  3. AC light dimmer with 2x TRIAC
23 Posts 7 Posters 25.0k Views 12 Watching
  • J
    J
    jacikaas
    My name is Dovydas. This is my first post in this forum. When I start to interest in MySensors and started to connect wires, I was thinking that I want to control my AC bulb remotely. I start to looking info about it and I found description in Instructables about Arduino controlled AC light dimmer: http://www.instructables.com/id/Arduino-controlled-light-dimmer-The-circuit/?ALLSTEPS
    I connect the circuit on my breadboard (on the LOAD I connect AC light bulb):
    Then I upload code to Arduino from STEP 4 in Instructables:
    AC Voltage dimmer with Zero cross detection
    Author: Charith Fernanado <a href="http://www.inmojo.com">  http://www.inmojo.com
    </a>
    Adapted by DIY_bloke
    License: Creative Commons Attribution Share-Alike 3.0 License.
    Attach the Zero cross pin of the module to Arduino External Interrupt pin
    Select the correct Interrupt # from the below table
    (the Pin numbers are digital pins, NOT physical pins:
    digital pin 2 [INT0]=physical pin 4 and digital pin 3 [INT1]= physical pin 5)
    check: <a href="http://arduino.cc/en/Reference/attachInterrupt">  http://www.inmojo.com
    </a>
    Pin    |  Interrrupt # | Arduino Platform
    2      |  0            |  All -But it is INT1 on the Leonardo
    3      |  1            |  All -But it is INT0 on the Leonardo
    18     |  5            |  Arduino Mega Only
    19     |  4            |  Arduino Mega Only
    20     |  3            |  Arduino Mega Only
    21     |  2            |  Arduino Mega Only
    0      |  0            |  Leonardo
    1      |  3            |  Leonardo
    7      |  4            |  Leonardo
    The Arduino Due has no standard interrupt pins as an iterrupt can be attached to almosty any pin.
    In the program pin 2 is chosen
    int AC_LOAD = 3;    // Output to Opto Triac pin
    int dimming = 128;  // Dimming level (0-128)  0 = ON, 128 = OFF
      pinMode(AC_LOAD, OUTPUT);// Set AC Load pin as output
      attachInterrupt(0, zero_crosss_int, RISING);  // Choose the zero cross interrupt # from the table above
    //the interrupt function must take no parameters and return nothing
    void zero_crosss_int()  //function to be fired at the zero crossing to dim the light
      // Firing angle calculation : 1 full 50Hz wave =1/50=20ms
      // Every zerocrossing thus: (50Hz)-> 10ms (1/2 Cycle)
      // For 60Hz => 8.33ms (10.000/120)
      // 10ms=10000us
      // (10000us - 10us) / 128 = 75 (Approx) For 60Hz =>65
      int dimtime = (75*dimming);    // For 60Hz =>65
      delayMicroseconds(dimtime);    // Wait till firing the TRIAC
      digitalWrite(AC_LOAD, HIGH);   // Fire the TRIAC
      delayMicroseconds(10);         // triac On propogation delay
    				 // (for 60Hz use 8.33) Some Triacs need a longer period
      digitalWrite(AC_LOAD, LOW);    // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
    void loop()  {
      for (int i=5; i <= 128; i++){
        dimming=i;
        delay(10);
    When I test it with real AC light bulb, everything working perfectly.
    Then I was looking in already made MyS examples and found "DimmableLEDActuator" example, which is theoricaly should be suitable for same AC circuit, becose A|C circuit is controled by optocoupler MOC3021. So in one side MOC3021 is connected to DC circuit and in other side is connected to AC circuit. With DimmableLEDActuator I need to control only DC circuit.
    The main step is, that I need to integrate 'interrupt function' zero_cross_int to MyS DimmableLEDActuator exampe. I was trying to do it, but becose I have no skills in programming I have no luck with it.
    So, maybe someone could help me and explain how I could merge/integrate code from Instructables STEP 4 to DimmableLEDActuator code?
    Thank You!
    • J
      J
      jacikaas
      Hello again,
      I still trying to do it on my own :)
      I combine 2 codes and I add sensor to Domoticz:
      0_1456480682628_upload-26f859f5-9d5c-4b18-92e6-5bcc2a3d5642
      It is great, that I can control it: turn on or off. But if I set dim by percentage for example 14% - my AC light bulb is fully ON, like 100% and it's flickering. It seems like zero_crosss_int function not working.
      My changed code:
       * Version 1.0 - February 15, 2014 - Bruce Lacey
       * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
       * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
       * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
       * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
       * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
       * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
       * to the LED negative terminal and the MOSFET Source pin is connected to ground.
       * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
       * http://www.mysensors.org/build/dimmer
      #define SN "DimmableLED"
      #define SV "1.1"
      #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
      #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
      #define INTERRUPT 2  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
      static int currentLevel = 0;  // Current dim level...
      MyMessage dimmerMsg(0, V_DIMMER);
      MyMessage lightMsg(0, V_LIGHT);
       * Dimmable LED initialization method
        Serial.println( SN );
        gw.begin( incomingMessage );
        pinMode(LED_PIN, OUTPUT);// Set AC Load pin as output
        attachInterrupt(INTERRUPT, zero_crosss_int, RISING);  // Choose the zero cross interrupt # from the table above
        gw.present( 0, S_DIMMER );
        gw.sendSketchInfo(SN, SV);
        // Pull the gateway's current dim level - restore light level upon sendor node power-up
        gw.request( 0, V_DIMMER );
        // 10ms=10000us
        digitalWrite(LED_PIN, HIGH);   // Fire the TRIAC
        digitalWrite(LED_PIN, LOW);    // No longer trigger the TRIAC (the next zero crossing will swith it off) TRIAC
       *  Dimmable LED main processing loop
        gw.process();
        if (message.type == V_LIGHT || message.type == V_DIMMER) {
          requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
          // Clip incoming level to valid range of 0 to 100
          Serial.print( "Changing level to " );
          Serial.print( ", from " );
          Serial.println( currentLevel );
          fadeToLevel( requestedLevel );
          gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
          // hek comment: Is this really nessesary?
          gw.send( dimmerMsg.set(currentLevel) );
       *  This method provides a graceful fade up/down effect
      void fadeToLevel( int toLevel ) {
        int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
        while ( currentLevel != toLevel ) {
          currentLevel += delta;
          analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
          delay( FADE_DELAY );
      I have add lines in DimmableLEDActuator Example:
      1. Before SETUP:
      1. In SETUP:
      1. Function zero_crosss_int:
        // 10ms=10000us
      Maybe there is some suggestions what I'm doing wrong?
      • J
        J
        jacikaas
        Hello, again :)
        It's working! Not very well, but at least its working.
        Code bellow:
        #define SV "1.1"
        //int dimming = 128;  // Dimming level (0-128)  0 = ON, 128 = OFF
        static int currentLevel = 128;  // Current dim level...
          // 10ms=10000us
          int dimtime = (75*currentLevel);    // For 60Hz =>65
          gw.process();
        What I change:
        1. Comment line: int dimming = 128;
        2. Change 0 to 128 in line: static int currentLevel = 128; // Current dim level...
        3. After some reading, change interrupt line from defined comand to just 0 (it means arduino pin 2): attachInterrupt(0, zero_crosss_int, RISING); // Choose the zero cross interrupt # from the table above
        4. In zero_crosss_int function change dimming to currentLevel: int dimtime = (75***currentLevel); // For 60Hz =>65
        Problems:
        1. When I set dim level from Domoticz - its beeing set upside down. For exampe: when I set 100% dim in Domoticz - light bulb is shining at the lowest power. When I set 7% - light bulb is shining at max power.
        2. There is no graceful dim up or dim down. When I change dim level, light bulb flicker few times until it reach dim level I set.
        Again, maybe someone knows how to fix this? :D
        Thanks!
        rvendrameR 1 Reply Last reply
        • J jacikaas
          Hello, again :)
          Code bellow:
          #define SV "1.1"
            // 10ms=10000us
            gw.process();
          What I change:
          Problems:
          Thanks!
          rvendrameR
          rvendrameR
          rvendrame
          @jacikaas
          Try changing this line (not tested):
          to
           int dimtime = (75* ( 128-currentLevel) );    // For 60Hz =>65
          Also remove this line to avoid the flicker:
          ... and finally add this line right before the "fadeToLevel( requestedLevel );" , in order to convert 0-100 range into 0-128 range:
           requestedLevel = map( requestedLevel, 0 , 100 , 0 , 128 );
          Good luck!
          ESP8266 GW + mySensors 2.3.2
          Alexa / Google Home
          J 1 Reply Last reply
          • rvendrameR rvendrame
            @jacikaas
            to
            Good luck!
            J
            J
            jacikaas
            @rvendrame
            Thank You!
            Now there leaves only problem with flickering.
            I made a video for beter understanding: https://goo.gl/photos/FPY5peSVfEsMAYvK6
            • J jacikaas
              @rvendrame
              Thank You!
              rvendrameR
              rvendrameR
              rvendrame
              @jacikaas please post your actual sketch...
              Alexa / Google Home
              • J
                J
                jacikaas
                Hey,
                #define SV "1.1"
                  // 10ms=10000us
                  int dimtime = (75* (128-currentLevel));    // For 60Hz =>65
                  gw.process();
                   // analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                • rvendrameR
                  rvendrameR
                  rvendrame
                  @jacikaas
                  You must declare variables as 'volatile' to ensure they will be updated during interrupts. Try changing:
                  into
                  volatile int currentLevel = 128;  // Current dim level...
                  And to ensure no triac firing at zero level, try something like this at beginning of zero_cross_int() (before the "int dimtime"):
                  if ( currentLevel == 0 )  return;
                  Good luck again!
                  Alexa / Google Home
                  • J
                    J
                    jacikaas
                    Thanks!
                    Now when light bulb shining in 100% and I turn it off, it graceful goes to 0% with fading.
                    When I turn it on, bulb also graceful goes to 100%, but when max power had been reached - power instantly goes to 0% and in Domoticz status leaves as ON.
                    But if I use slipper to set 100% - dim level leaves and light bulb is shining as 100%.
                    When I use slipper to set dim between 0% and 100% there still shows up flickering.
                    What about that line which one we used before:
                    Maybe this line marks the end, when ligh bulb is going up from 0% to 100%?
                    Is this possible?
                    • J jacikaas
                      Thanks!
                      Is this possible?
                      rvendrameR
                      rvendrameR
                      rvendrame
                      @jacikaas
                      The analogWrite will fire the triac based on PWM concept, and not synched to zero_cross detection, so in my opinion it would bring more problems than solutions.
                      You might be suffering from electrical problems at your zero-cross circuit. It might be not detecting all zero-crosses (or false triggering).
                      Maybe if you have a oscilloscope you could check the activity in "zero-cross signal out" pin, it should give you precisely 100 pulses in one second, if working good.
                      Another try is to change the '75' constant at dimtime calculation, try increase and/or decrease it a bit, and watch the results...
                      Alexa / Google Home
                      • J
                        J
                        jacikaas
                        @rvendrame
                        Thank You for Your help! Unfortunately I don't have oscilloscope so I can't check the signal either.
                        I will try to change dimtime constant values :)
                        Thanks!
                        • ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          wrote on last edited by ahmedadelhosni
                          I wanted to post this topic in the general discussion as I want to make a "safe" AC control circuit and wanted some ideas.
                          I have already designed this circuit 2 years ago but every while I gain some new experience. I was programming the dimmer using PIC and I was using Real Time Operating System (RTOS) + using (delay) to create an accurate timing for firing the TRIAC after the Zero crossing is detected. It worked very fine. Ofcourse using delay is bad and blocks your code.
                          Afterwards I changed my code to use time interrupts instead of RTOS, and flickering was happening sometimes.
                          I am telling you this because this may be something wrong in your coding. So this is the first issue you have to revise.
                          Second. A few months ago I found a better design in this link . It is also a dimmer circuit but I read the comments and people said that there is no choke component in the circuit. I read later and new that this means that an inductor must be added ( don't know where exactly ) but I knew later that pulsing in such circuits is not safe without a choke components. This may also cause this flicker as I have on some sites.
                          Third. I had a friend of mine who used to run his Home Automation for 3 years. He used the same simple design as you and he never reported any bad issues :) This really made me confused, as the link which I have shared above contains more componets ( capactitors + snubber circuit ) for safety, while my friend didn't add them. I have also to add that snubber circuits are needed with inductive loads only, and maybe this is way he didn't face any problem.
                          ohhh what a long reply :)
                          • J
                            J
                            jacikaas
                            Hey,
                            @ahmedadelhosni
                            Thanks for long post ;)
                            Safety is in first place. This circuit should be safer with snubber circuit, inductor and varistor. I miss something? DIAC is same purpose like varistor?
                            I look at few already made products in China. Im not realy sure about whats that in pictures, is that inductor or antenna for rf module :)
                            First smart switch from China:
                            0_1456680598953_upload-d7de8b51-9fa6-491b-8890-ba237374a0a7
                            Second smart switch from China:
                            0_1456681086581_upload-5f889d7a-2e39-488b-8099-0d7059df050c
                            Even more cheaper: Cheap smart switch
                            But theese switches are with relays.
                            @rvendrame
                            I was trying to change around dimtime constant values - and with no any good luck.
                            Today I move last modified code to Arduino Mini Pro and test it. When I test it - there was no flickering at all. Only there is same problem with:
                            I will check it and try to figure out why this is happening. :)))
                            • J jacikaas
                              Hey,
                              @ahmedadelhosni
                              @rvendrame
                              rvendrameR
                              rvendrameR
                              rvendrame
                              I saw you still using 'static int' instead 'volatile int' for currentLevel . Did you try 'volatile int' ?
                              Apart from that, I don't see any other reason for that. Perhaps something into controller side (domoticz)? I use Vera Lite with similar arduino circuit as yours, and I never had this behavior in my setup.
                              Alexa / Google Home
                              • Z
                                Z
                                Zeph
                                If I understand, sometimes when you think you should be seeing 100%, the light is actually off?
                                You are counting on the triac to latch and hold until the next Zero Crossing. However a triac needs a certain level of current in order to latch. If you try to trigger it too early in the AC cycle (while the AC voltage is still close to zero, just starting to rise), the load may not provide enough current to latch the triac. This is especially true with some kinds of loads. For example, LED Xmas lisghts don't conduct until the AC instantaneous voltage rises above the combined Vfwd of 25-50 series LEDs.
                                One way to test this hypothesis is to lengthen the pulse. Or you could adjust your timing multiplier.
                                • J
                                  J
                                  jemish
                                  Can we control AC fan using this module???
                                  • OitzuO
                                    OitzuO
                                    Oitzu
                                    @jemish which module do you mean exactly?
                                    The schematic in the first post is not suitable for inductive loads.
                                    • OitzuO Oitzu
                                      J
                                      J
                                      jemish
                                      @Oitzu okk my friend, thank you so much.
                                      But is there any design available for controlling inductive load???
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        @jemish maybe have a look at following blog-post: http://www.homemade-circuits.com/2012/04/how-to-use-triacs-for-inductive-loads.html
                                        With this information you should be able to "improve" above schematic to be also able to handle inductive loads.
                                        If you have no clue about all that... maybe have a look at this module:
                                        https://www.kemo-electronic.de/en/Light-Sound/Effects/Modules/M028-Power-control-110-240-V-AC-2600-VA.php
                                        It can control AC Motors,
                                        in combination with this module:
                                        https://www.kemo-electronic.de/en/Transformer-Dimmer/Converter/M150-DC-pulse-converter.php
                                        You can connect it safely to the arduino.
                                        ahmedadelhosniA 1 Reply Last reply
                                        • OitzuO Oitzu
                                          ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          @Oitzu i cant find the price of them on the site. Are they listed ?
