  3. ESP8266 gateway - where are SPI pins defined?
4 Posts 2 Posters 4.1k Views 3 Watching
  • KrisJacobsK
    KrisJacobsK
    KrisJacobs
    I'm working with an Adafruit HUZZAH ESP8266 breakout, I wish to use it as my Gateway.
    https://learn.adafruit.com/adafruit-huzzah-esp8266-breakout/pinouts
    I wish to use these pins on the HUZZAH to interface with the NRF24L01 radio:
    4 - CE
    5 - CSN/CS
    12 - SCK
    13 - MOSI
    14 - MISO
    I've spent some time searching the forums and looking thru .h files, but I'm still not sure where the SPI pins are defined.
    What file defines these pins?
    Thanks!
    -KJ
    • KrisJacobsK
      KrisJacobsK
      KrisJacobs
      I think I've found what I needed in the header of ESP8266Gateway.ino:
       * The ESP8266 however requires different wiring:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
      YveauxY 1 Reply Last reply
      • KrisJacobsK KrisJacobs
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
        YveauxY
        YveauxY
        @KrisJacobs What you've found is only the text describing the pin connections.
        The ESP8266 uses its SPI port on pins GPIO12..14 to communicate to the radio. These pins are fixed.
        Only the CE & CSN/CS pin can be changed.
        They are defined here and here in the development branch (which you'd better use with the ESP).
        • KrisJacobsK
          KrisJacobsK
          KrisJacobs
          Awesome, exactly what I was looking for, thank you Yveaux!
