  3. MyController.org
  4. beta testers required for MyController 0.0.3-alpha1 release
Scheduled Pinned Locked Moved MyController.org
mycontroller.org
55 Posts 10 Posters 19.8k Views 9 Watching
  • A anarro
    When I click on "Backup" option its show this:
    Thank you,
    Antoni.
    J
    J
    jkandasa
    wrote on last edited by jkandasa
    #32
    Thank you,
    Antoni.
    Yes, you will face this issue, when MyController.org server unable to access given backup location.
    A 2 Replies Last reply
    • J jkandasa
      Thank you,
      Antoni.
      anarro
      • J jkandasa
        Thank you,
        Antoni.
        anarro
        @jkandasa said:
        Thank you,
        Antoni.
        Yes, where this option is set ?, as I fix it?
        J 1 Reply Last reply
        • A anarro
          @jkandasa said:
          Thank you,
          Antoni.
          J
          J
          jkandasa
          @anarro said:
          @jkandasa said:
          Thank you,
          Antoni.
          • A
            anarro
            Hi Sr!,
            I think it would require a button to return to the previous window in the backups, it is possible?, you think the same?
            Antoni.
            • A anarro
              Hi Sr!,
              Antoni.
              J
              J
              jkandasa
              @anarro said:
              Hi Sr!,
              Antoni.
              hi, If you click on backup menu on top. it will take you!
              A 1 Reply Last reply
              • J jkandasa
                @anarro said:
                Hi Sr!,
                Antoni.
                anarro
                @jkandasa,
                Yes, I had seen, but.. I think it was more intuitive (personal opinion.)
                • A anarro
                  @jkandasa,
                  J
                  J
                  jkandasa
                  @anarro said:
                  @jkandasa,
                  Thank you for the feedback. Ok I will add Back button.
                  • hoegaarden_bierH
                    hoegaarden_bierH
                    hoegaarden_bier
                    Some typos in English language when adding a widget:
                    Do a search on ' grpahica' => 'graphical'
                    • hoegaarden_bierH hoegaarden_bier
                      J
                      J
                      jkandasa
                      Thank you! I will fix this typo.
                      hoegaarden_bierH 1 Reply Last reply
                      • hoegaarden_bierH
                        hoegaarden_bierH
                        hoegaarden_bier
                        I noticed that when graphing data in dashboard (mixed sensors graph) for sensors that send data at different intervals (eg 1=5min;2=1min) that the graph and the interactive guide line is showing something what I think is the epoch time and the marker dots do not align (only at start of graph).
                        Turning off the checkbox ( Use intractive guide line) resolves the issue.
                        • J jkandasa
                          hoegaarden_bierH
                          hoegaarden_bierH
                          hoegaarden_bier
                          @jkandasa
                          Also here "Use intractive guide line" => "Use interactive guide line
                          • hoegaarden_bierH
                            hoegaarden_bierH
                            hoegaarden_bier
                            When sensor does not have a 'name' (resources-Sensor-sensor details) ,
                            it shows as eg. 'null-Humidity' in the dashboard (mixed sensors graph).
                            Maybe just show '-Humidity' ignore the null.
                              J
                              J
                              jkandasa
                              Yes, It's known issue with nvd3 chart plugin. For that only I gave an option to disable interactive guide
                              • J jkandasa
                                J
                                J
                                jkandasa
                                @hoegaarden_bier Thank you for your support!!
                                • hoegaarden_bierH
                                  hoegaarden_bierH
                                  hoegaarden_bier
                                  When trying to uploading a Firmware , I create a version + type , then try to upload a firmware file (eg. BLINK.ino sketch ), I get an error
                                  2016-03-01 21:43:32,002 ERROR [Acme.Utils.ThreadPool(8)-PooledThread: Acme.Serve.Serve$ServeConnection@5f12cf] [org.mycontroller.standalone.api.jaxrs.exception.mappers.ApplicationExceptionMapper:41] ApplicationException,
                                  org.jboss.resteasy.spi.ApplicationException: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                                  	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:152) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.core.ResourceMethodInvoker.invokeOnTarget(ResourceMethodInvoker.java:295) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:249) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.core.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:236) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:395) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.core.SynchronousDispatcher.invoke(SynchronousDispatcher.java:202) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.plugins.server.servlet.ServletContainerDispatcher.service(ServletContainerDispatcher.java:221) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:56) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.plugins.server.tjws.TJWSServletDispatcher.service(TJWSServletDispatcher.java:40) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.jboss.resteasy.plugins.server.servlet.HttpServletDispatcher.service(HttpServletDispatcher.java:51) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at Acme.Serve.Serve$ServeConnection.runServlet(Serve.java:2328) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at Acme.Serve.Serve$ServeConnection.parseRequest(Serve.java:2282) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at Acme.Serve.Serve$ServeConnection.run(Serve.java:2054) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at Acme.Utils$ThreadPool$PooledThread.run(Utils.java:1402) [mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at java.lang.Thread.run(Thread.java:744) [na:1.8.0]
                                  Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: 1
                                  	at java.lang.String.substring(String.java:1950) ~[na:1.8.0]
                                  	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.getFirmware(FirmwareUtils.java:75) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.updateFirmwareFromHexString(FirmwareUtils.java:50) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.mycontroller.standalone.mysensors.firmware.FirmwareUtils.createFirmware(FirmwareUtils.java:161) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at org.mycontroller.standalone.api.jaxrs.FirmwareHandler.createFirmware(FirmwareHandler.java:211) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0]
                                  	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0]
                                  	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0]
                                  	at java.lang.reflect.Method.invoke(Method.java:483) ~[na:1.8.0]
                                  	at org.jboss.resteasy.core.MethodInjectorImpl.invoke(MethodInjectorImpl.java:139) ~[mycontroller-standalone-0.0.3-alpha1-SNAPSHOT-single.jar:na]
                                  	... 15 common frames omitted
                                  This is the way it should work not?
                                    J
                                    J
                                    jkandasa
                                    #48
                                    You should upload .hex file.
                                    • J jkandasa
                                      hoegaarden_bierH
                                      hoegaarden_bierH
                                      hoegaarden_bier
                                      @jkandasa
                                      Thx, that works :)
                                      • hoegaarden_bierH
                                        hoegaarden_bierH
                                        hoegaarden_bier
                                        Question,...
                                        What makes the status of a NODE (under node details) go down?
                                          Question,...
                                          J
                                          J
                                          jkandasa
                                          #51
                                          @hoegaarden_bier
                                          Have a look at https://github.com/mycontroller-org/mycontroller/issues/27
                                          https://github.com/mysensors/Arduino/blob/f9d23c9c697ebc57d935aa4de6f47c3381a0810a/libraries/MySensors/core/MySensorCore.cpp#L241
                                          node status will be checked based on I_HEARTBEAT_RESPONSE for every 30 minutes by default. If we do not receive with in 30 minutes, will mark that node as down. MyControllor will send _HEARBEAT request to all nodes every 30 minutes once. you can change this 30 minutes as your wish. located at Settings-->System --> Node alive check interval typo :) I will fix it (Noded alive check interval)
