  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.2k Views 9 Watching
  • J
    J
    jkandasa
    Hello everyone, MyController 0.0.3-alpha1 is almost ready to release. As it has huge changes we want beta testers before release.
    Changes summary:
    • brand new Enterprise level GUI
    • Supports multiple gateways
    • Feature added with timers (supports active time, send payload with delay, etc.,)
    • Add simple timer support
    • user friendly logs display and filter
    • user friendly action board
    • brand new dashboard (supports multiple dashboards)
    • Supports groups (scene control)
    • role based authentication (share particular resource to user)
    • and many more
    Currently I'm working on documentation. Kindly let me know if you are interested to test.
    • J
      J
      jkandasa
      demo server upgraded to new version of MyController.org.
      http://demo.mycontroller.org/
      • tekkaT
        tekkaT
        tekka
        Very nice and clean GUI. Good job!
          mvader
          I'll beta test.
          • W
            W
            Werwolfx
            hi
            @mvader said:
            I'll beta test.
            +1 and i want beta test this release
            • W
              W
              Werwolfx
              very nice update!
              i see demo page and i found one not good moment/
              if i add to the dashboard and click another link? my changes are broken =( and i not see the confirmation dialog about i lost all changes/
              may be you add this confirmation?
              sorry for my english. i am from Russia
              J 1 Reply Last reply
                A Former User
                +1 I want to beta test!
                • W Werwolfx
                  very nice update!
                  J
                  J
                  jkandasa
                  @Werwolfx said:
                  very nice update!
                  Yes, will be good to add confirmation to notify user. will add it thank you!
                  • C
                    C
                    cdr
                    do donators get priority? :)
                    • C cdr
                      J
                      J
                      jkandasa
                      Sure, I have PM the link.
                      • W
                        W
                        Werwolfx
                        wrote on last edited by Werwolfx
                        very nice update!
                        short install instructions:
                        0)stop old version if installed, backup it
                        1)copy this beta to a server
                        2)chmod +x bin/start.sh and stop.sh
                        3)open conf/mycontroller.properties and edit ip/port settings
                        4)bin/start.sh
                        5)open url in your browser, protocol https!
                        6)login admin/admin
                        7)see buteful interface
                        • After change the default admin password, mycontroller not logoff me and i not work in the interface.
                          after logoff and logon myself from new password i can use again
                        • in Resources-Sensors not sorting for Node EUI. May be you add sorting to click on header table names ?
                        • not found RAW message send =( may be you add to dashboard button, in button configuration set raw message, if user press to the button, message send to node. is good functional for release to custom message nodes and one of more steps to mycontroller can smart home system
                          May be add a REST API for send RAW message to other NODEs
                        where I can post comments / suggestions to use this beta version?
                          A Former User
                          On the "Sensors and variables mapping" page.
                          The page number controller dosent work, you are only able to see the first page.
                          Excellent work
                          Goran
                          • J
                            J
                            jkandasa
                            @Werwolfx @goranrad Thank you very much to spend time to test MyController.org.
                            I will fix the issues reported here as soon as.
                            @Werwolfx
                            I have added fix for this. Once we changed the password will redirect to login page automatically.
                            as per our current design Node EUI not supported for sorting on this page. we may implement it later. we are not going to give sorting option of each tab. in this case it looks bit odd if we put it on table header and nice widget already available with patternfly for sorting. So we are using it separately. in the recent build Node EUI was removed from sorting options.
                            Yes, I removed, was assuming no one is using it. Sure, I will add it again.
                            for now we do not have page to give feedback or comments. But for issues kindly use https://github.com/mycontroller-org/mycontroller/issues
                            • T
                              Tag
                              Can i test release 0.0.3 please? :smiley:
                              WOW!! this is really cool stuff!!!
                              Got a serial gateway with 2 wireless sensors running,
                              Sensor 1:
                              -Humidity
                              -Temperature (DHT22)
                              -Lightlevel (DHT22)
                              Sensor 2:
                              -Temperature (BMP085)
                              -Airpressure (BMP085)
                              -Outside temperature (with NTC)
                              Keep up the good work!!!!
                              • R
                                R
                                robosensor
                                Sorry, seems like I broken demo site by entering " ` " in temperature field of sensor :worried:
                                Now getVariables returns 500 error with message:
                                errorMessage:"java.lang.NumberFormatException: For input string: "`""
                                • R robosensor
                                  J
                                  J
                                  jkandasa
                                  It is not a problem. Thank you to made this. We have to fix this one also :smile:
                                  Thanks again!
                                  • J
                                    J
                                    jkandasa
                                    Thanks again!
                                    Fixed. Yet to implement number validation in front end
                                    • R
                                      R
                                      robosensor
                                      wrote on last edited by robosensor
                                      Please also escape all information that demo user enters :) Just an example: I entered html in forecast sensor data in dashboard and this html is rendered in resources/logs section: http://demo.mycontroller.org/#/resources/logs/
                                      The same thing in node names in groups: http://demo.mycontroller.org/#/resources/groups/map/list/1
                                      • R robosensor
                                        J
                                        J
                                        jkandasa
                                        Thank you! I will fix issues!
                                        • T
                                          Tag
                                          gui is looking great!,
                                          have been playing with the software and found the following:
                                          in resources/nodes, all my nodes (mysensors 15,x) are shown as "down" while they are sending data...is this a setup issue?
                                          and for the weather forcast only N/A is shown and not the value from the sensor.....
                                          rest looks great! really like the dashboard feature!
