  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.6k Views 18 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62
    • GertSandersG
      GertSandersG
      GertSanders
      If anyone uses the bootloaders, please leave a message here with your experience. It would be nice to know which one of the bootloaders are effectively used.
      I know some combinations of CPU clock and upload speed do not make sense, so those will be removed. But for the moment I leave them in the project.
      I have succes with the following versions:
      Used on the very narrow board:
      optiboot_atmega328_08M_038400_B0.hex (on V 1-0)
      optiboot_atmega328_08M_038400_D6.hex (on V 1-1)
      Used on my AC based board:
      optiboot_atmega328_16M_057600_B0.hex
      • carlierdC
        carlierdC
        carlierd
        I will start some test on bootloader impact on battery so the timing is perfect !
        One very useful thing to add in your project could be fuse settings and IDE board files ?
        David.
        • carlierdC carlierd
          David.
          GertSandersG
          GertSandersG
          GertSanders
          wrote on last edited by GertSanders
          @carlierd
          I can probably package this in a directory structure you could add to the Hardware folder in the Arduino files, but I do not have the time for it right now. I know that has been done for the original Optiboot 6.2 files already (including a pinout file for the various processor variants):
          https://github.com/Optiboot/optiboot
          For the moment I have added my boards.txt file as I use it in my Arduino IDE (common), it shows some fuse settings, but you are right: a document describing the fuse settings to use, and their effect on a bootloader would be a nice reference for many people.
          A 1 Reply Last reply
          • carlierdC
            carlierdC
            carlierd
            I will try some bootloader so I will be able to give you some fuse settings I have tested to.
            One more question, what B0 means ? I understood it's the pin for the LED ? Why B ? It's not D0 for digital 0 ?
            David.
              David.
              GertSandersG
              GertSandersG
              GertSanders
              @carlierd
              "B0" is the Port B - pin 0 as is the terminology in AVR compiler ("port pins"). It is the parameter I need to add to GCC compiler to be able to use that pin.
              In Arduino IDE terms this is digital arduino pin nr 8. On the DIL version of the chip it is physical pin nr 14. The Arduino IDE makes abstraction of the port pins, by designating numbers to the pins of various ports. The relation between the two can be found in the file "pins_arduino.h", which is stored in a subdirectory "variants". This allows the IDE to use the same number of "pin" for different versions of boards and processors.
              In this file you will find (for the "standard" Arduino Uno the following comments:
              // ATMEL ATMEGA8 & 168 / ARDUINO
              //            PC6  1|    |28  PC5 (AI 5)
              //      (D 0) PD0  2|    |27  PC4 (AI 4)
              //      (D 1) PD1  3|    |26  PC3 (AI 3)
              //      (D 2) PD2  4|    |25  PC2 (AI 2)
              // PWM+ (D 3) PD3  5|    |24  PC1 (AI 1)
              //      (D 4) PD4  6|    |23  PC0 (AI 0)
              //            VCC  7|    |22  GND
              //            GND  8|    |21  AREF
              //            PB6  9|    |20  AVCC
              //            PB7 10|    |19  PB5 (D 13)
              // PWM+ (D 5) PD5 11|    |18  PB4 (D 12)
              // PWM+ (D 6) PD6 12|    |17  PB3 (D 11) PWM
              //      (D 7) PD7 13|    |16  PB2 (D 10) PWM
              //      (D 8) PB0 14|    |15  PB1 (D 9) PWM
              // (PWM+ indicates the additional PWM pins on the ATmega168.)
              In the diagram below you see the relation between IDE, physical and ATMEL definition of the pins for the DIL variant.
              In this diagram below you see the CPU variant used on the Pro Mini. Port B, pin 0 is here physical pin 12, but for Arduino IDE this is still digital pin number 8:
              carlierdC 1 Reply Last reply
              • bjacobseB
                bjacobseB
                bjacobse
                will there be an "Arduino Pro Mini" (Using external 8MHz scaled to 1MHz="X8M1") with LED B5 blink -> optiboot_atmega328_X8M1_057600_B5.hex avialable? preferable with BOD=disabled or set to 1,8v
                • GertSandersG GertSanders
                  @carlierd
                  //            VCC  7|    |22  GND
                  //            GND  8|    |21  AREF
                  //            PB6  9|    |20  AVCC
                  carlierdC
                  carlierdC
                  carlierd
                  @GertSanders Perfect !!!
                  • bjacobseB bjacobse
                    GertSandersG
                    GertSandersG
                    GertSanders
                    @bjacobse
                    Try this one.
                    0_1457034725597_optiboot_atmega328_X8M1_057600_B5.hex
                    I doubt uploading will work since 57600baud for a 1MHz device will generate around 8% error, which is way above the 2% AVRDUDE tolerates (I think). For the error calculation see below (WormFood's...)
                    But test it. I may be wrong.
                    I will make a 4800 baud version if you want later.
                    The BOD setting is something independent of the boot loader, you choose this with the fuses.
                    This boot loader expects to run at 1MHz, so you can either choose the internal 8MHz oscillator or a crystal at 8Mhz and set the fuses for clock division by 8. The clockdivision is also decided via the fuses and independent of the boot loader itself.
                    There are only a few things that are important to a boot loader as far as I know:
                    Frequency of the cpu needs to be known at compile time, so that functions like wait() and delay() have an exact time reference (meaning that wait(1000) take 1 second and not some other duration).
                    Speed of the expected uploads also needs to be known, so that it can match the speed used to upload sketches. Not all combinations of cpu frequency and upload speed are possible. Some combinations have too much error. Google the "WormFood's AVR Baud Rate Calculator" and you will find info on this.
                    In the boards.txt file of the Arduino IDE you need to match the cpu and upload frequency.
                    The fact that a LED needs to flash also needs to be known when compiling the boot loader (it's a parameter
                    This is how I started the make tool for Optiboot compilation for your bootloader:
                    make atmega328 BAUD_RATE=57600 AVR_FREQ=1000000L LED_START_FLASHES=3 LED=B5
                    Fuse settings:
                    For Clock division by 8
                    Internal 8Mhz oscillator
                    BOD at 1.8V:
                    Low: 0x62
                    High: 0xDF
                    Extended: 0xFE (or 06 in the boards.txt)
                    External Full Swing 8Mhz crystal
                    BOD at 1.8V:
                    Low: 0x77
                    High: 0xDF
                    For No BOD at all, Low and High fuses stay the same, only the Extended fuse changes:
                    Extended: 0xFF (or 07 in the boards.txt)
                    Let me know if you can get it to work.
                    • bjacobseB
                      bjacobseB
                      bjacobse
                      I tried to compile as you write that my baudrate was unrealistic high. to get a 4800 baudrate hexfile
                      I downloaded from github optiboot, and tried your compile settings, but get an AVR_FREQ error. I can understand that the AVR_FREQ isn't correctly taken as input from the commandline ans used by the makefile
                      I'm on Ubuntu Linux
                      /media/bjacobse/documents/Downloads/optiboot-master/optiboot/bootloaders/optiboot$ make atmega328 BAUD_RATE=4800 AVR_FREQ=1000000L LED_FLASHES=3 LED=B5
                      avr-gcc (GCC) 4.8.2
                      Copyright (C) 2013 Free Software Foundation, Inc.
                      This is free software; see the source for copying conditions. There is NO
                      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                      avr-gcc: error: 000L: No such file or directory
                      make: [baudcheck] Error 1 (ignored)
                      baudcheck.tmp.sh: line 17: ( (H�00 + 4800 * 4) / ((4800 * 8))) - 1 : syntax error: invalid arithmetic operator (error token is "�00 + 4800 * 4) / ((4800 * 8))) - 1 ")
                      baudcheck.tmp.sh: line 25: (H�00/(8 * (()+1))) : syntax error: invalid arithmetic operator (error token is "�00/(8 * (()+1))) ")
                      BAUD RATE CHECK: Desired: 4800, Real: , UBRRL = , Error=-100.0%
                      avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=atmega328p -DF_CPU=HW� 000L -DBAUD_RATE=4800 -DLED_START_FLASHES=3 -DLED=B5 -c -o optiboot.o optiboot.c
                      make: *** [optiboot.o] Error 1
                      GertSandersG 2 Replies Last reply
                        I'm on Ubuntu Linux
                        avr-gcc (GCC) 4.8.2
                        GertSandersG
                        GertSandersG
                        GertSanders
                        @bjacobse
                        You can not just compile on linux. The make file needs to be adapted to your setup. I compile my bootloaders on a Mac within a virtual machine running WinAVR version 2010 (oktober).
                        Tomorrow I will make a 4800 baud version. The 9600 baud 1Mhz should work as well, but the errorrate for uploads will be higher. Seems acceptable on some peoples boards.
                          I'm on Ubuntu Linux
                          avr-gcc (GCC) 4.8.2
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @bjacobse
                          Here is a 4800 baud version.
                          0_1457256109633_optiboot_atmega328_X8M1_004800_B5.hex
                          bjacobseB 1 Reply Last reply
                            @bjacobse
                            bjacobseB
                            bjacobseB
                            bjacobse
                            @GertSanders
                            Thank you for the file, however I have some troubles, I can flash via USBtiny but I am not able to upload sketch via Arduino IDE+ FTDI,
                            will you check my settings are correct?
                            Here is my boards.txt file for the optiboot
                            pro328opti.name=BJa BOD 1,8V Optiboot, Arduino Pro Mini (3.3V, 8 MHz) w/ ATmega328
                            pro328opti.upload.protocol=arduino
                            pro328opti.upload.maximum_size=30720
                            pro328opti.upload.speed=4800
                            pro328opti.bootloader.low_fuses=0x77
                            pro328opti.bootloader.high_fuses=0xDF
                            pro328opti.bootloader.extended_fuses=0x06
                            pro328opti.bootloader.path=optiboot
                            pro328opti.bootloader.file=1457256062840-optiboot_atmega328_x8m1_004800_b5.hex
                            pro328opti.bootloader.unlock_bits=0x3F
                            pro328opti.bootloader.lock_bits=0x0F
                            pro328opti.build.mcu=atmega328p
                            pro328opti.build.f_cpu=8000000L
                            pro328opti.build.core=arduino
                            pro328opti.build.variant=standard
                              @GertSanders
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @bjacobse
                              As you use the clock divider, you should inform the Arduino IDE that the processor is running slower.
                              So you need to set this:
                              pro328opti.build.f_cpu=1000000L
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Sounds like good idea :-) Thanks
                                now the board.tx file is updated: pro328opti.build.f_cpu=1000000L
                                restart Arduino, but still get upload errors
                                Error messages:
                                Binary sketch size: 1,102 bytes (of a 30,720 byte maximum)
                                avrdude: stk500_recv(): programmer is not responding
                                avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                                I feel it's an unlucky Sunday... Can you provide more ideas what I can do?
                                  Error messages:
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @bjacobse
                                  Not sure, but an out of sync message is usually because of a mismatch in speed between what the IDE en avrdude expect, and what the cpu does.
                                  So I would check the fuses of the cpu to be sure. I will try this boot loader on one of my nodes to see if the boot loader itself is the problem.
                                  • alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @GertSanders I installed your compiled bootloaders - thanks for compiling them, but I cannot compile a Blink sketch using 1Mhz internal one
                                    Board GertSanders:avr:atmega328pO5M16c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M16C
                                    Board GertSanders:avr:atmega328pO5M8c doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328PO5M8C
                                    Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
                                    WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
                                    Build options changed, rebuilding all
                                    In file included from sketch\Blink.ino.cpp:1:0:
                                    C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:249:26: fatal error: pins_arduino.h: No such file or directory
                                    #include "pins_arduino.h"
                                    compilation terminated.
                                    exit status 1
                                    Error compiling.```
                                    • alexsh1A alexsh1
                                      exit status 1
                                      Error compiling.```
                                      GertSandersG
                                      GertSandersG
                                      GertSanders
                                      @alexsh1
                                      My boards.txt file is pointing to a location you are not using.
                                      You have your library in a different place then I.
                                      You should make sure that the directory in which you put the variant matches with what you have. I can not know which directory you put the Arduino IDE, so matching this is an exercise for you ;-)
                                      In my case, my variants boards is here:
                                      \Dropbox\Arduino\hardware\atmega328p\avr\variants\BlueBoard\pins_arduino.h
                                      This is matched with the fact that my boards file is here:
                                      \Dropbox\Arduino\hardware\atmega328p\avr\boards.txt
                                      Within the boards.txt file, I'm referring to the following variant: "BlueBoard". This is done here:
                                      BlueBoard.build.core=arduino:arduino
                                      BlueBoard.build.mcu=atmega328p
                                      BlueBoard.build.board=AVR_GERTSANDERSBLUEBOARD
                                      BlueBoard.build.variant=BlueBoard
                                      You seem to have a different path:
                                      I'm not sure where you added my files or boards.txt, but do not just copy it. You need to adapt your boards.txt file.
                                      My "hardware" directory is within the Arduino sketch directory and contains this:
                                      All my boot loaders are in directory "bootloaders\myoptiboot":
                                      the file pins_arduino.h is a pins layout file for a standard atmega328p (copied from the "standard" variant directory.
                                      If you have a pro micro with the flat atmega328p, you need to use the "eightanaloginputs" variant.
                                      This is what it looks like in my Arduino IDE installation directory:
                                      alexsh1A 1 Reply Last reply
                                        @alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        That's what I did - I adopted your boards.txt
                                        All my bootloaders are in the hardware directory (C:\Users\Alex\Documents\Arduino\hardware). The hardware directory is located together with all my sketches in the Arduino directory. Now, for whatever reason, the error is point out to the completely different location:
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @GertSanders OK, I sorted it out.
                                          I had to create "BlueBoard" and "standard" under "variants" and copy two corresponding files pins_arduino.h
                                          At least I can compile now.
                                          Will try to upload a sketch later on and see if it works.
