  3. Multi-button relay switch without debounce
9 Posts 3 Posters 3.2k Views 3 Watching
  • CJ CassarinoC
    CJ CassarinoC
    CJ Cassarino
    I am trying to figure out how to have multiple relays (2 in my case) with a button to trip the relays but without the debounce. I want the relay to only be active while the switch is being pushed. Could anyone help me with this?
    • AndurilA
      AndurilA
      Anduril
      why do you want to do that without debounce? Afaik there is no downside on using the debounce lib to get a smoother switching behaviour.
      CJ CassarinoC 1 Reply Last reply
      • AndurilA Anduril
        CJ CassarinoC
        CJ CassarinoC
        CJ Cassarino
        @Anduril
        Because I am controlling an actuator with the ability for manual controls with a button. I want 1 button when held down to open it and another button when held down to close. With debounce I have to click it to open, click it again to turn of relay, then click the other button to retract, and then click to turn of relay.
          The bounce2 library supports detecting changes. See this example https://github.com/thomasfredericks/Bounce2/blob/master/examples/change/change.ino
            CJ CassarinoC
            CJ CassarinoC
            CJ Cassarino
            @mfalkvidd
            I get this error "'class Bounce' has no member named 'fell'"
              You'll probably need Bounce2 then.
                CJ CassarinoC
                CJ CassarinoC
                CJ Cassarino
                @mfalkvidd
                I have bounce2... Ill try redownloading it
                • AndurilA
                  AndurilA
                  Anduril
                  When downloading MySensors this library is included. For usage see MySensors example 'BinarySwitchSensor'.
                  • AndurilA Anduril
                    CJ CassarinoC
                    CJ CassarinoC
                    CJ Cassarino
                    @Anduril
                    Yea thats what I thought, and I see it. Ill check this out thanks
