  3. Curtain Control Node
mysensorscurtain controlcontest2016
13 Posts 5 Posters 6.5k Views 5 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/45/Curtain-Control-Node
    • bisschopsrB
      bisschopsrB
      bisschopsr
      Hi Suresh,
      It would be great if you added the schematics of your design as a PDF file. I guess you created the design in Eagle?
      Thanaks in advance,
      Ralph
      Domoticz, P1 meter interface, MySensors and more to come!
      Suresh MaliS 1 Reply Last reply
      • J
        J
        jemish
        Hi Suresh,
        where we can by this type of curtain material. I want to use in my home.
        • bisschopsrB bisschopsr
          Hi Suresh,
          Thanaks in advance,
          Ralph
          Suresh MaliS
          Suresh MaliS
          Suresh Mali
          @bisschopsr The design files are available on openhardware.io
          • J jemish
            Hi Suresh,
            Suresh MaliS
            Suresh MaliS
            Suresh Mali
            @jemish You can look for on Aliexpress.
            • TON RIJNAARDT
              TON RIJNAARDT
              TON RIJNAARD
              Goodmorning,
              I try to load the sch file with egle but i get a error, can you help me.
              I use eagle 5.11 proffecial.
              In the picture of the schematic i don't see the ATSHA204-TSU and 25LC080SN can you help me with this.
              Greatz Ton Rijnaard
              Suresh MaliS 2 Replies Last reply
              • TON RIJNAARDT TON RIJNAARD
                Goodmorning,
                Greatz Ton Rijnaard
                Suresh MaliS
                Suresh MaliS
                Suresh Mali
                @TON-RIJNAARD I'll get back with libs for these parts. I am not in town and all files are on my desktop. Will send you once m back
                • TON RIJNAARDT
                  TON RIJNAARDT
                  TON RIJNAARD
                  Suresh Mali,
                  I have let make the board and now i try to complete the curtain
                  Can you help me where i connect the nss from the radio. i use the RFM 69, 433 mhz
                  How do i get te ino file in the atmega with the prog connector
                  You give me some answers in early question.
                  Greatsz Ton
                    Goodmorning,
                    Greatz Ton Rijnaard
                    Suresh MaliS
                    Suresh MaliS
                    Suresh Mali
                    @TON-RIJNAARD
                    SparkFun-DigitalIC.lbr This lib has the ATSHA204.
                    https://www.diymodules.org/eagle-show-object?type=usr&id=1937&part=microchip.lbr&device=25* here you can download the EEPROM lib
                      Suresh Mali,
                      Greatsz Ton
                      Suresh MaliS
                      Suresh MaliS
                      Suresh Mali
                      wrote on last edited by Suresh Mali
                      @TON-RIJNAARD There is a ICSP header to program MCU. I dont use RFM69 so you'll have to modify the Sch file. NS pin connects to D10. More info here : https://www.mysensors.org/build/connect_radio shows on how to connect RFM69.
                      • TON RIJNAARDT
                        TON RIJNAARDT
                        TON RIJNAARD
                        wrote on last edited by TON RIJNAARD
                        Suresh Mali,
                        Thx for the ersponse i give it a try.
                        D9 is that d100 perheps.
                        • TON RIJNAARDT
                          TON RIJNAARDT
                          TON RIJNAARD
                          Suresh,
                          How do i programm the chip.
                          I have try with arduino but don't now witch board i must select.
                          I have try it with arduin uno but i get only errors.
                          When everything is going okee i have load a bootloader in the atmega chip.
                          I use the programm connector on your board (6 pins streath) with a usb to 6 pins.
                          Ton Rijnaard
                            Suresh,
                            Ton Rijnaard
                            Suresh MaliS
                            Suresh MaliS
                            Suresh Mali
                            @TON-RIJNAARD You need to select the board based on the bootloader you have flashed. Complile the code in Arduino and try burning the hex file using a programmer (USBasp, AVRISP, etc..) if are facing issues with Arduino.
