  3. Push button interrupt now functioning properly
9 Posts 2 Posters 4.3k Views 4 Watching
  • rchampR
    rchampR
    rchamp
    Hi there, I just finished building my push button sensor to act as a doorbell for my system.
    I used the basic binary switch sensor example as my basis. I have it connected to pin 3 on my arduino pro mini clone. When reading the serial logs, i learned that the pin registers high (1) when not pushed, and low (0) when pushed. So, i changed the send from 1:0 to 0:1 to send the correct state to Vera. all works fine there.
    When i tried to implement the sleep with interrupt, it seems as if the arduino sleeps indefinitely and does not wake upon state change (button push).
    Any idea as to why?
    Here is my code
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define NODE_ID 20
    #define SLEEP_TIME 120000
    Bounce debouncer = Bounce();
    int oldValue=-1;
      gw.begin(NULL, NODE_ID, false);
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      gw.present(CHILD_ID, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         Serial.println("Value = ");
         Serial.print(value);
         gw.send(msg.set(value==HIGH ? 0 : 1));
         oldValue = value;
      // Sleep until something happens with the sensor
      gw.sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
    rchampR martinhjelmareM 2 Replies Last reply
    • rchampR rchamp
      Any idea as to why?
      Here is my code
      #define CHILD_ID 3
      #define NODE_ID 20
      int oldValue=-1;
       // Setup the button
        debouncer.update();
           oldValue = value;
      rchampR
      rchampR
      rchamp
      @rchamp
      to add to this, is it an issue with the debouncer and the interrupt? i'm still a bit mystified about the debouncer library
      • rchampR rchamp
        Any idea as to why?
        Here is my code
        #define CHILD_ID 3
        #define NODE_ID 20
        int oldValue=-1;
         // Setup the button
          debouncer.update();
             oldValue = value;
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @rchamp
        Hi!
        The deboncer Bounce doesn't go well in combination with sleeping in my experience. Sleep for a short while in the loop before reading the pin, instead, to make the bounce settle.
        There's an example using this method among the examples in the mysensors library, called binary switch sleep something...
        • rchampR
          rchampR
          rchamp
          I'm trying out that sketch now. I'm getting weird results in the serial log. I'm going to try different interupt options instead of CHANGE to see if that helps
          • rchampR
            rchampR
            rchamp
            I'm getting some better results. Right now i have a .sleep(20) prior to reading the input.
            I also set the interrupt to detect on FALLING edge. Seems to be more stable.
            However, about one out of every 10 times i push the button i get a "1, 0,1" instead of a "1,0" .
            I then changed the pinMode to "INPUT_PULLUP" vs just "INPUT". I also changed the interrupt condition back to "CHANGE" and that seemed to do the trick to reliably capture button presses. Thanks for the quick response!!
            Here's a snapshot of my working code for reference for others that may experience my trouble
             * Interrupt driven binary switch example with dual interrupts
             * Author: Patrick 'Anticimex' Fallberg
             * Connect one button or door/window reed switch between
             * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
             * one in similar fashion on digital I/O pin 2.
             * This example is designed to fit Arduino Nano/Pro Mini
            #define SKETCH_NAME "Binary Sensor"
            #define SKETCH_MAJOR_VER "1"
            #define SKETCH_MINOR_VER "0"
            #define PRIMARY_CHILD_ID 3
            #define PRIMARY_BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
            #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
            #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
            MySensor sensor_node;
            MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
              sensor_node.begin();
              // Setup the buttons
              pinMode(PRIMARY_BUTTON_PIN, INPUT_PULLUP);
              // Activate internal pull-ups
              digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
              sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
              // Register binary input sensor to sensor_node (they will be created as child devices)
              sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
              uint8_t value;
              static uint8_t sentValue=2;
              sensor_node.sleep(20);
              value = digitalRead(PRIMARY_BUTTON_PIN);
              if (value != sentValue) {
                 // Value has changed from last transmission, send the updated value
                 sensor_node.send(msg.set(value==HIGH ? 0 : 1));
                 sentValue = value;
              sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, 0);
            • rchampR rchamp
                uint8_t value;
                   sentValue = value;
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @rchamp
              You shouldn't need to write the pin to HIGH if you have it as INPUT_PULLUP. But whatever works. :thumbsup:
              • rchampR
                rchampR
                rchamp
                I made that change and removed writing the pin to HIGH.
                However, in both cases, while i'm correctly seeing reads in the serial monitor, I'm not getting any status change on the motion created in VERA. I did a clean inclusion to vera (the node and sensor were never added to vera prior) and did the normal, include, reload and then turn on and off the sensor to get the sensor name and version details)
                Serial monitor reports normal, but not vera.
                Ideas?!
                • rchampR
                  rchampR
                  rchamp
                  strange. I changed the NODE_ID to 1 vs using the default AUTO selection from the gateway, and now I am seeing status in Vera. i think the gateway is having issues properly assigning node IDs. Will have to look into that some other time. Not a big deal for me as I have an excel table of all of my nodes anyway.
                  here's some photos of my doorbell node
                  • rchampR rchamp
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    @rchamp
                    I'm not familiar with how the Vera works. The gateway doesn't assign node ids, it's the controller that has to do that. I don't know if Vera supports that or not. Someone more versed in Vera should answer this.
