  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • S Samuel235
    @alexsh1 If you haven't touched the ATmega328p then it should be sitting with fuses of; L:0x62 H:0xD9 E:0xFF, which would run the uC at 1MHz
    alexsh1A
    alexsh1A
    alexsh1
    @samuel235 This is strange. The serial monitor was working only on 74880 - I do not think the AVR was running @ 1Mhz
    • alexsh1A
      alexsh1A
      alexsh1
      #42
      @GertSanders Thanks for a detailed write-up!
      @GertSanders said:
      You can also use an external 8 mhz crystal, and combine this with clock division by 8 to get 1mhz operation.
      And you can choose an external 1mhz crystal.
      How is this influencing low power though? My understanding is that such setup (external crystal) takes more power.
      • alexsh1A alexsh1
        GertSandersG
        GertSandersG
        GertSanders
        @alexsh1
        Using a 1mhz crystal would not be the best thing for low power use, you are correct there.
        But it gives a more accurate clock base for the timing functions.
        • alexsh1A
          alexsh1A
          alexsh1
          Not sure what happened, but the following error returned:
          Board atmega328p:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
          Board atmega328p:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
          I did not change anything so very strange why it comes up.
          • S
            Samuel235
            Actually, i have no proof but i've been informed from the arduino standalone microcontroller forums, that using a external 8mhz crystal is good for power consumption. ONLY if its a sleeping module though, it enables it to perform its tasks quicker and then sleep quicker, resulting in more time sleeping.
            That error code is something i ran into, i'm guessing you're working inside of arduino IDE, if so its to do with your boards.txt entry. Its missing that entry that it speak about. Check that its there, if not enter it in manually.
            MySensors 2.1.1
            alexsh1A 1 Reply Last reply
            • S Samuel235
              alexsh1A
              alexsh1A
              alexsh1
              #46
              @samuel235
              Thanks - yes you are right it is about boards.txt.
              However, the problem is that I did not change anything. Two days ago I uploaded severa sketches and no errors were coming up and now two different boards are showing the same error. This is just odd...
              S 1 Reply Last reply
              • alexsh1A alexsh1
                @samuel235
                Samuel235
                @alexsh1, have you performed an Arduino IDE update? I had this exact issue simply because I updated my IDE.
                MySensors 2.1.1
                • GertSandersG
                  GertSandersG
                  GertSanders
                  wrote on last edited by GertSanders
                  #48
                  This message pops up since IDE 1.6.7
                  The new IDE expects this entry for all boards, just add it or ignore (it's more a warning then an error).
                  carlierdC 1 Reply Last reply
                  • S
                    Samuel235
                    And there you go, the forever informative @GertSanders has andwered your questioning ;)
                    MySensors 2.1.1
                    • S Samuel235
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @samuel235 Looks like you are right - without realising I did press update button thinking about a sketch rather than about the update :(
                      Corrected this issue aleady in the boards.txt
                      • GertSandersG GertSanders
                        carlierdC
                        carlierdC
                        carlierd
                        @GertSanders Hello ! I am trying to upload a sketch without success for the moment.
                        Burning of the bootloader was done correctly (led on pin 8 lit three times) but impossible to load a sketch.
                        For easy deployment I choose to create a new folder to include your bootloaders:
                        But it seems that something is missing as upload is not possible:
                        Le croquis utilise 1 030 octets (3%) de l'espace de stockage de programmes. Le maximum est de 32 256 octets.
                        Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2 039 octets pour les variables locales. Le maximum est de 2 048 octets.
                        /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1411 -b38400 -D -Uflash:w:/var/folders/2y/_n7gfzjx5_sgmtyh9t_lp0wc0000gn/T/build8919458311701309495.tmp/Blink.cpp.hex:i
                        avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
                                 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                 Copyright (c) 2007-2009 Joerg Wunsch
                                 System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
                                 User configuration file is "/Users/carlierd/.avrduderc"
                                 User configuration file does not exist or is not a regular file, skipping
                                 Using Port                    : /dev/cu.usbmodem1411
                                 Using Programmer              : arduino
                                 Overriding Baud Rate          : 38400
                        avrdude: ser_open(): can't open device "/dev/cu.usbmodem1411": No such file or directory
                        ioctl("TIOCMGET"): Inappropriate ioctl for device
                        avrdude done.  Thank you.
                        Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
                        Any suggestion ?
                        David.
                        • carlierdC carlierd
                          Any suggestion ?
                          David.
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @carlierd
                          I am almost certain that you are NOT using my boards.txt because you put the bootloaders outside the reach of the IDE (must be in the sketchfolder and within the hardware subfolder of the sketches folder).
                          carlierdC 2 Replies Last reply
                            @carlierd
                            carlierdC
                            carlierdC
                            carlierd
                            @GertSanders
                            No doubt that I using your file as I got the same problem as @alexsh1 with the arduino pin file.
                            Look at my board choice:
                            I find this method very good for deployment but only when it's working ;)
                            I check the bootloader with Nick Gammon sketch and it seems good.
                            David.
                            • carlierdC
                              carlierdC
                              carlierd
                              I burn the bootloader one more time and now I can upload without any change on configuration.
                              Perhaps I made a mistake the first time :)
                              I will continue my test.
                              David.
                                @carlierd
                                carlierdC
                                carlierdC
                                carlierd
                                @GertSanders One more question on the LED connected on B0.
                                When you wrote that the LED lit on arduino reset, it's when the reset button is pushed ? when the arduino start ? or both ?
                                David.
                                  David.
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  #56
                                  @carlierd
                                  When the atmega328 is reset, the LED will flash three times if the boot loader is in memory. This also happens when you send a new sketch via the Arduino IDE to the atmega328.
                                  So if you connect pin 1 shortly to GND, the led should flash.
                                  The first time you load a boot loader, the atmega328 will "loop" between the startup procedure of the boot loader (and will flash the led), and then try to load the sketch. If there never is a sketch, it will start the boot loader again and again ...
                                    @carlierd
                                    carlierdC
                                    carlierdC
                                    carlierd
                                    @GertSanders
                                    So it confirms that your bootloader was correctly burnt in the atmega as the first time I failed to upload a sketch the LED flash three time again and again !
                                    Thanks !
                                    David.
                                    • carlierdC
                                      carlierdC
                                      carlierd
                                      I tested two bootloaders today:
                                      • optiboot_atmega328_08M_038400_B0.hex
                                      • optiboot_atmega328_01M_009600_B0.hex
                                      But I am pretty sure you already tested them.
                                      I got some issue with 1MHz bootloader but probably because I am using signing feature.
                                      I will check the forum to be sure.
                                      David.
                                        David.
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @carlierd
                                        Indeed I am using these two boot loaders already. The 1Mhz in my very slim nodes and the 8Mhz in the red board battery based nodes.
                                        I also use the 16Mhz in my AC based board (as a repeater or as SMS gateway).
                                        I will make an AC board with a 20Mhz crystal just to test the faster versions of the bootloader.
                                          @carlierd
                                          carlierdC
                                          carlierdC
                                          carlierd
                                          @GertSanders
                                          Hello, as I got some issue with the 1MHz bootloader, I tried without the signing feature and I still got st=fail.
                                          One question for you, perhaps stupid but I need to be sure ;)
                                          Do you need to set the same serial speed on both node and gateway ?
                                          David.
