  3. Ultrasonic essential Oil diffuser
11 Posts 7 Posters 10.1k Views 11 Watching
  • fifipil909F
    fifipil909F
    fifipil909
    wrote on last edited by fifipil909
    my wife like to use essential oil in the house, but basic humidifier use a lot of water and increase the ambiant humidity in the room.
    I notice also that the smell of the oil is not really intense.
    So the idea, modify a cheap ultrasonic humidifier and create an oil diffuser without dealing with water.
    The start, a cheap Donut humidifier 6$ on ebay.
    http://www.ebay.com/itm/Donut-Shaped-Ultrasonic-USB-Humidifier-Air-Essential-Oil-Purifier-Aroma-Diffuser-/301652283655?hash=item463be09107:g:vrwAAOSwBahVbrHo
    then, I decide to build a wood enclosure with a removable top for easy oil bottle changing and put everything together.
    The top is maintain by 2 small magnet, and the ceramic caps just touch the top of the Bottle wick.
    Regarding the Sketch, Its like a dimmer, V_status for the On/Off state, V_percentage for the frequency.
    // INCLUDE
    #include <Time.h>
    // OPTION
    #define DEBUG
    #define MIN_DELAY  10
    #define MAX_DELAY  90
    bool  Diffuser_status;
    uint8_t   Diffuser_Freq;
    int delaytowait;
    unsigned long lastUpdate;
    int nbseconds = 0;
    // CHILD ID
    #define CHILD_ID_DIFFUSER 0
    // PIN DEF
    #define DIFFUSER_PIN A3
    // VAR
    // Messsage Settings
    MyMessage IntensityMsg(CHILD_ID_DIFFUSER, V_PERCENTAGE);
    MyMessage StatusMsg(CHILD_ID_DIFFUSER, V_STATUS);
      gw.begin(incomingMessage, AUTO, false);
      pinMode(DIFFUSER_PIN, OUTPUT);
      digitalWrite(DIFFUSER_PIN, HIGH);
      // Info
      gw.sendSketchInfo("Difuser", "1.0");
      // Send Presentation
      gw.present( CHILD_ID_DIFFUSER, S_DIMMER );
      Diffuser_status = gw.loadState(5);
      Diffuser_Freq = gw.loadState(8);
      gw.send(StatusMsg.set(Diffuser_status ? true : false), true);
      gw.wait(200);
      gw.send(IntensityMsg.set(Diffuser_Freq),true);
      unsigned long now = millis();
      gw.process();
      if (now - lastUpdate > 1000) {
        nbseconds++;
        lastUpdate = now;
      float delaytowaittmp = ((MAX_DELAY - MIN_DELAY) / 100.0) * Diffuser_Freq;
      int delaytowait = delaytowaittmp;
      if ((Diffuser_status == true) && (nbseconds > delaytowait)) {
        digitalWrite(DIFFUSER_PIN, LOW);
        delay(100);
        delay(100);
        delay(100);
        delay(100);
        nbseconds = 0;
      }else if(nbseconds > delaytowait)
        nbseconds = 0;
      if (message.type == V_STATUS || message.type == V_PERCENTAGE) {
        int req_status = -1;
        int req_percentage = -1;
        if (message.type == V_STATUS)
          req_status = message.getBool();
          Diffuser_status = req_status;
          gw.saveState(5, Diffuser_status);
        if (message.type == V_PERCENTAGE)
          req_percentage = message.getByte();
          Diffuser_Freq = req_percentage;
          gw.saveState(8, Diffuser_Freq);
    Now, you can have good smell in every room for some dollars when you arrived from work, when you start cooking, when going to sleep or entering in your Bat Cave !
      Wow, I didn't see that actuator coming. :)
        MikeF
        ...think we need a new sensor type: V_ESSENTIAL_OIL_DIFFUSER :laughing:
        • greglG
          greglG
          gregl
          @fifipil909 That's outstanding work!
          I never knew these ultrasonic essential oil diffusers existed.
          for version 2 you need to add a sensor for when the oil is depleted!
          What sort of current does the ultrasonic humidifier demand?
          • tripyT
            tripyT
            tripy
            The enclosure is very nice too.
            Hand made ?
            • fifipil909F
              fifipil909F
              fifipil909
              @gregl yes, I think about add a level indication by using a simple ldr and a led, shouldn't be complicated to archeve.
              regarding the ceramic caps, a lot of them you can find on ebay use 40 Vac at 1.6Mhz. so not so easy and finding a 8:1 transformer working at this frequency to make a small DC to AC converter is not that easy.
              after some search, I find some other caps like exactly the same there is on this "donut" humidifer. they are working at a much low frequency, 113khz to be exact.
              http://fr.aliexpress.com/item/20mm-113KHz-ultrasonic-atomizer-transducer-atomizing-part/32273063940.html?spm=2114.44010308.4.177.0Amsoy
              Regarding the voltage, I found some caps working at 5vpp but the donut caps seems to working arround 50v.
              I don't have any idea how they boost the voltage to that pick.
              here is some scope:
              Mofset Gate :
              Caps input:
              the sinus wave it's really durty, but seems to be enough to vibrate the caps.
              donut IC :
              if someone have some idea of what is this black component on the right side. seems to be the one that boost the voltage up to 60v.
              @tripy yes everything handmade. my friend carpenter help me to glue together some piece of wood plate like this : http://planete-bois.com/plans-de-travail/28-plan-de-travail-chene-lamelle-colle-aboute.html I manage the rest with a router and a drill press.
              AWIA 1 Reply Last reply
              • greglG
                greglG
                gregl
                "what is this black component on the right side"
                id say its a simple transformer. how many leads go into it? ( photos a bit blurry )
                • fifipil909F fifipil909
                  here is some scope:
                  Mofset Gate :
                  Caps input:
                  donut IC :
                  AWIA
                  AWIA
                  AWI
                  @fifipil909 I assume the black component is a coil. There are many simple circuits which can generate a high voltage with a coil/ transformer or capacitors and diodes.
                  0_1456991504666_upload-5eaa06af-25c0-46e1-8e68-4a66872cecf1 Some noisy examples
                  • fifipil909F
                    fifipil909F
                    fifipil909
                    There is 3 leads.
                    I did try to make better pic.
                    • lucyheartL
                      lucyheartL
                      lucyheart
                      Wow... you're resourceful persion. i want build this but it difficult for me :D
                      • fifipil909F
                        fifipil909F
                        fifipil909
                        It's hard to say right now.
                        It can be interesting to know how do you control the On/Off.
                        Those Ceramic caps don't like to be used without any liquid and can be damaged very quickly if there are dry.
                        But normally there is a build in switch off circuit if no liquid is detected.
                        Can you tell me more how to you modify the electronic to control it with Mysensors ?
