  3. No triggering Door, Window and Push-button Sensor
4 Posts 2 Posters 1.5k Views 2 Watching
  • toinobcoolT
    toinobcoolT
    toinobcool
    I just build a ESP8266 GW connected to my Vera Ui7 so far so good, made a sensor Relay, perfect it worked well,
    But now when I try to build a Door, Window and Push-button Sensor i don´t get any event triggering in Vera.
    0_1456339201964_upload-35c398f6-c529-47b7-b164-1c20e1276532
    I detect the sensor correct in devices, i can see 2 devices (arduino node 4 and Arduino motion 3 (4) ) i see that arduino node 4 "Last update" changes datetime when i change the sensor pinout (button) but somehow my scene doesn´t work.
    I have a small scene where when Arduino Motion 3(4) detect motion armed or not it should turn on a Lamp but nothing happens, even in the log file from VERA i see that " Evaluate 4 scene Test Sensor is false " i always get false.
    Does nyone understands why?
    Am I missing something.
    Thank you for your help.
    Regards
    Sensor Code:
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_MOTION);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    Scene Vera:
    0_1456339302621_upload-645ca57e-7cad-450d-86ef-836122e72f7e
    Log in VERA:
    AlarmManager::AddRelativeAlarm current time 1456336378 delay 0 type 45 <0x7502e520>
    AlarmManager::AddAbsoluteAlarm alarm 0xb36dc8 entry 0xd72f60 id 322 type 45 param=(nil) entry->when: 1456336378 time: 1456336378 bCancelFirst 0=0 <0x7502e520>
    AlarmManager::Run 0xb36dc8 notified of a change entry 0x10200a0 id 312 deleted 0 <0x77a2e520>
    AlarmManager::Run callback for alarm 0xb36dc8 entry 0xd72f60 type 45 id 322 param=(nil) entry->when: 1456336378 time: 1456336378 tnum: 1 slow 0 tardy 0 <0x77a2e520>
    AlarmManager::Run finish callback for alarm 0xb36dc8 entry 0xd72f60 type 45 id 322 param=(nil) entry->when: 1456336378 time: 1456336378 tnum: 1 slow 0 duration 0 <0x77a2e520>
    AlarmManager::Run 0xb36dc8 notified of a change entry 0x110fb78 id 303 deleted 0 <0x7782e520>
    Device_Variable::m_szValue_set device: 88 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 536870913 now: 536870912 #hooks: 1 upnp: 0 skip: 1 v:0xc49ad8/NONE duplicate:0 <0x7502e520>
    UserData::m_iDataVersion_Variables_incr Tripped user data 335633001 variables 335633212 <0x7502e520>
    UserData::DataIsDirty UpdateStateList was 1 incr 0 user data 335633001 variables 335633212 <0x7502e520>
    Device_Variable::m_szValue_set device: 88 VV: 1 <0x7502e520>
    Event::Evaluate 4 scene Test Sensor is false repeat 0/-1 <0x7502e520>
    • BartEB
      BartEB
      BartE
      @toinobcool said: try sending "0" and "1" so strings i.s.o. numbers
      BTW your loop can be optimized to this:
          if (debouncer.update()) {
             gw.send(msg.set(debouncer.read() ? "1" : "0"));
      • toinobcoolT
        toinobcoolT
        toinobcool
        thnaks @BartE .
        I will give a try.
        I found some topic in the forum that there is a problem with the ESP8266 GW code.
        The Development Code fix some bugs in the gateway. Is it something related to this issue ?
        • toinobcoolT
          toinobcoolT
          toinobcool
          It is working now.
          If I have to send the value as a string and not int will it work if i send string values of temperature where it should be a int ?
          That will be my next test :)
          @BartE thank you very much for the help.
