  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.2k Views 58 Watching
  • tekkaT tekka
    @Алексей-Гусаров :+1:
    J
    J
    jkandasa
    @tekka I work for MyController.org and it supports firmware upload. Do I need to change anything to support MYSbootloader v1.3pre ?
    Currently MyController.org supports for MYSbootloader1.1
    • Thar0lT Thar0l
      @tekka OK, I'll try to do it tomorrow.
      J
      J
      jkandasa
      @Алексей-Гусаров If you use MYSbootloader you should Reboot your node. AFAIK, MYSbootloader requires Reboot to get active.
      You should configure firmware in node edit page and reboot the node.
      Upload firmware works only for DualOptiboot
      Thar0lT 1 Reply Last reply
      • J jkandasa
        Thar0lT
        Thar0lT
        Thar0l
        @jkandasa I've tried to reboot and have such rsponce:
        Apr 28, 2016 02:49:44 PM	serial   0:GatewayNode Received Internal [Log message] send: 0-0-1-1 s=255,c=3,t=13,pt=0,l=0,sg=0,st=fail:
        Apr 28, 2016 02:49:44 PM	serial   1:SensorNode	Sent Internal	[Reboot]
        J 1 Reply Last reply
        • Thar0lT Thar0l
          J
          J
          jkandasa
          wrote on last edited by jkandasa
          #64
          @Алексей-Гусаров It looks like your node is not in the range!
          • J jkandasa
            Thar0lT
            Thar0lT
            Thar0l
            It sends messages it really in is 0.5 meters from gw.
            • Thar0lT Thar0l
              J
              J
              jkandasa
              @Алексей-Гусаров can you reboot the node manually?
              • J jkandasa
                Thar0lT
                Thar0lT
                Thar0l
                wrote on last edited by Thar0l
                #67
                @jkandasa
                I have this:
                [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006202
                [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:010002006302801481E090E00F90DF91CF910895FC01
                [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006302
                [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:0100020064021382128248EE53E060E070E044835583
                [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006402
                [Log message] send: 0-0-1-1 s=255,c=4,t=3,pt=6,l=22,sg=0,st=ok:0100020065026683778385ED91E09183808308951092
                [Log message] read: 1-1-0 s=255,c=4,t=2,pt=6,l=6,sg=0:010002006502
                And yes, it has been updated.
                Thanks, OTA works now, allthought remote reboot doesn working.
                • Thar0lT Thar0l
                  @jkandasa
                  I have this:
                  J
                  J
                  jkandasa
                  @Алексей-Гусаров I could not guess why remote reboot is not working! (Gateway says "Failed to send reboot command to node"). After OTA update completion, try reboot from MyController.org GUI. It may work with new software.
                  • J jkandasa
                    Thar0lT
                    Thar0lT
                    Thar0l
                    @jkandasa I've tried and it didn't help.
                    tekkaT 1 Reply Last reply
                    • Thar0lT Thar0l
                      tekkaT
                      tekkaT
                      tekka
                      @Алексей-Гусаров rebooting is only working if node is actively processing incoming msgs. Use wait() instead of sleep() within your loop()
                      • tekkaT tekka
                        Thar0lT
                        Thar0lT
                        Thar0l
                        #71
                        @tekka @jkandasa
                        Thank you.
                        I've added
                        #define MY_REPEATER_FEATURE
                        line in Node code, and it is working now.
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          wrote on last edited by Mark Swift
                          #72
                          Guys,
                          I'm trying to get this working on my ESP8266 gateway (using the latest development branch).
                          I've uploaded the 16mhz boot loader to an Arduino Nano clone but don't seem to see anything in MYScontroller. I realised that my gateway sketch had channel 125 specified, so took that out for testing as I believe the boot loader uses channel 76...
                          Do I need to change any fuse settings etc, what am I missing?
                          Many thanks in advance...
                          Mark
                          Edit: Got it working, fantastic!
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            #73
                            Is there a way I can change the channel from the default 76?
                            Also am I correct in thinking that for my Nano's I copy the bits (high, low, extended, lock, unlock) from the Arduino section at the top and replace the pasted lines from the tutorial as it seems to be for the UNO?
                            • rollercontainerR
                              rollercontainerR
                              rollercontainer
                              is already answered in this therad...
                              http://forum.mysensors.org/topic/3453/mysbootloader-1-3-pre-release-myscontroller-1-0-0beta/35
                              Mark SwiftM 1 Reply Last reply
                              • rollercontainerR rollercontainer
                                Mark SwiftM
                                Mark SwiftM
                                Mark Swift
                                This post is deleted!
                                • N
                                  N
                                  novas
                                  wrote on last edited by novas
                                  #76
                                  I have same problem as @n1ck1355. Shetch upload works, data are send, but serial output doesn't work.
                                  • Mark SwiftM
                                    Mark SwiftM
                                    Mark Swift
                                    I also have the same issues with no node serial output within the Arduino IDE....
                                    • Mark SwiftM Mark Swift
                                      tekkaT
                                      tekkaT
                                      tekka
                                      wrote on last edited by tekka
                                      #78
                                      @Mark-Swift @novas do you see any traffic over the air from that node? If yes, please post the log, specifically, I'm interested in bootloader messages.
                                      Mark SwiftM N 2 Replies Last reply
                                      • tekkaT tekka
                                        Mark SwiftM
                                        Mark SwiftM
                                        Mark Swift
                                        #79
                                        @tekka I apologise, in my case it was the bootloader delay I wasn't allowing for. Opening the serial monitor and being patient, it appears all is well. Apologies for the mistake!
                                        • tekkaT tekka
                                          N
                                          N
                                          novas
                                          @tekka In my case there were two problems. First same as @Mark-Swift, bootloader deley. I didn't expect that it takes about 30 seconds. Second one was that my gateway didn't run. In this case bootloader is still running and serial output isn't provided.
