  3. Buzzers...
Buzzers...
7 Posts 2 Posters 1.8k Views 2 Watching
  • S Offline
    Samuel235
    Does anyone have any active buzzers in stock that they could get me the pin pitch on. If you also have the source of the buzzers that would be fantastic. I can grab some off of aliexpress at a nice cheap price however, i have no documentation on these things. The only spec that I need is the recommended land pattern of the device. From all of the ones on uk.farnell.com i'm seeing that most of them are 5mm spacing, however i would like someone to confirm this with their own stock.
    Thanks,
    Sam.
    MySensors 2.1.1
    • mfalkviddM Offline
      I have some of these at home http://www.ebay.com/itm/171857067572
      Can check their pitch in about 12 hours if no-one else has pitched in by then.
      S 1 Reply Last reply
        Samuel235
        @mfalkvidd, that will be awesome. Thank you. They actually look like a better choice thanks to their price point.
        MySensors 2.1.1
        • S Samuel235
          @Samuel235:
          First buzzer
          inner distance between legs 7.12mm
          outer distance between legs 8.35mm
          leg diameter 0.61mm
          => distance cc (7.12+8.35)/2= 7.74mm
          Second buzzer:
          inner distance between legs 7.03mm
          outer distance between legs 8.25mm
          leg diameter 0.63
          => distance cc (7.03+8.25)/2= 7.64mm
          The legs are quite flexible so it is possible to bend them a bit if necessary.
          I measured as close to the base as I could.
            @Samuel235:
            First buzzer
            leg diameter 0.61mm
            Second buzzer:
            leg diameter 0.63
            Samuel235
            @mfalkvidd Perfect! I will get some ordered now.
            Thank you for your help!
            MySensors 2.1.1
              You're welcome :) Note: I added a second set of measurements. Seems there is some variation in the manufacturing process.
                Samuel235
                @mfalkvidd said:
                You're welcome :) Note: I added a second set of measurements. Seems there is som variation in the manufacturing process.
                I just noticed those. I will put the pin pitch at around the 7.7mm mark to allow for variation either side and can bend them as needed.
                MySensors 2.1.1
