documentation :)
                        meddie
                        @Anticimex
                        one more question: is it possble to run the atmega with dualoptiboot bootloader at 1MHz. For battery use. And use the the encryption and signing and OTA.
                          meddie
                          @ahmedadelhosni
                          fine, thank you in advanced
                          • M meddie
                            @Anticimex
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @meddie Please direct OTA questions to @tekka He can better explain what is supported in which solution and when any unsupported features will be available if planned.
                            Generally, 1MHz offer little battery benefit over 8MHz.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              for a MCU that never enters sleep states, running at 1Mhz can save you some power, compared to running at 8Mhz. But if you plan to enter sleep state, and only wake up periodically, you won't gain that much. As sleepmode current is the same for both 1Mhz and 8Mhz.
                              One can also argue that if you are using 1Mhz, then the program execution will be longer, compared to 8Mhz. So when it wakes up from sleep mode, it will stay awake for a longer time, if running at 1Mhz, compared to 8Mhz.
                              • tbowmoT tbowmo
                                ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                @tbowmo Good points. Neven thought about it as I flash 1Mhz always.
                                I may try power consumption using 8Mhz in a new sensor node.
                                Thanks for the info.
                                  meddie
                                  wrote on last edited by meddie
                                  #36
                                  yes me too. i will try my test setup to burn the bootloader at 8 mhz. It would make much easier.
                                  • SoloamS
                                    SoloamS
                                    Soloam
                                    Any one tried to run a atmega with encryption and software signing? And with Hardware Signing?
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                            Yes.
