  3. Several dimmers
Several dimmers
11 Posts 3 Posters 4.3k Views 6 Watching
    moskovskiy82
    In my project i need to run 3 separate dimmers from one board. Can somebody give a hint how to integrate 3 dimmers in the standard dimmer sketch?
    #define SN "DimmableLED"
    #define SV "1.1"
    #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    static int currentLevel = 0;  // Current dim level...
    MyMessage dimmerMsg(0, V_DIMMER);
    MyMessage lightMsg(0, V_LIGHT);
     * Dimmable LED initialization method
      Serial.println( SN );
      gw.begin( incomingMessage );
      gw.present( 0, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( 0, V_DIMMER );
     *  Dimmable LED main processing loop
      gw.process();
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
        requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
        // Clip incoming level to valid range of 0 to 100
        Serial.print( "Changing level to " );
        Serial.print( ", from " );
        Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
        gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));
        // hek comment: Is this really nessesary?
        gw.send( dimmerMsg.set(currentLevel) );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
    • TheoLT
      TheoLT
      TheoL
      Here's the declaration part, including presenting the node. Didn't have time to modify the incoming message handler, but hopefully it helpts
      #define SV "1.1"
      #define DIMMER_NODE_1 1
      #define DIMMER_NODE_2 1
      #define DIMMER_NODE_3 1
      // static int currentLevel1 = 0;  // Current dim level... <== static is static don't think you want that
      byte currentLevel1 = 0;  // Current dim level...
      byte currentLevel2 = 0;  // Current dim level...
      byte currentLevel3 = 0;  // Current dim level...
      MyMessage dimmerMsg1(DIMMER_NODE_1, V_DIMMER);
      MyMessage lightMsg1(DIMMER_NODE_1, V_LIGHT);
      MyMessage dimmerMsg2(DIMMER_NODE_2, V_DIMMER);
      MyMessage lightMsg2(DIMMER_NODE_2, V_LIGHT);
      MyMessage dimmerMsg3(DIMMER_NODE_3, V_DIMMER);
      MyMessage lightMsg3(DIMMER_NODE_3, V_LIGHT);
        gw.present( DIMMER_NODE_1, S_DIMMER );
        gw.wait( 50 );
        gw.present( DIMMER_NODE_2, S_DIMMER );
        gw.wait( 50 );
        gw.present( DIMMER_NODE_3, S_DIMMER );
        gw.wait( 50 );
        gw.wait( 50 );
        gw.request( DIMMER_NODE_1, V_DIMMER );
        gw.wait( 50 );
        gw.request( DIMMER_NODE_2, V_DIMMER );
        gw.wait( 50 );
        gw.request( DIMMER_NODE_3, V_DIMMER );
      I also changed the current level from static int to byte. The static part could never have worked. Dim level is 0-100 which fits in a byte (0-255) and thus a byte is better. Saves memory
        moskovskiy82
        Thank you for the help.
        Here is the final working code in case somebody needs it
        #define SN "DimmableLEDs"
        #define SV "1.0"
        #define LED_PIN_1 3
        #define LED_PIN_2 5
        #define LED_PIN_3 6
        #define DIMMER_NODE_1 0
        #define DIMMER_NODE_3 2
        byte currentLevel[3] = {0,0,0};
        MyMessage dimmerMsg0(0, V_DIMMER);
        MyMessage lightMsg0(0, V_LIGHT);
        MyMessage dimmerMsg1(1, V_DIMMER);
        MyMessage lightMsg1(1, V_LIGHT);
        MyMessage dimmerMsg2(2, V_DIMMER);
        MyMessage lightMsg2(2, V_LIGHT);
          gw.wait( 50 );
          gw.wait( 50 );
          gw.wait( 50 );
          gw.wait( 50 );
          gw.wait( 50 );
          gw.wait( 50 );
          gw.process();
            Serial.println( currentLevel[message.sensor] );
            fadeToLevel( requestedLevel, message.sensor);
        switch(message.sensor)
            case 0:
              gw.send(lightMsg0.set(currentLevel[0] > 0 ? 1 : 0));
              gw.send( dimmerMsg0.set(currentLevel[0]) );
              break;
            case 1:
              gw.send(lightMsg1.set(currentLevel[1] > 0 ? 1 : 0));
              gw.send( dimmerMsg1.set(currentLevel[1]) );
              break;
            case 2:
              gw.send(lightMsg2.set(currentLevel[2] > 0 ? 1 : 0));
              gw.send( dimmerMsg2.set(currentLevel[2]) );
              break;
        void fadeToLevel( int toLevel, byte sensorId ) {
          int delta = ( toLevel - currentLevel[sensorId] ) < 0 ? -1 : 1;
          while ( currentLevel[sensorId] != toLevel ) {
            currentLevel[sensorId] += delta;
         switch(sensorId)
            case 0:
              analogWrite( LED_PIN_1, (int)(currentLevel[sensorId] / 100. * 255) );
              break;
            case 1:
              analogWrite( LED_PIN_2, (int)(currentLevel[sensorId] / 100. * 255) );
              break;
            case 2:
              analogWrite( LED_PIN_3, (int)(currentLevel[sensorId] / 100. * 255) );
              break;
          moskovskiy82
          Every time the node is reset - LED is on. You have to send 100% first to make it work. Is there a way to start with LED off?
          M 1 Reply Last reply
          • M moskovskiy82
            moskovskiy82
            This effect is also on the standard LED dimmer sketch published on mysensors site
              Yes, instead of requesting value at startup, your can send a level 0 to controller.
                moskovskiy82
                @hek
                Can you help with the code example for this?
                So we comment out
                and substitute it with?
                  moskovskiy82
                  Should it go like this?
                  { SOME CODE HERE
                   gw.send(dimmerMsg0.set(0));
                   digitalWrite( LED_PIN_1, 0);```
                  • M moskovskiy82
                    { SOME CODE HERE
                    moskovskiy82
                    No luck with this one
                      You should probably send with ack enabled, this this:
                      gw.send(dimmerMsg0.set(0), true);
                        moskovskiy82
                        The answer was simple
                        Change
                        to
                        analogWrite( LED_PIN_1, 0);
