  3. Problem with Ardunio Ethernet as gateway
9 Posts 3 Posters 3.4k Views 3 Watching
  • TiasT Offline
    TiasT Offline
    Tias
    wrote on last edited by Tias
    Hi !
    Trying to make my first gateway to work with no success.
    I found out (by adding some Serial.println() statements) it fails in rf24.isPVariant().
    Output (shown by the serial monitor) from MySensors is "0;0;3;0;9;radio init fail"
    I am rather sure I have wired my NRF24L01+ wrong since the Arduino Ethernet board does not have the exact same pin markings as listen in MySenbors,org.
    (Ethernet is correctly setup since in my sketch I can ping the Arduino from my PC without problem)
    My setup : Arduino Ethernet
    Arduino IDE : 1.6.5
    OS : Windows 10 Prof.
    MySensors library version : 1.5.4
    NRF devices are clearly the Plus version, chip is marked as
    NRF M
    24L01+
    1452AB
    Wiring (based on info I found here:
    Arduino NRF24
    GND GND
    3.3V Vcc
    Digital pin 7 CE
    Digital pin 8 CSN/CS
    SCK SCK
    MOSI MOSI
    MISO MISO
    IRQ Not connected
    Changes in the EthernetGateway sketch :
    #define RADIO_CE_PIN 7 // radio chip enable
    #define RADIO_SPI_SS_PIN 8 // radio SPI serial select
    Changes in MyConfig.h :
    #define DEBUG (obviously... :) )
    #define RF24_CE_PIN 7
    #define RF24_CS_PIN 8
    const uint8_t SOFT_SPI_MISO_PIN = 12;
    const uint8_t SOFT_SPI_MOSI_PIN = 11;
    const uint8_t SOFT_SPI_SCK_PIN = 13;
    Has anyone else been successful using the Arduino Ethernet as a MySensor gateway ? If so, what am I doing wrong here... ?
    Cheers & TIA !
    /T
    F 1 Reply Last reply
    • TiasT Tias
      Hi !
      Arduino IDE : 1.6.5
      NRF M
      24L01+
      1452AB
      Arduino NRF24
      GND GND
      3.3V Vcc
      Digital pin 7 CE
      SCK SCK
      MOSI MOSI
      MISO MISO
      IRQ Not connected
      Cheers & TIA !
      /T
      F Offline
      F Offline
      flopp
      @Tias
      Hi
      I am not sure
      But for CE you wrote 7 and in sketch it is 5?
      Try to change sketch to 7.
      Same about SPI, you wrote 8 and in sketch it is 4.
      • TiasT Offline
        TiasT Offline
        Tias
        Hi !
        Sorry, I tried both version 5 & 4 and then 7 & 8) so that's why I messed it up in my post.
        It is 7 & 8 (now corrected in my OP) based on the info for the Arduino Ethernet I linked to in tho OP.
        Cheers !
        F A 2 Replies Last reply
        • TiasT Tias
          Hi !
          Cheers !
          F Offline
          F Offline
          flopp
          @Tias
          Can you please copy your sketch here
          Easier for everyone to help you, maybe it can be something with soft pins?
          TiasT 1 Reply Last reply
          • TiasT Tias
            Hi !
            Cheers !
            A Offline
            A Offline
            anibaldiniz
            @Tias
            Hi, I'am using :
            in my application
            #define RADIO_CE_PIN 5 // radio chip enable
            #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
            in MyConfig.h
            #define SOFTSPI
            #ifdef SOFTSPI
            // Define the soft SPI pins used for NRF radio
            const uint8_t SOFT_SPI_MISO_PIN =   12;          //A2
            const uint8_t SOFT_SPI_MOSI_PIN = 11;            //A1
            const uint8_t SOFT_SPI_SCK_PIN =  13;            //A0
            the connection NRF24l01 with Uno, MISO->A2
            MOSI->A1
            SCK ->A0
            CE -> D5
            CS-> D6
            • F flopp
              @Tias
              TiasT Offline
              TiasT Offline
              Tias
              @flopp
              No Problem, here's my EthernetGateway.ino and below MyConfig.h :
              EthernetGateway.ino :
              #include <MyConfig.h>
              #include <MyHw.h>
              #include <MyHwATMega328.h>
              #include <MyHwESP8266.h>
              #include <MyMessage.h>
              #include <MyParser.h>
              #include <MyParserSerial.h>
              #include <MySigning.h>
              #include <MySigningAtsha204.h>
              #include <MySigningAtsha204Soft.h>
              #include <MySigningNone.h>
              #include <MyTransport.h>
              #include <MyTransportNRF24.h>
              #include <MyTransportRFM69.h>
              #include <Version.h>
              #include <MyHw.h>
              #include <MyHw.h>
              #include <NewPing.h>
              #include <MyHw.h>
              #include <MyHw.h>
              * Version 1.0 - Henrik EKblad
              * COMPILING WIZNET (W5100) ETHERNET MODULE
              * > Edit MyConfig.h in (libraries\MySensors\) to enable softspi (remove // before "#define SOFTSPI").
              * COMPILING ENC28J60 ETHERNET MODULE
              * > Use Arduino IDE 1.5.7 (or later)
              * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
              * > Remove Ethernet.h include below and include UIPEthernet.h
              * > Remove DigitalIO include
              * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
              * VERA CONFIGURATION:
              * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
              * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
              * LED purposes:
              #define DEBUG 1
              #define NO_PORTB_PINCHANGES
              #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
              #include <stdarg.h>
              #include <PinChangeInt.h>
              #include "GatewayUtil.h"
              // Use this if you have attached a Ethernet ENC28J60 shields
              // #include <UIPEthernet.h>
              // Use this for WizNET W5100 module and Arduino Ethernet Shield
              #include <Ethernet.h>
              #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
              #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
              #define RADIO_ERROR_LED_PIN 7  // Error led pin
              #define RADIO_RX_LED_PIN    8  // Receive led pin
              #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
              MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW);
              //MyTransportRFM69 transport;
              // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
              //MySigningNone signer;
              //MySigningAtsha204Soft signer;
              //MySigningAtsha204 signer;
              // Hardware profile
              MyHwATMega328 hw;
              // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
              // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
              #ifdef WITH_LEDS_BLINKING
              MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
              #else
              MySensor gw(transport, hw /*, signer*/);
              #define IP_PORT 5003        // The port you want to open
              IPAddress myIp (192, 168, 1, 89);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
              byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x45, 0x5F };  // DEAD BEEF FEED
              // a R/W server on the port
              EthernetServer server = EthernetServer(IP_PORT);
              // handle to open connection
              EthernetClient client = EthernetClient();
              char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
              int inputPos = 0;
              bool sentReady = false;
              void output(const char *fmt, ... )
                va_list args;
                va_start (args, fmt );
                vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
                va_end (args);
                Serial.print(serialBuffer);
                server.write(serialBuffer);
               Serial.begin(115200);//MT: Without this, I don't get any debug msgs on the serial port.
               Ethernet.begin(mac, myIp);
               setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
               // Add interrupt for inclusion button to pin
               PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
               // give the Ethernet interface a second to initialize
               delay(1000);
               // Initialize gateway at maximum PA level, channel 70 and callback for write operations
               gw.begin(incomingMessage, 0, true, 0);
               // start listening for clients
               server.begin();
               gw.process();
               checkButtonTriggeredInclusion();
               checkInclusionFinished();
               // if an incoming client connects, there will be
               // bytes available to read via the client object
               EthernetClient newclient = server.available();
               // if a new client connects make sure to dispose any previous existing sockets
               if (newclient)
                   if (client != newclient)
                    client.stop();
                    client = newclient;
                    output(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                if (client)
                  if (!client.connected())
                    client.stop();
                  else if (client.available())
                    // read the bytes incoming from the client
                    char inChar = client.read();
                    if (inputPos<MAX_RECEIVE_LENGTH-1)
                      // if newline then command is complete
                      if (inChar == '\n')
                        Serial.println("Finished");
                         // a command was issued by the client
                         // we will now try to send it to the actuator
                         inputString[inputPos] = 0;
                         // echo the string to the serial port
                         Serial.print(inputString);
                         parseAndSend(gw, inputString);
                         // clear the string:
                         inputPos = 0;
                      else
                        // add it to the inputString:
                        inputString[inputPos] = inChar;
                        inputPos++;
                   else
                      // Incoming message too long. Throw away
                      inputPos = 0;
              MyConfig.h :
              #ifndef MyConfig_h
              #define MyConfig_h
              #include <stdint.h>
              // Enable debug flag for debug prints. This will add a lot to the size of the final sketch but good
              // to see what is actually is happening when developing
              #define DEBUG
              // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
              #define ENABLED_SERIAL
              // Serial output baud rate (for debug prints and serial gateway)
              #define BAUD_RATE 115200
              *  Over the air firmware updates
              // The following define enables the safe over-the-air firmware update feature
              // which requires external flash and the DualOptiBoot bootloader.
              // Note: You can still have OTA FW updates without external flash but it
              // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
              //#define MY_OTA_FIRMWARE_FEATURE
              // Slave select pin for external flash
              #define MY_OTA_FLASH_SS 8
              // Flash jdecid
              #define MY_OTA_FLASH_JDECID 0x1F65
              *  Information LEDs blinking
              // This feature enables LEDs blinking on message receive, transmit
              // or if some error occured. This was commonly used only in gateways,
              // but now can be used in any sensor node. Also the LEDs can now be
              // disabled in the gateway.
              //#define WITH_LEDS_BLINKING
              // The following setting allows you to inverse the blinking feature WITH_LEDS_BLINKING
              // When WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
              // off when blinking
              //#define WITH_LEDS_BLINKING_INVERSE
              // default LEDs blinking period in milliseconds
              #define DEFAULT_LED_BLINK_PERIOD 300
              // The RX LED default pin
              #define DEFAULT_RX_LED_PIN 6
              // The TX LED default pin
              #define DEFAULT_TX_LED_PIN 5
              // The Error LED default pin
              #define DEFAULT_ERR_LED_PIN 4
              *  Message Signing Settings
              // Disable to completly disable signing functionality in library
              //#define MY_SIGNING_FEATURE
              // Define a suitable timeout for a signature verification session
              // Consider the turnaround from a nonce being generated to a signed message being received
              // which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
              #define MY_VERIFICATION_TIMEOUT_MS 5000
              // Enable to turn on whitelisting
              // When enabled, a signing node will salt the signature with it's unique signature and nodeId.
              // The verifying node will look up the sender in a local table of trusted nodes and
              // do the corresponding salting in order to verify the signature.
              // For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
              // nodes have to implement whitelisting for this to work.
              // Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
              // to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
              // for the sender in it's whitelist)
              //#define MY_SECURE_NODE_WHITELISTING
              // MySigningAtsha204 default setting
              #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
              // MySigningAtsha204Soft default settings
              #define MY_RANDOMSEED_PIN 6 // A7 - Pin used for random generation (do not connect anything to this)
              // Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
              #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
              *  NRF24L01 Driver Defaults
              #define RF24_PA_LEVEL 	   RF24_PA_MAX
              #define RF24_PA_LEVEL_GW   RF24_PA_LOW
              // RF channel for the sensor net, 0-127
              #define RF24_CHANNEL	   76
              //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
              #define RF24_DATARATE 	   RF24_250KBPS
              // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
              #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
              // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
              #define SOFTSPI
              #ifdef SOFTSPI
              *  RFM69 Driver Defaults
              // Default network id. Use the same for all nodes that will talk to each other
              #define RFM69_NETWORKID     100
              // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
              // #define RFM69_FREQUENCY   RF69_433MHZ
              #define RFM69_FREQUENCY   RF69_868MHZ
              //#define FREQUENCY     RF69_915MHZ
              // Enable this for encryption of packets
              //#define RFM69_ENABLE_ENCRYPTION
              #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
              A 1 Reply Last reply
              • TiasT Tias
                @flopp
                #include <MyHw.h>
                #include <MyHw.h>
                #include <MyHw.h>
                #include <MyHw.h>
                #include <MyHw.h>
                * LED purposes:
                #define DEBUG 1
                #include <stdarg.h>
                // Hardware profile
                MyHwATMega328 hw;
                #else
                int inputPos = 0;
                  va_list args;
                  va_end (args);
                 delay(1000);
                 server.begin();
                 gw.process();
                 if (newclient)
                      client.stop();
                      client = newclient;
                  if (client)
                      client.stop();
                        if (inChar == '\n')
                           inputPos = 0;
                        else
                          inputPos++;
                     else
                        inputPos = 0;
                MyConfig.h :
                #ifndef MyConfig_h
                #define MyConfig_h
                #include <stdint.h>
                #define DEBUG
                // Flash jdecid
                #define SOFTSPI
                #ifdef SOFTSPI
                A Offline
                A Offline
                anibaldiniz
                @Tias
                Your Arduino is Mega?????
                • A anibaldiniz
                  @Tias
                  TiasT Offline
                  TiasT Offline
                  Tias
                  @anibaldiniz
                  Nope, it's an Arduino Ethernet (there's a link to it in my OP above).
                  • TiasT Tias
                    @anibaldiniz
                    TiasT Offline
                    TiasT Offline
                    Tias
                    @Tias
                    Right, I gave up and got an Arduino Nano to use as a Serial gateway instead.
                    It's initializing ok and entering the loop() but presents other issues, however, that's for another thread.
                    Cheers & thanks !
                    /T
                    12.1k
