  2. Feature Requests
  3. 1wire – missing unique IDs (28-xxxxxxxxxxxx)
Scheduled Pinned Locked Moved Feature Requests
8 Posts 3 Posters 2.7k Views 4 Watching
  • tiberiusT Offline
    tiberiusT Offline
    tiberius
    I’ve testet the sketch “DallasTemperatureSensor.ino”. Only info I can see is temperature of each DS18B20. But I can’t see from which DS18B20 this temperature is. One importend thing of 1wire are the unique IDs. Only with these IDs I know from which senser the temperature is.
    Is it possible to include these IDs?
    • H Offline
      H Offline
      You can send them using V_ID.
      tiberiusT 1 Reply Last reply
      • H hek
        tiberiusT Offline
        tiberiusT Offline
        tiberius
        @hek
        thanks for your quick answer.
        I understand: sending with V_ID. But how to get the ID? I've no idea.
        Do you have an example for me because I'm very new to mysensors.
        • H Offline
          H Offline
          It's really up to the controller to pick up the id-value and show it for the temp-sensor. Not sure if all of them do that...
          • mfalkviddM Offline
            Take a look in File->Sketchbook->libraries->DallasTemperature->Multiple in the Arduino IDE. There is some code to fetch the addresses.
              tiberiusT Offline
              tiberiusT Offline
              tiberius
              @mfalkvidd
              thats very interesting. I thought I can use only examples from MySensors-lib.
              Am I right: I use a body of a MySensors example and transform the DallasTemperature->Multiple in this body?
                Yes, that's correct.
                • tiberiusT Offline
                  tiberiusT Offline
                  tiberius
                  thank you all.
                  I'll try to create a working sketch.
                  12.1k
