  2. Feature Requests
  3. Big Wish - a working system including up-to-date Reference
22 Posts 4 Posters 9.1k Views 5 Watching
    If you can reproduce this, It would be helpful if you could start adding debug prints in the library code to locate where it hangs to narrow down things.
    • K
      K
      kr0815
      Hello Hek,
      thank you so much to try to help me - i found the problem now and i guess it´s the same problem many others have here:
      On almost all ESP12 GPIO 4 and 5 are labeled wrong
      I didn´t use a NodeMCU, but one of the other available boards
      As the CE pin is then connected to the wrong GPIO, it seems to work, Radio init ok, but as soon as the gateway sends something, it crashes
      Here are some interesting posts about that:
      https://github.com/esp8266/Arduino/issues/437
      Maybe you should ad this notice to the build-section for the wifi gateway ?
      Best regards
      Klaus
