  3. Newbie help DHT22 on battery need sketch.
9 Posts 4 Posters 3.4k Views 3 Watching
  • E Offline
    E Offline
    Eawo
    wrote on last edited by Eawo
    Hello
    Im kinda new to this mysensor ive done a few noods with step by step guides.
    1 mars i will move to a house. And i need to know the humidity under the house couse its to high.
    this is my setup @ moment:
    I need some help figuring out a sketch that will run on this. I dont need to update humidity more then every 20 min.
    I dont know any coding but i want to learn. So if anyone could give me a good tip how to startout i would be greatful.
    Im going to remove the led an i wonder if i can remove the regulator to? couse i heard the dht22 need 3.3v "actually its a Am2303".
    • hekH Offline
      hekH Offline
      Just increase sleep time in this one:
      https://codebender.cc/sketch:47533
      • E Offline
        E Offline
        Eawo
        Can i remove the regulator for better battery life or should i keep it?
        Is it possible to add so i can see my battery status?
        • S Offline
          Hi!
          Am2303 can run on 3.3 to 6v according to datasheet, so yes remove the regulator.
          But if you are using a 3.3v arduino (which is best for battery) i would use a booster or the DHT will stop working pretty soon.
          • hekH Offline
            hekH Offline
            wrote on last edited by hek
            You'll have to read the datasheet of the hum sensor. Measuring battery voltage is described on the main site.
            Edit. darn @sundberg84 was fast! ;)
            • E Offline
              E Offline
              Eawo
              ok im soon finished with it i guess i should order some link text
              but for now i just want to try it out :). Thanks for the help
              • E Offline
                E Offline
                Eawo
                up and running
                now im waiting for some stepup 3v3
                • HoffanH Offline
                  HoffanH Offline
                  Hoffan
                  @Eawo
                  Where did you get that box??
                  • E Offline
                    E Offline
                    Eawo
                    This box I used good quality but a bit to small for me.
                    http://m.aliexpress.com/item/1993296858.html
