  3. W5100 gateway not connecting to network
5 Posts 2 Posters 3.2k Views 2 Watching
  • hautomateH
    hautomateH
    hautomate
    Howdy,
    I'm trying to set up a new ethernet gateway with the W5100 shield and cannot get on my network. The compile works and the serial monitor shows the following:
    Here's the setup function from EthernetGateway.ino. After perusing the forum and reading about various network-related issues, it looks like gw.begin is missing a key piece. No?
      Ethernet.begin(mac, myIp);
     // give the Ethernet interface a second to initialize
      delay(1000);
      setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
       // Initialize gateway at maximum PA level, channel 70 and callback for write operations
      gw.begin(incomingMessage, 0, true, 0);
      // start listening for clients
      server.begin();
    • hautomateH
      hautomateH
      hautomate
      I just tried the dev release to be able to use DHCP and define a static lease on my router, but that doesn't get me connected either.
      With an IP defined in GatewayW5100.ino I get a response showing an IP of 0.0.0.0:
      #define MY_IP_ADDRESS 10,10,10,231   // If this is disabled, DHCP is used to retrieve address
      #define MY_PORT 5003
      0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
      0;255;3;0;9;Radio init successful.
      IP: 0.0.0.0
      0;255;3;0;9;Init complete, id=0, parent=0, distance=0
      With the IP not defined, I get no IP info, similar to the results with the 1.5 release:
      //#define MY_IP_ADDRESS 10,10,10,231   // If this is disabled, DHCP is used to retrieve address
      I'd be happy with either option working. Any ideas on what to try next?
      • SoloamS
        SoloamS
        Soloam
        Hello @houtomate ! I had the same problem! Lost a lot of days wondering and testing solutions! At this point I'm starting to believe my W5100 is defective! I ordered a new one to test it out! Waiting for it to arrive!
        • hautomateH
          hautomateH
          hautomate
          I was originally using a Vilros UNO and a "MEGA compatible" W5100 shield. I switched to a Vilros shield and got "avrdude: stk500_recv (): programmer is not responding" errors when trying to upload.
          I then tried a Sunfounder UNO + "MEGA compatible" shield and bingo, problem solved!
          DHCP is getting an address, but not the one I set in a static lease on my router, but that's okay. At least I can move forward!
          In my troubleshooting I ran across this post that describes a fix on the HanRun boards that involves jumping two 100 ohm resistors between RJ45 pins 1-2 and 3-6. I didn't have any 100 ohm resistors on hand so I didn't try it...
          https://forum.arduino.cc/index.php?topic=351477.msg2662072#msg2662072
          • SoloamS
            SoloamS
            Soloam
            Hello, I teste this solution out and it worked :) My W5100 is now working! Use as reference the post https://forum.arduino.cc/index.php?topic=351477.msg2662072#msg2662072
