  3. How to connect 5V sensor to battery powered device?
3 Posts 2 Posters 1.5k Views 3 Watching
  • A
    A
    arraWX
    On the battery powered sensor build page it is suggested to power 5V sensors using a step up converter. I guess that most 5V sensors use 5V logic levels for their digital output. Furthermore, as far as I understand the ATmega328P digital inputs do not accept voltages higher than Vcc + 0.5V (see datasheet p. 299). Consider as an example a sensebender operating at low battery level, say 2V. Wouldn’t the sensebender be harmed by a 5V digital signal from an attached sensor?
    I hope someone in here can help explain how to properly connect a 5V sensor to battery powered device.
    AWIA 1 Reply Last reply
    • A arraWX
      AWIA
      AWIA
      AWI
      @arraWX use a 'level converter' or find a 3v alternative for the sensor?
      • A
        A
        arraWX
        Thanks @AWI! A level converter is exactely what is needed.
