  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • elisavetgrigE
    elisavetgrigE
    elisavetgrig
    You are right! I thought that I missing something... always there are Data connection, VCC connection and GND.. and I had only one! I made another dummy scheme... Is that better?leaf wetness.jpg
    SparkmanS 1 Reply Last reply
    • elisavetgrigE elisavetgrig
      SparkmanS
      SparkmanS
      Sparkman
      @elisavetgrig Take a look at the second diagram of the link I posted. Right now you show the GND pin connected to the Analog pin and Vcc is also connected to the same spot, so that's not going to work.
      Al
      • elisavetgrigE
        elisavetgrigE
        elisavetgrig
        I based in the second diagram... i think that I understand it... resistorss-leaf wet.png
          SparkmanS
          SparkmanS
          Sparkman
          @elisavetgrig As I mentioned a few posts ago and how it's shown in the diagram on that link, is that you only need one resistor. The leaf wetness sensor becomes the other resistor in the circuit. In your last diagram, you have both the terminals of the wetness sensor connected to ground. Think of the wetness sensor as a resistor, with each of the terminals representing one leg of a regular resistor.
          Al
          • elisavetgrigE
            elisavetgrigE
            elisavetgrig
            OK... So I need only one resister... I think that "Scheme 2" is closer to the solution... images ofs.jpg
            • 5546dug5
              5546dug5
              5546dug
              @epierre how is the gold plating holding out on the sensor?
              Is there pitting and would you'd recommend this over the style in the store?
              How is the battery life with this setup?
              • epierreE
                epierreE
                epierre
                gold plating is a must have for outdoor.
                I am now regarding to have something more robust in time , I'm waiting for a light with movement with solar pannel to modify it for it.
                z-wave - Vera -> Domoticz
                • AWIA
                  AWIA
                  AWI
                  wrote on last edited by AWI
                  #39
                  In the case described there is a constant battery drain when there is "wetness" (moisture) on the sensor. This also implies an electrolytic process which takes care of eroding your sensor. No matter if you use gold plating or not.
                  To avoid both you can supply the sensor during measurement only -and- reverse te polarity each time.
                  An example ketch which takes care of measuring three moisture sensors which relies on this principle.
                  (the actual measurement is in the "ReadMoistureValues()" routine)
                   PROJECT: MySensors / Floor moisture sensor - measures moisture
                   PROGRAMMER: AWI
                   DATE: june 7, 2015/ last update: june 9, 2015
                   FILE: AWI_FloorMoisture.ino
                   LICENSE: Public domain
                   Hardware: tbd .- ATmega328p board w/ NRF24l01
                  	and MySensors 1.4
                  	(later: Temp & Humidity - HTU21)
                  Special:
                  	program with Arduino Pro 3.3V 8Mhz
                  SUMMARY:
                  	Moisture by analog read a polarity switching voltage divider between (high/ low)
                   Remarks:
                  	Fixed node-id
                  #include <Wire.h> 								// I2C
                  #define batteryVoltagePin A0
                  #define MoistureHighPin 3
                  #define MoistureLowPin 4
                  #define Moisture1ReadPin A1
                  #define Moisture2ReadPin A2
                  #define Moisture3ReadPin A3
                  #define BuzzerPin 5
                  #define LedPin 6
                  // MySensors Child ID's
                  #define MOISTURE1_CHILD_ID 5					// Moisture 1
                  #define MOISTURE2_CHILD_ID 6					// Moisture 2
                  #define MOISTURE3_CHILD_ID 7					// Moisture 3
                  // #define MOISTURE4_CHILD_ID 8					// Moisture 4
                  // MySensors messages
                  MyMessage moisturePercentageMsg1(MOISTURE1_CHILD_ID, V_HUM);	// Percentage
                  MyMessage moisturePercentageMsg2(MOISTURE2_CHILD_ID, V_HUM);	// Percentage
                  MyMessage moisturePercentageMsg3(MOISTURE3_CHILD_ID, V_HUM);	// Percentage
                  // MySensors instantiate
                  MySensor gw(9,10); 								// board, 3.3v (pin default 9,10)
                  // Reference values for ADC and Battery measurements
                  const float VccMin        = 1.0*3.5;    // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                  const float VccMax        = 1.0*4.2;    // Maximum expected Vcc level, in Volts.
                  float VccReference = 3.3 ;				// voltage reference for measurement (=vcc)
                  unsigned long SLEEP_TIME = 60000;  		//  10 sec sleep time between reads (seconds * 1000 milliseconds)
                  // **** class for Moisture measurement *****
                  // attaches an analog input to a data structure for measurements
                  // 			measures % of full scale voltage and scales the range of actual values
                  // 			stores current/ min & max values for the sensor
                  class MoistureSense
                  public:
                  	// Create an instance of MoistureSense and initialize (digital & input pin and reference values)
                    MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) ; 		// attach to pin and init
                    void ReadHigh();								// Read moisture if positive
                    void ReadLow();								// Read moisture with polarity inverted
                    // average the low/ high readings ang get the moisture percent value
                    uint8_t MoisturePercent();
                    void ResetMinMax();							// reset min & max values
                  protected:
                    uint8_t _ReadPin ; 							// Hardware Analog Pin number
                    int _CurMoisture, _MaxMoisture, _MinMoisture, _Low, _High, _HighValue, _LowValue ;
                    uint8_t _curState;
                  // to create an instance of MoistureSense and initialize (input pin and reference values)
                  MoistureSense::MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) {		// attach to pins and init
                  	_ReadPin = ReadPin;
                  	_LowValue = LowValue;
                  	_HighValue = HighValue;
                  	_CurMoisture = _MaxMoisture = _MinMoisture = NULL ;	// min & max in percent
                  void MoistureSense::ReadHigh()
                   // Read moisture with high polarity (in relation to Gnd)
                  	_High = analogRead(_ReadPin);
                  void MoistureSense::ReadLow()
                   // Read moisture with low polarity (in relation to Vcc)
                  	_Low = 1024 - analogRead(_ReadPin);
                  void MoistureSense::ResetMinMax()
                   // Reset min & max values
                  	_MinMoisture = _MaxMoisture = _CurMoisture;
                  uint8_t MoistureSense::MoisturePercent()
                  	uint8_t reading = constrain(map((_Low + _High)/2, _LowValue, _HighValue, 0, 100),0,100);	// average map to the 0-100% range
                  	_MinMoisture = min(reading, _MinMoisture);	// set min and max values
                  	_MaxMoisture = max(reading, _MaxMoisture);
                  // Instantiate moisture sensor objects
                  MoistureSense Moisture1(Moisture1ReadPin, 0, 1024);
                  MoistureSense Moisture2(Moisture2ReadPin, 0, 1024);
                  MoistureSense Moisture3(Moisture3ReadPin, 0, 1024);
                  void setup(){
                    	// MySensors setup (baud 115200)
                  	gw.begin(NULL, 21);  // fixed node 21, (final: connected to repeater 3 (living))"
                  	gw.sendSketchInfo("AWI FloorMoisture 21", "1.0");
                  	gw.present(MOISTURE1_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                  	gw.present(MOISTURE2_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                  	gw.present(MOISTURE3_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                  	Serial.print("AWI Moisture Started ");
                  	pinMode(BuzzerPin,OUTPUT);						// Setup intermittent buzzer & light
                  	pinMode(LedPin,OUTPUT);
                  void loop(){
                  	Serial.println("Moisture Percentages");
                  	ReadMoistureValues();
                  	gw.send(moisturePercentageMsg1.set(Moisture1.MoisturePercent())); // MySensors Send (V)
                  	gw.send(moisturePercentageMsg2.set(Moisture2.MoisturePercent())); // MySensors Send (V)
                  	gw.send(moisturePercentageMsg3.set(Moisture3.MoisturePercent())); // MySensors Send (V)
                  	gw.sendBatteryLevel(batteryPercentage());
                  	// show local alarm if moisture > 20%
                  	if ((Moisture1.MoisturePercent()>20) || (Moisture2.MoisturePercent()>20) ||
                  		(Moisture3.MoisturePercent()>20) || (batteryPercentage() < 10))
                  		MoistureAlarm();
                  	gw.sleep(SLEEP_TIME);							// low power for sleep time
                  unsigned ReadMoistureValues()
                  // read all moisturevalues
                  	pinMode(MoistureLowPin, OUTPUT);				// first set all pins to measurement(non floating) mode
                  	pinMode(MoistureHighPin, OUTPUT);
                  	digitalWrite(MoistureLowPin, LOW); 				// Set polarity on voltage divider high and read the values
                  	digitalWrite(MoistureHighPin, HIGH); delayMicroseconds(100);
                  	Moisture1.ReadLow(); delayMicroseconds(100);
                  	Moisture2.ReadLow(); delayMicroseconds(100);
                  	Moisture3.ReadLow(); delayMicroseconds(100);
                  	digitalWrite(MoistureLowPin, HIGH);				// reverse polarity on voltage divider and read values
                  	digitalWrite(MoistureHighPin, LOW); delayMicroseconds(100);
                  	Moisture1.ReadHigh(); delayMicroseconds(100);
                  	Moisture2.ReadHigh(); delayMicroseconds(100);
                  	Moisture3.ReadHigh(); delayMicroseconds(100);
                  	pinMode(MoistureLowPin, INPUT);					// reset pins to floating, to avoid power leakage
                  	pinMode(MoistureHighPin, INPUT);
                  	Serial.print("Moist1: ");
                  	Serial.print(Moisture1.MoisturePercent());
                  	Serial.print(" , Moist2: ");
                  	Serial.print(Moisture2.MoisturePercent());
                  	Serial.print(" , Moist3: ");
                  	Serial.print(Moisture3.MoisturePercent());
                  	Serial.println();
                  unsigned MoistureAlarm()
                  // If moisturelevel to high, sound & show local alarm
                  	delay(100);										// sound & light for 100ms, uses a lot of power, so no no need for power down
                  // get Battery Voltage & charge current
                  // assumes a balanced voltage divider on Battery and uses the Vcc as reference (3.3V in this case)
                  // Parameters:
                  // - VccMin = minimum battery voltage
                  // - VccMax = maximum battery voltage
                  // - VccReference = reference voltage for ADC
                  uint8_t batteryPercentage()
                  	float batteryVoltage = ((float)analogRead(batteryVoltagePin)* VccReference/1024) * 2;	// actual voltage is double
                  	Serial.print("Batt: ");
                  	Serial.print(batteryVoltage);
                  	Serial.print("V ; ");
                  	return(constrain(map(batteryVoltage, VccMin, VccMax, 0, 100),0,100));	// and map to the 0-100% range
                    This is a great idea to get less erosion!
                    • epierreE
                      epierreE
                      epierre
                      @AWI your sketch has 3 sensors ? do you use a special wiring or you just get through high and low ?
                      The sketch on soil humidity does this but with two pins to make kind of AC current, but it needs also some gypsum to protect the electrodes.
                      . Leaf wetness is not immersed by nature hopefully ;-)
                      AWIA 1 Reply Last reply
                      • epierreE epierre
                        AWIA
                        AWIA
                        AWI
                        #42
                        @epierre It has 3 sensors with copper wiring. It switches the polarity of the voltage divider (1 Mohm in series with the "sensor") and measures the voltage over the sensor. Actualy it is a moisture alarm for a sensitive wooden floor.
                        and I learned something today :smirk:
                        "Gypsum is a soft sulfate mineral composed of calcium sulfate dihydrate, with the chemical formula CaSO4·2H2O"
                        • epierreE
                          epierreE
                          epierre
                          @AWI You can call it also "Plaster of Paris" ;-)
                          When immersed you need to protect it whatever you do : http://vanderleevineyard.com/1/category/vinduino/1.html
                          • epierreE
                            epierreE
                            epierre
                            @awi going back to you above sketch, what is your wiring ?
                            • epierreE
                              epierreE
                              epierre
                              #45
                              I guess it is the same as Vinduino :
                              with their test code:
                              // This program tests 3 soil sensor inputs and prints bias caused by galvanic effects
                              // Copyright (C) 2015, Reinier van der Lee
                              // www.vanderleevineyard.com
                              // This program is free software: you can redistribute it and/or modify
                              // it under the terms of the GNU General Public License as published by
                              // the Free Software Foundation, either version 3 of the License, or
                              // any later version.
                              // This program is distributed in the hope that it will be useful,
                              // but WITHOUT ANY WARRANTY; without even the implied warranty of
                              // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                              // GNU General Public License for more details.
                              #include <math.h>       // Conversion equation from resistance to %
                              // Setting up format for reading 3 soil sensors
                              #define NUM_READS 10    // Number of sensor reads for filtering
                              long buffer[NUM_READS];
                              int index;
                              typedef struct {        // Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
                                int moisture;
                                long resistance;
                              } values;
                              const long knownResistor = 1500;  // Constant value of known resistor in Ohms
                              int supplyVoltage;                // Measured supply voltage
                              int sensorVoltage;                // Measured sensor voltage
                              values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
                              int i;                            // Simple index variable
                                // initialize serial communications at 9600 bps:
                                // initialize the digital pins as an output.
                                // Pin 6,7 is for sensor 1
                                pinMode(6, OUTPUT);
                                pinMode(7, OUTPUT);
                              measure(1,6,7,1);
                              Serial.print ("\t");
                              Serial.println (average());
                              long read1 = average();
                              measure(1,7,6,0);
                              long read2= average();
                              long sensor1 = (read1 + read2)/2;
                              Serial.print ("resistance bias =" );
                              Serial.println (read1-read2);
                              Serial.print ("sensor bias compensated value = ");
                              Serial.println (sensor1);
                              Serial.println ();
                               delay (3000);
                              void measure (int sensor, int phase_b, int phase_a, int analog_input)
                                // read sensor, filter, and calculate resistance value
                                // Noise filter: median filter
                                for (i=0; i<NUM_READS; i++) {
                                  // Read 1 pair of voltage values
                                  digitalWrite(phase_a, HIGH);                 // set the voltage supply on
                                  delayMicroseconds(25);
                                  supplyVoltage = analogRead(analog_input);   // read the supply voltage
                                  digitalWrite(phase_a, LOW);                  // set the voltage supply off
                                  delay(1);
                                  digitalWrite(phase_b, HIGH);                 // set the voltage supply on
                                  sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                                  digitalWrite(phase_b, LOW);                  // set the voltage supply off
                                  // Calculate resistance
                                  // the 0.5 add-term is used to round to the nearest integer
                                  // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
                                  long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage)-457 ;
                                  delay(1);
                                  addReading(resistance);
                                  Serial.print (resistance);
                              // Averaging algorithm
                              void addReading(long resistance){
                                buffer[index] = resistance;
                                index++;
                                if (index >= NUM_READS) index = 0;
                              long average(){
                                long sum = 0;
                                for (int i = 0; i < NUM_READS; i++){
                                  sum += buffer[i];
                                return (long)(sum / NUM_READS);
                              and my hall of fame and shame of sensors I've tried :
