  3. USB ISP programmer with Small AA sensor node
4 Posts 2 Posters 2.3k Views 3 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    Programming a bare ATMEGA can be quite cumbersome. Using a cheap USB ISP programmer and the Arduino IDE simplifies things.
    0_1456997858419_upload-6532ca59-67fd-4ee5-a524-206a11ab024c
    I equipped The multi purpose Slim 2AA Battery Node with a ZIF socket and resonator (only needed if the bare ATMEGA328 is pre programmed to need an external crystal) and voila: a €6 USB ISP programmer for your MySensors nodes!
    0_1456998326251_upload-309e3269-313f-42dc-9139-0731e45111c7
    0_1456997605485_upload-9a7eedf6-d78e-4c14-ad63-02b624761a87
    (notice that I mounted the components on the back side of the board, in fact most are not actually needed)
    Select the right programmer in the Arduino IDE and you can set fuses and upload you preferred bootloader.
    • D
      D
      drock1985
      I like this.
      What pins are you connecting the USB ISP programmer to on the EasyNode?
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      AWIA 1 Reply Last reply
      • D drock1985
        I like this.
        AWIA
        AWIA
        AWI
        @drock1985 There is a dedicated ISP connector on the Slim node
        0_1457071597831_upload-5862bed2-fa9f-4b1d-982b-7d01654fc873
        • D
          D
          drock1985
          @AWI
          Thanks for the info. I didn't see the 8 to 6 pin adapter at first.
          Do
          My Projects
          2 Door Chime Sensor
