  3. Problem with relay+button and dallas temperature sketch combination
4 Posts 2 Posters 2.4k Views 2 Watching
  • MixeurM
    MixeurM
    Mixeur
    wrote on last edited by Mixeur
    I wanted to make a node that both read temperature from 2 dallas sensors and activate a relay (with button option).
    It works pretty fine, but only for an undetermined time. Afeter sometime (1 or 2 days), if I push the button, it crahses, and i have to reset it to get the good behaviour. If I don't use the relay features, everything is working normally a long time.
    Here is the sketch :
    #include <Bounce2.h>
    #include <OneWire.h>
    // Partie Température
    #define ONE_WIRE_BUS 8 // Pin where dallase sensor is connected
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    // Partie Relay
    #define RELAY_PIN  4  // Arduino Digital I/O pinnumber for relay
    #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
    #define CHILD_ID 17   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    int oldValue=0;
    bool state;
    unsigned long previousMillis = 0;
    MyMessage msg2(CHILD_ID,V_LIGHT);
      sensors.begin();
      gw.sendSketchInfo("Relay & Button", "1.0");
      gw.sendSketchInfo("Temperature Sensor", "1.1");
      Serial.print(numSensors);
      Serial.println(" temperature sensors detected");
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
         gw.present(i, S_TEMP);
      gw.present(CHILD_ID, S_LIGHT);
      pinMode(RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID);
      gw.process();
      // Relay button
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
          gw.send(msg2.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
      //int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution());
      // gw.wait(conversionTime);
      if (currentMillis - previousMillis >= SLEEP_TIME) {
        // save the last time you read temperature
        previousMillis = currentMillis;
          #if COMPARE_TEMP == 1
          #else
      if (message.isAck()) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID, state);
         // Write some debug info
         Serial.print(message.sensor);
    You will see it is almost a copy-cut of the sketches available here, but without any sleep or wait, that causes the button not to work...
    Anyone see what could be the problem ?
    Thanks.
    AWIA 1 Reply Last reply
    • MixeurM Mixeur
      int numSensors=0;
      // Partie Relay
      #define RELAY_ON 1
      #define RELAY_OFF 0
      int oldValue=0;
      bool state;
        sensors.begin();
       // Setup the button
        gw.process();
        // Relay button
        debouncer.update();
        oldValue = value;
            #else
      Thanks.
      AWIA
      AWIA
      AWI
      @Mixeur A relay generates a lot of noise on the power lines. Much has been written on this issue on the forum. Try powering the relays from a different voltage regulator and a enough decoupling capacitors on the power lines. Especially the radio needs stable power.
      • MixeurM
        MixeurM
        Mixeur
        Actually, It is what I did. I use a LM317 to power all 5V devices from a 12V power supply (arduino, relay and ds18b20).
        3.3V for the radio is obtained from LM1117 (its input is the LM317). The radio also has a 4.7 uF capacitor on power line. So I'm unsure this is a question of noise on powerlines. Also, issue is only happening after a few undetermined time. I can trigger how many I want the relay with any issue after powering the module, without problem.
        It is just a question of time. So I think it can be a software issue, but I don't see anything in my sketch.
        • MixeurM Mixeur
          AWIA
          AWIA
          AWI
          @Mixeur 0_1454875053591_upload-1a3e50aa-5e84-4235-9f46-77db31dad43a start of a difficult journey .... i finally changed the relays for SSD types.
          your sketch looks pretty straightforward.
