  3. Home Assistant
  4. Problem with S_RGB_LIGHT
10 Posts 2 Posters 4.5k Views 2 Watching
  • D
    D
    danivalencia
    Hi all.
    I'm trying to set up a test sensor, with a RGB Led attached to a Nano/NRF sensor.
    For now what I have is this code borrowed from the domoticz forum, but the light doesn't show on the UI.
    Any help apreciated (and sorry for my english :wink: )
    #define RED_PIN 3
    #define GREEN_PIN 5
    #define BLUE_PIN 6
    #define NODE_ID 2
    #define CHILD_ID 0
    #define SKETCH_NAME "RGB_STRIP"
    #define SKETCH_VERSION "1.0.0"
    #define NODE_REPEAT false
    long RGB_values[3] = {0, 0, 0};
    float dimmer;
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      gw.begin(incomingMessage, NODE_ID, NODE_REPEAT);
      gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
      gw.present(CHILD_ID, S_RGB_LIGHT, "RGB Strip", false);
      gw.request(CHILD_ID, V_RGB);
      gw.process();
      if (message.type == V_RGB) {
        String hexstring = message.getString();
        long number = (long) strtol( &hexstring[0], NULL, 16);
        RGB_values[0] = number >> 16;
        RGB_values[1] = number >> 8 & 0xFF;
        RGB_values[2] = number & 0xFF;
      if (message.type == V_DIMMER) {
        dimmer = message.getInt();
        analogWrite(RED_PIN, int(RGB_values[0] * (dimmer / 100)));
        analogWrite(GREEN_PIN, int(RGB_values[1] * (dimmer / 100)));
        analogWrite(BLUE_PIN, int(RGB_values[2] * (dimmer / 100)));
        if (message.getInt() == 0) {
          digitalWrite(RED_PIN, 0);
          digitalWrite(GREEN_PIN, 0);
          digitalWrite(BLUE_PIN, 0);
        if (message.getInt() == 1) {
    • D danivalencia
      Hi all.
      #define RED_PIN 3
      #define GREEN_PIN 5
      #define BLUE_PIN 6
      #define NODE_ID 2
      #define CHILD_ID 0
      float dimmer;
        gw.process();
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @danivalencia
      Hi!
      You're not sending any initial values for each of the V_TYPES you want to use, in the end of setup. Have you read the instructions here?
      https://home-assistant.io/components/mysensors/#presentation
      Since you want to use V_RGB, V_DIMMER and V_LIGHT, you should populate all three data types. The device will show in the GUI, once you have at least populated the corresponding V_TYPE per S_TYPE that you present per sensor. In this case that's V_RGB corresponding to S_RGB_LIGHT.
      See also https://home-assistant.io/components/light.mysensors/
      D 1 Reply Last reply
        @danivalencia
        Hi!
        D
        D
        danivalencia
        @martinhjelmare
        Thanks!
        I think I figured out the solution, but not yet fixed at all.
        I presented the three V_ types, and sent a value for each all. But now I'm dealing with the ON/OFF "order" for the light. It doesn't respond to the switch at the UI.
        #define RED_PIN 3
        #define GREEN_PIN 5
        #define BLUE_PIN 6
        #define NODE_ID 2
        #define CHILD_ID 0
        #define SKETCH_NAME "RGB_LED"
        #define SKETCH_VERSION "1.0"
        MyMessage msgBright(CHILD_ID, V_PERCENTAGE);
        MyMessage msgColor(CHILD_ID, V_RGB);
        MyMessage msgLight(CHILD_ID, V_LIGHT);
        float dimmer;
         gw.present(CHILD_ID, S_RGB_LIGHT);
         gw.present(CHILD_ID, S_DIMMER);
         gw.present(CHILD_ID, S_LIGHT);
         gw.request(CHILD_ID, V_PERCENTAGE);
         gw.request(CHILD_ID, V_LIGHT);
         gw.send(msgBright.set(100));
         gw.send(msgColor.set("000000"));
         gw.send(msgLight.set(1));
         gw.process();
         if (message.type == V_PERCENTAGE) {
        Any idea why?
        • D danivalencia
          @martinhjelmare
          Thanks!
          #define RED_PIN 3
          #define GREEN_PIN 5
          #define BLUE_PIN 6
          #define NODE_ID 2
          #define CHILD_ID 0
          float dimmer;
           gw.process();
          Any idea why?
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @danivalencia
          Yes, you are not sending back the updated state for the values after they have changed. By default home assistant will wait for feedback from the actuator for state update before updating the state in home assistant. This can be changed by setting the option optimistic to true in the config. But it's better to send back the updated state from the arduino.
          Also, you don't have to present three sensors if you only have one actual rgb light. You can have all three V_TYPES, V_RGB, V_DIMMER and V_LIGHT for the one S_TYPE, S_RGB_LIGHT.
          I'll update the docs on the web, cause I see now that the light page is not very clear about which types you actually can use.
            @danivalencia
            D
            D
            danivalencia
            @martinhjelmare
            Thanks a lot!
            So, I can remove two of the presentations, but I have to send three messages or can I send just one?
            And for the respond to the gateway, can you show me an example?
            Thanks again!
            • D danivalencia
              @martinhjelmare
              Thanks a lot!
              Thanks again!
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @danivalencia
              I suggest still sending values for all three V_TYPES at the end of setup. But remove presentation of S_LIGHT and S_DIMMER, as you say.
              The following is the sketch I've used when I tested the code. It's based on the LED dimmer example, and I've just added a dummy RGB light actuator which will just print out the received hex string, not actually changing any RGB LEDs. So just update the relevant parts of your sketch. I think it will work if you add the update of the states, by sending in those values.
               * Version 1.0 - February 15, 2014 - Bruce Lacey
               * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
               * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
               * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
               * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
               * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
               * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
               * to the LED negative terminal and the MOSFET Source pin is connected to ground.
               * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
               * http://www.mysensors.org/build/dimmer
              #define SN "DimmableLED"
              #define SV "1.1"
              #define CHILD_ID 1
              #define LED_PIN 5      // Arduino pin attached to MOSFET Gate pin
              #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
              char rgb[7] = "ffffff";
              static int currentLevel = 0;  // Current dim level...
              MyMessage dimmerMsg(CHILD_ID, V_PERCENTAGE);
              MyMessage lightMsg(CHILD_ID, V_STATUS);
              MyMessage rgbMsg(CHILD_ID, V_RGB);
               * Dimmable LED initialization method
                Serial.println(SN);
                gw.begin(incomingMessage);
                gw.sendSketchInfo(SN, SV);
                // Pull the gateway's current dim level - restore light level upon sendor node power-up
                gw.wait(2000);
                gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
                gw.send(dimmerMsg.set(currentLevel));
                gw.send(rgbMsg.set(rgb));
               *  Dimmable LED main processing loop
                gw.process();
                //gw.wait(5000);
                //gw.request(CHILD_ID, V_PERCENTAGE);
                  // Not implemented, just a dummy print.
                  hexstring.toCharArray(rgb, sizeof(rgb));
                  Serial.print("Changing color to ");
                  Serial.println(rgb);
                if (message.type == V_STATUS || message.type == V_PERCENTAGE) {
                  int requestedLevel = atoi(message.data);
                  requestedLevel *= (message.type == V_STATUS ? 100 : 1);
                  // Clip incoming level to valid range of 0 to 100
                  Serial.print("Changing level to ");
                  Serial.print(requestedLevel);
                  Serial.print(", from ");
                  Serial.println(currentLevel);
                  fadeToLevel(requestedLevel);
                  // hek comment: Is this really nessesary?
               *  This method provides a graceful fade up/down effect
              void fadeToLevel(int toLevel) {
                int delta = (toLevel - currentLevel) < 0 ? -1 : 1;
                while (currentLevel != toLevel) {
                  currentLevel += delta;
                  analogWrite(LED_PIN, (int)(currentLevel / 100. * 255));
                  delay(FADE_DELAY);
                @danivalencia
                #define SV "1.1"
                #define CHILD_ID 1
                  Serial.println(SN);
                  gw.wait(2000);
                  gw.process();
                  //gw.wait(5000);
                    delay(FADE_DELAY);
                D
                D
                danivalencia
                wrote on last edited by danivalencia
                @martinhjelmare
                I tried your sketch as is, just to try one leg for the RGB Led, but I'm not getting the expected result. When I change the brightness from the HA UI slider, the node gets the correct value, but...
                send: 12-12-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                send: 12-12-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.3
                send: 12-12-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                sensor started, id=12, parent=0, distance=1
                send: 12-12-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,st=ok:
                send: 12-12-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                send: 12-12-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                send: 12-12-0-0 s=1,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                send: 12-12-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
                send: 12-12-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                send: 12-12-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,st=ok:ffffff
                read: 0-0-12 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                Changing level to 100, from 0
                send: 12-12-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
                send: 12-12-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
                read: 0-0-12 s=1,c=1,t=3,pt=0,l=2,sg=0:17   // <- Here I modified brightness
                Changing level to 100, from 100
                read: 0-0-12 s=1,c=1,t=3,pt=0,l=1,sg=0:9  // <- Here too
                As you see, no matter what level receives, It goes to 100 forever.
                And if you try to move the brightness slider more over to the right (or the left to reduce), the values sometimes get higher than 100 (or -100), despite of the "clipping" method of the sketch.
                EDIT:
                Made a few changes to the code, to find what's failing, and I think is the way HA sends commands to the node;
                    Serial.print("Received: ");
                    Serial.println(message.data);
                    Serial.print("Bright: ");
                    Serial.println(requestedLevel);
                And the log from the sensor:
                read: 0-0-12 s=1,c=1,t=3,pt=0,l=3,sg=0:100
                Received: 100mableLED
                Bright: 100
                read: 0-0-12 s=1,c=1,t=3,pt=0,l=2,sg=0:45
                Received: 450mableLED
                Bright: 450
                Seems there is a string of the message (sketch name maybe) messing with the brightness data.
                • D danivalencia
                  @martinhjelmare
                  EDIT:
                  Bright: 100
                  Bright: 450
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @danivalencia
                  I think this was a bug in mysensors 1.5.2 - 1.5.3. Can you try version 1.5.4?
                    @danivalencia
                    D
                    D
                    danivalencia
                    @martinhjelmare
                    And there was the fail !! :s
                    Installed 1.5.4 and now it runs in the right manner.
                    Thank you!!
                    • D danivalencia
                      @martinhjelmare
                      Thank you!!
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      @danivalencia
                      :thumbsup:
