  2. Feature Requests
  3. 1wire – missing unique IDs (28-xxxxxxxxxxxx)
8 Posts 3 Posters 3.0k Views 4 Watching
  • tiberiusT
    tiberiusT
    tiberius
    I’ve testet the sketch “DallasTemperatureSensor.ino”. Only info I can see is temperature of each DS18B20. But I can’t see from which DS18B20 this temperature is. One importend thing of 1wire are the unique IDs. Only with these IDs I know from which senser the temperature is.
    Is it possible to include these IDs?
      You can send them using V_ID.
      tiberiusT 1 Reply Last reply
        tiberiusT
        tiberiusT
        tiberius
        @hek
        thanks for your quick answer.
        I understand: sending with V_ID. But how to get the ID? I've no idea.
        Do you have an example for me because I'm very new to mysensors.
          It's really up to the controller to pick up the id-value and show it for the temp-sensor. Not sure if all of them do that...
            Take a look in File->Sketchbook->libraries->DallasTemperature->Multiple in the Arduino IDE. There is some code to fetch the addresses.
              tiberiusT
              tiberiusT
              tiberius
              @mfalkvidd
              thats very interesting. I thought I can use only examples from MySensors-lib.
              Am I right: I use a body of a MySensors example and transform the DallasTemperature->Multiple in this body?
                Yes, that's correct.
                • tiberiusT
                  tiberiusT
                  tiberius
                  thank you all.
                  I'll try to create a working sketch.
