  3. Newbie help DHT22 on battery need sketch.
9 Posts 4 Posters 3.3k Views 3 Watching
  • E Offline
    E Offline
    Eawo
    wrote on last edited by Eawo
    Hello
    Im kinda new to this mysensor ive done a few noods with step by step guides.
    1 mars i will move to a house. And i need to know the humidity under the house couse its to high.
    this is my setup @ moment:
    I need some help figuring out a sketch that will run on this. I dont need to update humidity more then every 20 min.
    I dont know any coding but i want to learn. So if anyone could give me a good tip how to startout i would be greatful.
    Im going to remove the led an i wonder if i can remove the regulator to? couse i heard the dht22 need 3.3v "actually its a Am2303".
    • H Offline
      H Offline
      Just increase sleep time in this one:
      https://codebender.cc/sketch:47533
      • E Offline
        E Offline
        Eawo
        Can i remove the regulator for better battery life or should i keep it?
        Is it possible to add so i can see my battery status?
        • S Offline
          Hi!
          Am2303 can run on 3.3 to 6v according to datasheet, so yes remove the regulator.
          But if you are using a 3.3v arduino (which is best for battery) i would use a booster or the DHT will stop working pretty soon.
          • H Offline
            H Offline
            wrote on last edited by hek
            You'll have to read the datasheet of the hum sensor. Measuring battery voltage is described on the main site.
            Edit. darn @sundberg84 was fast! ;)
            • E Offline
              E Offline
              Eawo
              ok im soon finished with it i guess i should order some link text
              but for now i just want to try it out :). Thanks for the help
              • E Offline
                E Offline
                Eawo
                up and running
                now im waiting for some stepup 3v3
                • HoffanH Offline
                  HoffanH Offline
                  Hoffan
                  @Eawo
                  Where did you get that box??
                  • E Offline
                    E Offline
                    Eawo
                    This box I used good quality but a bit to small for me.
                    http://m.aliexpress.com/item/1993296858.html
                    12.1k
