  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.2k Views 9 Watching
  • hoegaarden_bierH hoegaarden_bier
    Some typos in English language when adding a widget:
    Do a search on ' grpahica' => 'graphical'
    J
    J
    jkandasa
    Thank you! I will fix this typo.
    hoegaarden_bierH 1 Reply Last reply
    • hoegaarden_bierH
      hoegaarden_bierH
      hoegaarden_bier
      I noticed that when graphing data in dashboard (mixed sensors graph) for sensors that send data at different intervals (eg 1=5min;2=1min) that the graph and the interactive guide line is showing something what I think is the epoch time and the marker dots do not align (only at start of graph).
      Turning off the checkbox ( Use intractive guide line) resolves the issue.
      J 1 Reply Last reply
      • J jkandasa
        hoegaarden_bierH
        hoegaarden_bierH
        hoegaarden_bier
        @jkandasa
        Also here "Use intractive guide line" => "Use interactive guide line
        • hoegaarden_bierH
          hoegaarden_bierH
          hoegaarden_bier
          When sensor does not have a 'name' (resources-Sensor-sensor details) ,
          it shows as eg. 'null-Humidity' in the dashboard (mixed sensors graph).
          Maybe just show '-Humidity' ignore the null.
            J
            J
            jkandasa
            Yes, It's known issue with nvd3 chart plugin. For that only I gave an option to disable interactive guide
            • J jkandasa
              J
              J
              jkandasa
              @hoegaarden_bier Thank you for your support!!
              • hoegaarden_bierH
                hoegaarden_bierH
                hoegaarden_bier
                When trying to uploading a Firmware , I create a version + type , then try to upload a firmware file (eg. BLINK.ino sketch ), I get an error
                2016-03-01 21:43:32,002 ERROR [Acme.Utils.ThreadPool(8)-PooledThread: Acme.Serve.Serve$ServeConnection@5f12cf] [org.mycontroller.standalone.api.jaxrs.exception.mappers.ApplicationExceptionMapper:41] ApplicationException,
                org.jboss.resteasy.spi.ApplicationException: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:152) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:295) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:249) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:236) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:395) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:202) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.plugins.server.tjws.TJWSServletDispatcher.service(TJWSServletDispatcher.java:40) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at Acme.Serve.Serve$ServeConnection.runServlet(Serve.java:2328) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at Acme.Serve.Serve$ServeConnection.parseRequest(Serve.java:2282) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at Acme.Serve.Serve$ServeConnection.run(Serve.java:2054) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at Acme.Utils$ThreadPool$PooledThread.run(Utils.java:1402) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
                Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                	at java.lang.String.substring(String.java:1950) ~[na:1.8.0]
                	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.getFirmware(FirmwareUtils.java:75) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.updateFirmwareFromHexString(FirmwareUtils.java:50) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.createFirmware(FirmwareUtils.java:161) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at org.mycontroller.standalone.api.jaxrs.FirmwareHandler.createFirmware(FirmwareHandler.java:211) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0]
                	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0]
                	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
                	at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
                	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:139) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                	... 15 common frames omitted
                This is the way it should work not?
                  J
                  J
                  jkandasa
                  wrote on last edited by jkandasa
                  #48
                  You should upload .hex file.
                  • J jkandasa
                    hoegaarden_bierH
                    hoegaarden_bierH
                    hoegaarden_bier
                    @jkandasa
                    Thx, that works :)
                    • hoegaarden_bierH
                      hoegaarden_bierH
                      hoegaarden_bier
                      Question,...
                      What makes the status of a NODE (under node details) go down?
                        Question,...
                        J
                        J
                        jkandasa
                        #51
                        @hoegaarden_bier
                        Have a look at https://github.com/mycontroller-org/mycontroller/issues/27
                        https://github.com/mysensors/Arduino/blob/f9d23c9c697ebc57d935aa4de6f47c3381a0810a/libraries/MySensors/core/MySensorCore.cpp#L241
                        node status will be checked based on I_HEARTBEAT_RESPONSE for every 30 minutes by default. If we do not receive with in 30 minutes, will mark that node as down. MyControllor will send _HEARBEAT request to all nodes every 30 minutes once. you can change this 30 minutes as your wish. located at Settings-->System --> Node alive check interval typo :) I will fix it (Noded alive check interval)
                        • hoegaarden_bierH
                          hoegaarden_bierH
                          hoegaarden_bier
                          Hey,
                          I'll be adding my defects on github as well :)
                          Thx for the quick responses, you must be close to my timezone or work very late/early;
                            Hey,
                            J
                            J
                            jkandasa
                            Hey,
                            https://github.com/mycontroller-org/mycontroller/issues/146 this should not be a bug, it's deleted all the resources log. Will fill with new information once it receives.
                            • hoegaarden_bierH
                              hoegaarden_bierH
                              hoegaarden_bier
                              Question:
                              When my sensor node does a 'requestTime', what time (epoch) does it send back?
                              Is this UTC, localtime????
                                Question:
                                J
                                J
                                jkandasa
                                Question:
                                will send local server time with local timezone.
                                https://github.com/mycontroller-org/mycontroller/blob/development/src/main/java/org/mycontroller/standalone/mysensors/MySensorsMessageEngine.java#L211
