  3. Locally attached sensors
7 Posts 3 Posters 3.3k Views 4 Watching
  • skatunS
    skatunS
    skatun
    My serial gateway will have something like 16 locally attached sensor to it. So I would like to keep my serial gateway code as clean and simple as possible, hence I would like some input on how to do this.
    I will take the energyMeterPulse sketch in the example folder as an example of my idea.
    I would like to rewrite the code to have an constructur like this:
    EnergyMeter(DIGITAL_INPUT_SENSOR,PULSE_FACTOR ,SLEEP_MODE,MAX_WATT,CHILD_ID,SEND_FREQUENCY)
    Then it should have three methods:
    Present
    Start
    Stop
    My serial gateway code will then look clean:
    EnergyMeter powerSensor1 = new EnergyMeter(2,1000,false,10000,12,60000)
    void presentation() {
       powerSensor1.present
    powerSensor1.start
    So how can I restructure energyMeterPulse sketch to achieve this? Or how does other handle heaps of locally attached sensor to gateway?
    skatunS 1 Reply Last reply
    • skatunS skatun
      Present
      Start
      Stop
      powerSensor1.start
      skatunS
      skatunS
      skatun
      Here is my suggestion, which does not quite work, because I dont know how to make the loop inside a class:)
      #include "ENERGYMETER.h" //include the declaration for this class
      #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
      #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
      #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
      #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
      int DIGITAL_INPUT_SENSOR // Usually the interrupt = pin -2 (on uno/nano anyway)
      #define CHILD_ID 1              // Id of the sensor child
      unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
      double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
      boolean pcReceived = false;
      volatile unsigned long watt = 0;
      unsigned long oldWatt = 0;
      double oldKwh;
      unsigned long lastSend;
      MyMessage wattMsg(CHILD_ID,V_WATT);
      MyMessage kwhMsg(CHILD_ID,V_KWH);
      const byte LED_PIN = 13; //use the LED @ Arduino pin 13, this should not change so make it const (constant)
      //<<constructor>> setup the LED, make pin 13 an OUTPUT
      ENERGYMETER::ENERGYMETER(_DIGITAL_INPUT_SENSOR){
      	DIGITAL_INPUT_SENSOR = _DIGITAL_INPUT_SENSOR;
        request(CHILD_ID, V_VAR1);
        // Use the internal pullup to be able to hook up this sketch directly to an energy meter with S0 output
        // If no pullup is used, the reported usage will be too high because of the floating pin
        pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
        attachInterrupt(INTERRUPT, onPulse, RISING);
        lastSend=millis();
      //<<destructor>>
      ENERGYMETER::~ENERGYMETER(){/*nothing to destruct*/}
      //present it
      void ENERGYMETER::present(){
        sendSketchInfo("Energy Meter", "1.0");
        present(CHILD_ID, S_POWER);
      //turn the LED off
      void ENERGYMETER::start(){
        unsigned long now = millis();
        bool sendTime = now - lastSend > SEND_FREQUENCY;
        if (pcReceived && (SLEEP_MODE || sendTime)) {
          // New watt value has been calculated
          if (!SLEEP_MODE && watt != oldWatt) {
            // Check that we dont get unresonable large watt value.
            // could hapen when long wraps or false interrupt triggered
            if (watt<((unsigned long)MAX_WATT)) {
              send(wattMsg.set(watt));  // Send watt value to gw
            Serial.print("Watt:");
            Serial.println(watt);
            oldWatt = watt;
          // Pulse cout has changed
          if (pulseCount != oldPulseCount) {
            send(pcMsg.set(pulseCount));  // Send pulse count value to gw
            double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
            oldPulseCount = pulseCount;
            if (kwh != oldKwh) {
              send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
              oldKwh = kwh;
          lastSend = now;
        } else if (sendTime && !pcReceived) {
          // No count received. Try requesting it again
          lastSend=now;
        if (SLEEP_MODE) {
          sleep(SEND_FREQUENCY);
        if (message.type==V_VAR1) {
          Serial.println(pulseCount);
          pcReceived = true;
      void onPulse()
        if (!SLEEP_MODE) {
          unsigned long interval = newBlink-lastBlink;
          if (interval<10000L) { // Sometimes we get interrupt on RISING
            return;
          watt = (3600000000.0 /interval) / ppwh;
          lastBlink = newBlink;
        pulseCount++;
      • skatunS
        skatunS
        skatun
        I now get this error message, any idea what the problem might be?
        In file included from C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:5:0:
        C:\Users\kim\Documents\Arduino\libraries\MySensors/MySensor.h:285:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        Here is my test class:
        #include <EnergyMeter.h>
        EnergyMeter power(1);//initialize an instance of the class
        void setup(){
          power.present();
        void loop(){
          power.update();//stay one second on, then a second off
        and here is my EnergyMeter.cpp file :
        #include "EnergyMeter.h" //include the declaration for this class
        long PULSE_FACTOR       // Nummber of blinks per KWH of your meeter
        boolean SLEEP_MODE        // Watt-value can only be reported when sleep mode is false.
        long MAX_WATT          // Max watt value to report. This filetrs outliers.
        int CHILD_ID              // Id of the sensor child
        double ppwh
        double oldKwh;
        EnergyMeter::EnergyMeter(int _CHILD_ID){
        	CHILD_ID   = _CHILD_ID;           // Id of the sensor child
        	/* Optional Arguments */
        	PULSE_FACTOR =1000;       // Nummber of blinks per KWH of your meeter
        	SLEEP_MODE =  false ;       // Watt-value can only be reported when sleep mode is false.
        	MAX_WATT = 10000;          // Max watt value to report. This filetrs outliers.
        	DIGITAL_INPUT_SENSOR = 0; // Usually the interrupt = pin -2 (on uno/nano anyway)
        	/*Starting the setup algorithm */
        	lastSend=millis();
        //<<destructor>>
        EnergyMeter::~EnergyMeter(){/*nothing to destruct*/}
        //present it
        //update the reading of the power
        void ENERGYMETER::update(){
              oldWatt = watt;
                oldKwh = kwh;
            lastSend = now;
            lastSend=now;
          if (SLEEP_MODE) {
            pcReceived = true;
        void onPulse()
          if (!SLEEP_MODE) {
              return;
          pulseCount++;
          I think you need
          #define MY_GATEWAY_SERIAL
            I think you need
            skatunS
            skatunS
            skatun
            The define method got rid of that error, so then i Should add it to the constructor?
            So that the user that creates the node have to decide if the gateway is serial,wifi, or RF, right?
            Now I got these errors instead:
            Arduino: 1.6.8 (Windows 7), Board: "Arduino Nano, ATmega328"
            Build options changed, rebuilding all
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:8:1: error: expected initializer before 'boolean'
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp: In constructor 'EnergyMeter::EnergyMeter(int)':
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:27:2: error: 'CHILD_ID' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:30:2: error: 'SEND_FREQUENCY' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:31:2: error: 'PULSE_FACTOR' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:32:2: error: 'SLEEP_MODE' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:33:2: error: 'MAX_WATT' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:34:2: error: 'DIGITAL_INPUT_SENSOR' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:38:2: error: 'ppwh' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:51:18: error: 'INTERRUPT' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:51:29: error: 'onPulse' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp: At global scope:
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:59:6: error: 'ENERGYMETER' has not been declared
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp: In function 'void present()':
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:64:11: error: 'CHILD_ID' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:69:6: error: 'ENERGYMETER' has not been declared
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp: In function 'void update()':
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:73:36: error: 'SEND_FREQUENCY' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:74:7: error: 'pcReceived' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:74:22: error: 'SLEEP_MODE' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:79:32: error: 'MAX_WATT' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:80:14: error: 'wattMsg' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:89:12: error: 'pcMsg' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:90:49: error: 'PULSE_FACTOR' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:93:14: error: 'kwhMsg' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:100:13: error: 'CHILD_ID' was not declared in this scope
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:104:7: error: 'SLEEP_MODE' was not declared in this scope
               if (SLEEP_MODE) {
            C:\Users\kim\Documents\Arduino\libraries\EnergyMeter\EnergyMeter.cpp:109:1: error: expected declaration before '}' token
            exit status 1
            Error compiling for board Arduino Nano.
            option enabled in File -> Preferences.
            • badmannenB
              badmannenB
              badmannen
              just for a test, try to make another constructor without any in-arguments and see if thoose errors persist. just to check. ( I might be way off here. did this stuff 12 years ago and just got back into it )
              //Henrik
              rPi 3 - UNO R3 - Mini - Nano - custom
              • badmannenB badmannen
                //Henrik
                skatunS
                skatunS
                skatun
                @badmannen
                I am on to it:)
