  3. Rain Gauge stopped sending[Solved]
10 Posts 3 Posters 2.8k Views 2 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    It was working for at least 24 hour then suddenly it stopped.
    DEBUG
    send: 24-24-6-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 24-24-6-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:6
    sensor started, id=24, parent=6, distance=2
    send: 24-24-6-0 s=255,c=3,t=11,pt=0,l=10,sg=0,st=ok:Rain Gauge
    send: 24-24-6-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.8
    send: 24-24-6-0 s=1,c=0,t=10,pt=0,l=0,sg=0,st=ok:
    send: 24-24-6-0 s=2,c=0,t=30,pt=0,l=0,sg=0,st=ok:
    Seconds row, does that mean temperature?
    Ethernet Gateway 1.5.1
    Sensor Node 1.5.1
    Repeater Node 1.5.1
    Other Sensor nodes is connected and works fine.
    This is my sketch
    // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
    #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define CHILD_ID 1                              // Id of the sensor child
    #define BATT_CHILD 2
    #define NODE_ID 24                               // or AUTO to let controller assign
    #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
    #define SKETCH_VERSION "1.8"                    // Your version
    unsigned long SLEEP_TIME = 60*60000;            // Sleep time (in milliseconds).
    //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
    float hwRainVolume = 0;                         // Current rainvolume calculated in hardware.
    int hwPulseCounter = 0;                         // Pulsecount recieved from GW
    float fullCounter = 0;                           // Counts when to send counter
    float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
    boolean pcReceived = false;                     // If we have recieved the pulscount from GW or not
    boolean reedState;                              // Current state the reedswitch is in
    boolean oldReedState;                           // Old state (last state) of the reedswitch
    unsigned long lastSend =0;                      // Time we last tried to fetch counter.
    MyMessage volumeMsg(CHILD_ID,V_RAIN);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
    // BATTERY VOLTAGE DIVIDER SETUP
    #define VBAT_PER_BITS 0.003363075
    #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
    int batteryPcnt = 0;                              // Calc value for battery %
    int batLoop = 0;                                  // Loop to help calc average
    int batArray[3];                                  // Array to store value for average calc.
    int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
    long result;
    float batteryPcnt;
    float batteryVolt;
      pinMode(6,OUTPUT);
      digitalWrite(6,HIGH);
      //analogReference(INTERNAL);             // For battery sensing
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
      reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
      oldReedState = reedState; // Set startup position for reedswitch
      delay(500); // Allow time for radio if power used as reset
      //Begin (Change if you dont want static node_id! (NODE_ID to AUTO)
      gw.begin(incomingMessage, NODE_ID, false);
      gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
      gw.present(CHILD_ID, S_RAIN);
      gw.present(BATT_CHILD, S_MULTIMETER);
      Serial.println("Startup completed");
      Serial.println("start");
      delay(100);
    gw.process();
    //gw.begin(incomingMessage, NODE_ID, false);
    unsigned long currentTime = millis();
        //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
        if (!pcReceived && (currentTime - lastSend > 5000)) {
          gw.request(CHILD_ID, V_VAR1);
          Serial.println("Request pulsecount");
          lastSend=currentTime;
          gw.process();
          return;
        if (!pcReceived) {
          return;
    //Read if the bucket tipped over
    boolean tipped = oldReedState != reedState;
        //BUCKET TIPS!
        if (tipped==true) {
        Serial.println("The bucket has tipped over...");
        hwRainVolume = hwRainVolume + bucketSize;
        gw.send(volumeMsg.set((float)hwRainVolume,1));
        gw.wait(1000);
        fullCounter = fullCounter + bucketSize;
          //Count so we send the counter for every 1mm
          if(fullCounter >= 1){
          hwPulseCounter++;
          gw.send(lastCounterMsg.set(hwPulseCounter));
          gw.wait(1000);
          fullCounter = 0;
        if (tipped==false) {
         //No bucket tipped over last sleep-period, check battery then...
         readVcc();
         Serial.println("tbx");
    Serial.println("sleep");
    digitalWrite(6,LOW);
    delay(1000);
    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
    //Read if we have a incoming message.
      if (message.type==V_VAR1) {
        hwPulseCounter = message.getULong();
        hwRainVolume = hwPulseCounter;
        pcReceived = true;
        Serial.print("Received last pulse count from gw: ");
        Serial.println(hwPulseCounter);
    void batM() //The battery calculations
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       float Vbat  = sensorValue * VBAT_PER_BITS;
       int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
       Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
       // Add it to array so we get an average of 3 (3x20min)
       batArray[batLoop] = batteryPcnt;
       if (batLoop > 1) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
         batteryPcnt = batteryPcnt / 3;
       if (batteryPcnt > 100) {
         batteryPcnt=100;
         Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
           batLoop = 0;
         //Sends 1 per hour as a heartbeat.
         else
         batLoop++;
    long readVcc() {
      Serial.println("readVcc");
      ADCSRA |= _BV(ADSC); // Convert
      while (bit_is_set(ADCSRA,ADSC));
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result; // Back-calculate AVcc in mV
      //return result;
      batteryPcnt = (result - 3300) * 0.111111;
      batteryVolt = result/1000.000;
      gw.send(battMsg.set(batteryVolt, 3));
      /*Serial.print("battery volt:");
      Serial.println(batteryVolt, 3);
      Serial.print("battery percent:");
      Serial.println(batteryPcnt);
    • F flopp
      DEBUG
      Sensor Node 1.5.1
      Repeater Node 1.5.1
      This is my sketch
      long result;
      float batteryPcnt;
      float batteryVolt;
        pinMode(6,OUTPUT);
        delay(100);
      gw.process();
            gw.process();
            return;
          if (!pcReceived) {
            return;
          //BUCKET TIPS!
          if (tipped==true) {
          gw.wait(1000);
            hwPulseCounter++;
            gw.wait(1000);
            fullCounter = 0;
           readVcc();
      delay(1000);
          pcReceived = true;
         delay(500);
         delay(500);
         if (batLoop > 1) {
           batteryPcnt=100;
             batLoop = 0;
           else
           batLoop++;
      long readVcc() {
        result = ADCL;
        result |= ADCH<<8;
        //return result;
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @flopp
      Hi!
      st=fail means radio comm problem. The second row is asking the controller for config, t=6, metric or imperial.
      Radio problems are often power related, sometimes it can also be bad piece of hardware.
      Check cables/connections.
      Try adding 4.7 uF capacitor near radio.
      Try adding two caps near radio.
      Try a different power source.
      Try another piece of radio.
      Move node closer or farther away from gateway.
      F 1 Reply Last reply
        @flopp
        Hi!
        F
        F
        flopp
        @martinhjelmare
        Thanks.
        Just before you posted this I Cleared the EEprom and upload sketch again, then it started to work.
        • F flopp
          @martinhjelmare
          Thanks.
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @flopp
          OK. Good to hear. Do you think it was a routing problem, between node and gateway?
            @flopp
            F
            F
            flopp
            @martinhjelmare
            Yes, because when i test in my house it connects to my Repeater Node, but when I place it where it shall be I don't work anymore. It happened again.
            Can you confirm that: If it connects to a repeater node first time you start it it must go through that node everytime?
            • sundberg84S
              If will self-heal and it takes some time, you need some ST:fails for it to search new parent. When it do that route is stored and next time it will send that route.
              • martinhjelmareM
                martinhjelmareM
                martinhjelmare
                Yes, I think 6 fails are needed, before searching for new route.
                • F
                  F
                  flopp
                  Now it works, without Repeater Node. I flipped the bucket a couple of times.
                  But i wonder why it didn't heal before.
                  Can it be that when the timer is waking up the Sensor Node it doesn't heal.
                  Because it has been offline for 12 hour, sleeping 1 hour each time, without healing. No rain had come during this period. Now i was flipping the bucket and it start to heal.
                  • F flopp
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @flopp
                    I think it's 6 consecutive fails that's needed before the route search, and from your first log, it seems not all messages were failing.
                      @flopp
                      F
                      F
                      flopp
                      @martinhjelmare
                      Yes, that can be the reason.
                      Thanks everyone
