  3. Node will not connect unless #define MY_PARENT_NODE_ID
4 Posts 2 Posters 2.1k Views 2 Watching
  • Mark SwiftM
    Mark SwiftM
    Mark Swift
    wrote on last edited by Mark Swift
    Hi Guys,
    Using the latest 2.0.0 dev branch I'm having the issue where nodes will not connect unless I #define MY_PARENT_NODE_ID X. If I don't it just repeats:
    find parent
    send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    Init complete, id=1, parent=255, distance=255
    If I define the parent node, it connects, I can then write the sketch with it commented out?
    Sketch is simple (I'm using the default sketch for the ESP8266 gateway)
    // Enable debug prints
    #define MY_NODE_ID 1
    // #define MY_PARENT_NODE_ID 0
    // #define MY_RADIO_RFM69
    // Enabled repeater feature for this node
    #define MY_REPEATER_FEATURE
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      metric = getConfig().isMetric;
      sendSketchInfo("T+H+R", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      wait(dht.getMinimumSamplingPeriod()); // Delay or wait (repeater)
      // Fetch temperatures from DHT sensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
    #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      // Fetch humidity from DHT sensor
      if (isnan(humidity)) {
        lastHum = humidity;
    #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      wait(SLEEP_TIME); // Sleep or wait (repeater)
    • Mark SwiftM
      Mark SwiftM
      Mark Swift
      Morning guys,
      Does anyone have any ideas? As soon as I define a parent, all is well... Noob mistake I'm not seeing?
      EDIT: Okay, it seems the issue is simpler, if I take out the node ID it sits at req id, so I presume the gateway is not responding?
      Debug from sensor (I can see the other 2 that are deployed seem to communicate with it no problem?)
      Starting repeater (RNNRA-, 2.0.0-beta)
      Radio init successful.
      send: 1-1-2-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
      send: 1-1-2-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
      send: 1-1-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:2
      send: 1-1-2-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=fail:T+H+R
      send: 1-1-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
      send: 1-1-2-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=fail:
      find parent
      send: 1-1-2-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
      Init complete, id=1, parent=2, distance=255
      read and forward: 1-4-0 s=1,c=0,t=6,pt=0,l=0,sg=0
      send: 1-1-2-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:
      send: 1-1-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:26.3
      T: 26.30
      send: 1-1-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:38.6
      H: 38.60
      read and forward: 2-4-0 s=0,c=1,t=0,pt=7,l=5,sg=0
      send: 2-1-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:-24.1
      send: 1-1-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:37.9
      H: 37.90
      send: 2-1-2-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:-24.0
      find parent
      send: 1-1-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:25.8
      T: 25.80
      send: 1-1-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:39.1
      H: 39.10
        st=fails means that the message didn't reach the next node, so the problem is a radio communication issue which is often caused by power problems.
        If you haven't looked at http://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help already you might get some help from the troubleshooting flowchart there.
        Mark SwiftM 1 Reply Last reply
          Mark SwiftM
          Mark SwiftM
          Mark Swift
          @mfalkvidd
          My gateway is an NodeMCU with a NRF PA + LNA, it seems to be resolved if I use #define MY_RF24_PA_LEVEL RF24_PA_MIN on the gateway.
          Strange, as the NodeMCU has a AMS1117 which I believe can handle 800ma, presuming the ESP8266 uses 300ma max, that leaves 500ma, surely it should be enough?
          I've tried shielding the radio as suggested but it doesn't make a difference.
