Rain Gauge stopped sending[Solved]
  • It was working for at least 24 hour then suddenly it stopped.
    DEBUG
    send: 24-24-6-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 24-24-6-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:6
    sensor started, id=24, parent=6, distance=2
    send: 24-24-6-0 s=255,c=3,t=11,pt=0,l=10,sg=0,st=ok:Rain Gauge
    send: 24-24-6-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.8
    send: 24-24-6-0 s=1,c=0,t=10,pt=0,l=0,sg=0,st=ok:
    send: 24-24-6-0 s=2,c=0,t=30,pt=0,l=0,sg=0,st=ok:
    Seconds row, does that mean temperature?
    Ethernet Gateway 1.5.1
    Sensor Node 1.5.1
    Repeater Node 1.5.1
    Other Sensor nodes is connected and works fine.
    This is my sketch
    // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
    #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
    #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
    #define CHILD_ID 1                              // Id of the sensor child
    #define BATT_CHILD 2
    #define NODE_ID 24                               // or AUTO to let controller assign
    #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
    #define SKETCH_VERSION "1.8"                    // Your version
    unsigned long SLEEP_TIME = 60*60000;            // Sleep time (in milliseconds).
    //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
    float hwRainVolume = 0;                         // Current rainvolume calculated in hardware.
    int hwPulseCounter = 0;                         // Pulsecount recieved from GW
    float fullCounter = 0;                           // Counts when to send counter
    float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
    boolean pcReceived = false;                     // If we have recieved the pulscount from GW or not
    boolean reedState;                              // Current state the reedswitch is in
    boolean oldReedState;                           // Old state (last state) of the reedswitch
    unsigned long lastSend =0;                      // Time we last tried to fetch counter.
    MyMessage volumeMsg(CHILD_ID,V_RAIN);
    MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
    long result;
    float batteryPcnt;
    float batteryVolt;
      pinMode(6,OUTPUT);
      digitalWrite(6,HIGH);
      //analogReference(INTERNAL);             // For battery sensing
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
      reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
      oldReedState = reedState; // Set startup position for reedswitch
      //Begin (Change if you dont want static node_id! (NODE_ID to AUTO)
      gw.begin(incomingMessage, NODE_ID, false);
      // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
      gw.present(CHILD_ID, S_RAIN);
      gw.present(BATT_CHILD, S_MULTIMETER);
      Serial.println("Startup completed");
      Serial.println("start");
      delay(100);
    //gw.begin(incomingMessage, NODE_ID, false);
    unsigned long currentTime = millis();
        //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
        if (!pcReceived && (currentTime - lastSend > 5000)) {
          gw.request(CHILD_ID, V_VAR1);
          Serial.println("Request pulsecount");
          lastSend=currentTime;
          return;
        if (!pcReceived) {
          return;
    //Read if the bucket tipped over
    boolean tipped = oldReedState != reedState;
        //BUCKET TIPS!
        if (tipped==true) {
        Serial.println("The bucket has tipped over...");
        hwRainVolume = hwRainVolume + bucketSize;
        gw.send(volumeMsg.set((float)hwRainVolume,1));
        gw.wait(1000);
        fullCounter = fullCounter + bucketSize;
          //Count so we send the counter for every 1mm
          if(fullCounter >= 1){
          hwPulseCounter++;
          gw.send(lastCounterMsg.set(hwPulseCounter));
          gw.wait(1000);
          fullCounter = 0;
        if (tipped==false) {
         //No bucket tipped over last sleep-period, check battery then...
         readVcc();
         Serial.println("tbx");
    Serial.println("sleep");
    digitalWrite(6,LOW);
    delay(1000);
    gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
    //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
    //Read if we have a incoming message.
      if (message.type==V_VAR1) {
        hwPulseCounter = message.getULong();
        hwRainVolume = hwPulseCounter;
        pcReceived = true;
        Serial.print("Received last pulse count from gw: ");
        Serial.println(hwPulseCounter);
       delay(500);
       // Battery monitoring reading
       delay(500);
       // Calculate the battery in %
       if (batLoop > 1) {
         batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
       if (batteryPcnt > 100) {
         batteryPcnt=100;
           batLoop = 0;
         //Sends 1 per hour as a heartbeat.
         batLoop++;
    long readVcc() {
      Serial.println("readVcc");
      ADCSRA |= _BV(ADSC); // Convert
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result; // Back-calculate AVcc in mV
      //return result;
      batteryPcnt = (result - 3300) * 0.111111;
      batteryVolt = result/1000.000;
      gw.send(battMsg.set(batteryVolt, 3));
      /*Serial.print("battery volt:");
      Serial.println(batteryVolt, 3);
      Serial.print("battery percent:");
      Serial.println(batteryPcnt);
    @flopp
    Hi!
    st=fail means radio comm problem. The second row is asking the controller for config, t=6, metric or imperial.
    Radio problems are often power related, sometimes it can also be bad piece of hardware.
    Check cables/connections.
    Try adding 4.7 uF capacitor near radio.
    Try adding two caps near radio.
    Try a different power source.
    Try another piece of radio.
    Move node closer or farther away from gateway.
  • @martinhjelmare
    Just before you posted this I Cleared the EEprom and upload sketch again, then it started to work.
    @flopp
    OK. Good to hear. Do you think it was a routing problem, between node and gateway?
  • @martinhjelmare
    Yes, because when i test in my house it connects to my Repeater Node, but when I place it where it shall be I don't work anymore. It happened again.
    Can you confirm that: If it connects to a repeater node first time you start it it must go through that node everytime?
    If will self-heal and it takes some time, you need some ST:fails for it to search new parent. When it do that route is stored and next time it will send that route.
    Yes, I think 6 fails are needed, before searching for new route.
  • Now it works, without Repeater Node. I flipped the bucket a couple of times.
    But i wonder why it didn't heal before.
    Can it be that when the timer is waking up the Sensor Node it doesn't heal.
    Because it has been offline for 12 hour, sleeping 1 hour each time, without healing. No rain had come during this period. Now i was flipping the bucket and it start to heal.
    @flopp
    I think it's 6 consecutive fails that's needed before the route search, and from your first log, it seems not all messages were failing.
  • @martinhjelmare
    Yes, that can be the reason.
    Thanks everyone
