  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 38.6k Views 3 Watching
  • epierreE
    epierreE
    epierre
    @AWI your sketch has 3 sensors ? do you use a special wiring or you just get through high and low ?
    The sketch on soil humidity does this but with two pins to make kind of AC current, but it needs also some gypsum to protect the electrodes.
    . Leaf wetness is not immersed by nature hopefully ;-)
    z-wave - Vera -> Domoticz
    AWIA 1 Reply Last reply
    • epierreE epierre
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      #42
      @epierre It has 3 sensors with copper wiring. It switches the polarity of the voltage divider (1 Mohm in series with the "sensor") and measures the voltage over the sensor. Actualy it is a moisture alarm for a sensitive wooden floor.
      and I learned something today :smirk:
      "Gypsum is a soft sulfate mineral composed of calcium sulfate dihydrate, with the chemical formula CaSO4·2H2O"
      • epierreE
        epierreE
        epierre
        @AWI You can call it also "Plaster of Paris" ;-)
        When immersed you need to protect it whatever you do : http://vanderleevineyard.com/1/category/vinduino/1.html
        • epierreE
          epierreE
          epierre
          @awi going back to you above sketch, what is your wiring ?
          #define MoistureHighPin 3
          #define MoistureLowPin 4
          #define Moisture1ReadPin A1
          #define Moisture2ReadPin A2
          #define Moisture3ReadPin A3
          • epierreE
            epierreE
            epierre
            wrote on last edited by epierre
            #45
            I guess it is the same as Vinduino :
            with their test code:
            // This program tests 3 soil sensor inputs and prints bias caused by galvanic effects
            // Copyright (C) 2015, Reinier van der Lee
            // www.vanderleevineyard.com
            // This program is free software: you can redistribute it and/or modify
            // it under the terms of the GNU General Public License as published by
            // the Free Software Foundation, either version 3 of the License, or
            // any later version.
            // This program is distributed in the hope that it will be useful,
            // but WITHOUT ANY WARRANTY; without even the implied warranty of
            // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
            // GNU General Public License for more details.
            #include <math.h>       // Conversion equation from resistance to %
            // Setting up format for reading 3 soil sensors
            #define NUM_READS 10    // Number of sensor reads for filtering
            long buffer[NUM_READS];
            int index;
            typedef struct {        // Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
              int moisture;
              long resistance;
            } values;
            const long knownResistor = 1500;  // Constant value of known resistor in Ohms
            int supplyVoltage;                // Measured supply voltage
            int sensorVoltage;                // Measured sensor voltage
            values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
            int i;                            // Simple index variable
              // initialize serial communications at 9600 bps:
              Serial.begin(115200);
              // initialize the digital pins as an output.
              // Pin 6,7 is for sensor 1
              pinMode(6, OUTPUT);
              pinMode(7, OUTPUT);
            measure(1,6,7,1);
            Serial.print ("\t");
            Serial.println (average());
            long read1 = average();
            measure(1,7,6,0);
            long read2= average();
            long sensor1 = (read1 + read2)/2;
            Serial.print ("resistance bias =" );
            Serial.println (read1-read2);
            Serial.print ("sensor bias compensated value = ");
            Serial.println (sensor1);
            Serial.println ();
             delay (3000);
            void measure (int sensor, int phase_b, int phase_a, int analog_input)
              // read sensor, filter, and calculate resistance value
              // Noise filter: median filter
              for (i=0; i<NUM_READS; i++) {
                // Read 1 pair of voltage values
                digitalWrite(phase_a, HIGH);                 // set the voltage supply on
                delayMicroseconds(25);
                supplyVoltage = analogRead(analog_input);   // read the supply voltage
                digitalWrite(phase_a, LOW);                  // set the voltage supply off
                delay(1);
                digitalWrite(phase_b, HIGH);                 // set the voltage supply on
                sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                digitalWrite(phase_b, LOW);                  // set the voltage supply off
                // Calculate resistance
                // the 0.5 add-term is used to round to the nearest integer
                // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
                long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage)-457 ;
                delay(1);
                addReading(resistance);
                Serial.print (resistance);
            // Averaging algorithm
            void addReading(long resistance){
              buffer[index] = resistance;
              index++;
              if (index >= NUM_READS) index = 0;
            long average(){
              long sum = 0;
              for (int i = 0; i < NUM_READS; i++){
                sum += buffer[i];
              return (long)(sum / NUM_READS);
            and my hall of fame and shame of sensors I've tried :
