  3. st=fail since mysensors 1.5.4 update
4 Posts 2 Posters 1.3k Views 2 Watching
  • mrcrabsM
    mrcrabsM
    mrcrabs
    Hi !
    It's my first post !
    I've a mysensors network with 2 repeaters, 4 nodes ; and I noticed a problem since I updated my nodes to mysensors 1.5.4 ;
    Since reflashing nodes, I have a lot of st=fail in my logs, and data doesn't reach the gateway.
    After doing some tests, my conclusion is that the gw.send command sends too quick the data.....
    I fixed that behaviour by adding the gw.wait(200) command after each gw.send(...).
    Since I've done that on all my nodes, the problem disappeared !
    I don't know how it can be possible ????
    Sincerely,
    • mrcrabsM
      mrcrabsM
      mrcrabs
      I didn't told you : I've decoupling capacitors on all my nodes. My gateway has a separate 3.3V regulator since it as an amplified NRF24L01+ with an external antenna.
      • V
        V
        vil1driver
        hi,
        you may upgarde your gateway too
        • mrcrabsM
          mrcrabsM
          mrcrabs
          Thank you for your help. It is already upgraded :-(
          Sincerely,
