  3. ATtiny supported?
ATtiny supported?
42 Posts 20 Posters 34.2k Views 9 Watching
  • OitzuO Oitzu
    @NeverDie i used a spare arduino nano as programmer for the attiny85. This works great.
    As you maybe have seen i'm using a fork of the mysensors library of the end of may 2015.
    I don't really can identify, at this moment, with which version of rf24 the mysensors library comes by...
    but because the last update of this lib seems to be 9 months ago i should give it a try to update it.
    My suggested way to go would be: To merge the changes in the mysensors library from may 2015 to now into the fork (to be up-to-date with mysensors again) and then try to replace the rf24 library with a newer version.
    Did we have anyone here able to test the libs? At the moment i have no spare attiny & nrf laying arround, i'm waiting for a new delivery.
    About SPI: The rf24 lib includes a softSPI lib for communication.The lib even supports different ways to connect the nrf24 with the attiny.
    See: http://tmrh20.github.io/RF24/rf24ping85_8ino-example.html
    I never tried the 3 connect. I simply connected CE with VCC to get one pin for testing free.
    NeverDieN
    NeverDieN
    #21
    This is good news. It means the radio portion can be tested independently of the mysensors portion. If it turns out the radio portion tests out fine running standalone, then that would be good to know, as it might help isolate the source of instability to somewhere in the mysensors code. Or, visa versa.
    Using genuine Nordic Semiconductor parts for at least the initial radio testing would be ideal. I'm suggesting that so as to rule out possible clone-related problems. In about a week I should to receive a couple allegedly genuine Nordic Semiconductor NRF24L01+'s from an Itead distributor. Once I receive them, I can try running some standalone ATTiny85 wireless tests, starting with running the example code you referenced above from the TMRh2O library.
    As I'm a brand new arrival, I don't yet know anything about the mysensors code, and I have no experience by which to judge what's normal or atypical mysensors program behavior. So, in the near-term, I expect others would be in a better position to help with that part of the coding/testing/debugging/troubleshooting..
    • OitzuO Oitzu
      NeverDieN
      NeverDieN
      #22
      I'm getting a little confused. Not enough sleep I guess. :sleepy: Given what hek stated this morning in this link here, does that mean the current version of mysensors already supports the attiny85? Or does it need to be slimmed down to fit, which is what I gather (perhaps incorrectly) Oitzu and others were/are planning to do? Or is the required work something else entirely? If the TMRh20 library is already integrated, as hek stated in that link, and it contains the SoftSPI needed for the attiny85 to interface with an NRF24L01+, what other work, if any, remains to be done? Again, sorry for the Noob question.
      By the way,I made a typo in some of my posts. It should be TMRh20 (twenty), not TMRh2O (water). That's why my search of the forum hadn't turned up any reference to it, which is why I thought it might be new news rather than old news, as it apparently is. Sorry for that.
      • OitzuO
        OitzuO
        Oitzu
        @NeverDie to clear things up to you: Yes the underlying rf24 is fully compatible with the attiny85.
        The full-blown mySensors library is to big to fit on the attiny and has some compatibly issues.
        In April 2015 i forked the mysensors library and cut it down to fit on the attiny.
        It worked, but not reliable. The reason why it didn't worked correctly is at this moment not known, and i didn't investigated further.
        What need to be done: We need to merge the current mysensors library into the attiny fork, then we should merge the current rf24 lib into the attiny fork, after that... testing.
        • NeverDieN
          NeverDieN
          #24
          Thanks for the clarification. Perhaps not enough free memory. I've run into that causing instability on the UNO.
          Anyhow, after I receive the Nordic modules I'll probably run some ping-pong tests to measure packet loss with just the Attiny85 and the NRF24L01+ using the TMRh20 library. It won't be all that rigorous but If I notice instability, I'll let you know.
          • K
            K
            kapperi
            Just wondering that is it possible to make these sensors (Door) from ATtiny with nrf24l01+ and just pass the communication to arduino which is linked to mysensors networks? This way you don´t have to put mysensors code to little ATtiny.
            Just need somebody to figure out communication between arduino and Attiny network....
            • NeverDieN
              NeverDieN
              If the attiny85 turns out to be too tiny to be stable, maybe the LPC810 is worth trying? It has double the RAM and can sleep using less than 1uA of current. Adafruit has a starter kit as well as a tutorial on how to use it:
              https://www.adafruit.com/products/1336
              • NeverDieN NeverDie
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @NeverDie very cool chip but a bit dear.... even on aliexpress (assuming it is not a counterfeit - Oh no! here we go again!)
                NeverDieN 1 Reply Last reply
                • Moshe LivneM Moshe Livne
                  NeverDieN
                  NeverDieN
                  #28
                  Really? Quantity 1 price is $3.28 on Digikey for a chip that's practically standalone. Shockingly enough, the LPC824 is only $1.92 on Digikey, even though it looks like a far more capable chip: http://www.digikey.com/product-search/en?v=568&mpart=LPC824M201JHI33E
                  How can that be?
                    How can that be?
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @NeverDie I have no idea!!!! maybe digikey are selling counterfeits? hihihi
                    that is not a bad price.
                    • H
                      H
                      humblehacker
                      I think Attiny85, especially in the form of the Adafruit Trinket/Flora 3.3v version would be a perfect match for MySensors! Especially now that the Arduino Boards Manager makes third party boards much easier to work with. How is the Attiny MYS fork coming along?
                      • C
                        C
                        chuckconnors
                        I've seen a few posts about the ATtiny and it seems that perhaps someone has gotten it to work (http://forum.mysensors.org/topic/2129/battery-attiny85-door-window-wireless-sensor) though I'm not certain.
                        I'd really like to use these cheap chips for motion sensors and relay controllers for some sirens. Can anyone confirm or deny that these actually work?
                        • rustafariiR
                          rustafariiR
                          rustafarii
                          I have some attiny85 coming in. I will have a crack at with single pin sensor. Planning on testing with different clock speeds for stability. I will post any luck I have.
                          R
                          Shivanand ChanderballyS 1 Reply Last reply
                          • rustafariiR rustafarii
                            R
                            @rustafarii Any luck?
                            rustafariiR 1 Reply Last reply
                            • Shivanand ChanderballyS Shivanand Chanderbally
                              rustafariiR
                              rustafariiR
                              rustafarii
                              @Shivanand-Chanderbally
                              Not yet life got in my way and had to take a few months off. but i did get the tiny little boogers in.
                              My plan, as it looks like everyone else's, is to try getting attiny working with the radio without my sensors for basic communication, ping/pong, then add a sensor and see how much code to get readings from the sensor. if that goes well then it comes down to stripping what is not needed if any from the my sensor part sketch.
                              have you any progress?
                                @rustafarii Seems we have the same goal! I myself have been trying to get them working but the overhead is just too much to fit on such a tiny chip..
                                • T
                                  tlustoch
                                  wrote on last edited by tlustoch
                                  #36
                                  Any progress? I like to build simple low-power temperature sensor based on attiny85 but cannot compile mysensors sketch if attiny85 set as a processor :(
                                  C T 2 Replies Last reply
                                  • T tlustoch
                                    C
                                    C
                                    chuckconnors
                                    I've switched over to the ESP8266 runing ESPEasy firmware. Very cheap and very easy to use.
                                    • T tlustoch
                                      tlustoch
                                      It seems that it is possible: https://www.hackster.io/arjun/nrf24l01-with-attiny85-3-pins-74a1f2 but mysensors library has to support it?
                                        attiny85 seems to have 8kB flash. I don't think you'll be able to fit a MySensors sketch in so little space. Most sketches require 12k or more.
                                        Nca78N 1 Reply Last reply
                                          Nca78N
                                          Nca78N
                                          It would fit without a bootloader for very simple sketches only. RelayActuator example sketch without debug (and commented out debug lines) is 7 782 bytes.
                                          But I'm not sure it would run with 512bytes or ram and eeprom...
                                          T 1 Reply Last reply
