  3. BME280 temp/humidity/pressure sensor
31 Posts 13 Posters 36.5k Views 17 Watching
  • Z Zbigniew Ko
    @yoshida Hello
    You can share your sketch.
    Please
    I can not make modifications.
    I still have a lot of errors.
    Y Offline
    Y Offline
    yoshida
    Zbigniew Ko:
    (2.1.1 mysensors compatible, but first you need to install the BME280_MOD-1022.h library in arduino IDE)
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #include <Wire.h>
    // BME280 libraries and variables
    // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
    // Written originally by Embedded Adventures
    // https://github.com/embeddedadventures/BME280
    #include <BME280_MOD-1022.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define HUM_CHILD 2
    const float ALTITUDE = 184; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
    // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,     // "Stable Weather Pattern"
      SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5     // "Unknown (More Time needed)
    float lastPressure = -1;
    float lastTemp = -1;
    float lastHum = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
    // get kPa/h by dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage tempMsg(TEMP_CHILD, V_TEMP);
    MyMessage humMsg(HUM_CHILD, V_HUM);
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
        if (firstRound) // first time initial 3 hour
          dP_dt = change * 2; // note this is for t = 0.5hour
        else
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
        if (firstRound) //first time initial 3 hour
          dP_dt = change; //note this is for t = 1 hour
        else
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
        else
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
        else
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
        else
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
        else
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
      int forecast = UNKNOWN;
      if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
      else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
        forecast = CLOUDY;
      else if ((dP_dt > 0.05) && (dP_dt < 0.25))
        forecast = SUNNY;
      else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
      else
        forecast = UNKNOWN;
      // uncomment when debugging
      //Serial.print(F("Forecast at minute "));
      //Serial.print(minuteCount);
      //Serial.print(F(" dP/dt = "));
      //Serial.print(dP_dt);
      //Serial.print(F("kPa/h --> "));
      //Serial.println(weather[forecast]);
      return forecast;
      metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
      Wire.begin(); // Wire.begin(sda, scl)
    void presentation()  {
      sendSketchInfo("BME280 Sensor", "1.6");
      // Register sensors to gw (they will be created as child devices)
      present(BARO_CHILD, S_BARO);
      present(TEMP_CHILD, S_TEMP);
      present(HUM_CHILD, S_HUM);
    // Loop
      // need to read the NVM compensation parameters
      BME280.readCompensationParams();
      /* After taking the measurement the chip goes back to sleep, use when battery powered.
      // Oversampling settings (os1x, os2x, os4x, os8x or os16x).
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient, higher numbers avoid sudden changes to be accounted for (such as slamming a door)
      BME280.writeOversamplingPressure(os16x);    // pressure x16
      BME280.writeOversamplingTemperature(os8x);  // temperature x8
      BME280.writeOversamplingHumidity(os8x);     // humidity x8
      BME280.writeMode(smForced);                 // Forced sample.  After taking the measurement the chip goes back to sleep
      // Normal mode for regular automatic samples
      BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
      BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
      BME280.writeMode(smNormal);
      while (1) {
        // Just to be sure, wait until sensor is done mesuring
        while (BME280.isMeasuring()) {
      // Read out the data - must do this before calling the getxxxxx routines
      BME280.readMeasurements();
      float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
      float humidity = BME280.getHumidityMostAccurate();
      float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
      float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
      int forecast = sample(pressure);
      if (!metric)
        // Convert to fahrenheit
        temperature = temperature * 9.0 / 5.0 + 32.0;
      Serial.println();
      Serial.print("Temperature = ");
      Serial.print(temperature);
      Serial.println(metric ? " °C" : " °F");
      Serial.print("Humidity = ");
      Serial.print(humidity);
      Serial.println(" %");
      Serial.print("Pressure = ");
      Serial.print(pressure);
      Serial.println(" hPa");
      Serial.print("Forecast = ");
      Serial.println();
      if (temperature != lastTemp)
        send(tempMsg.set(temperature, 1));
        lastTemp = temperature;
      if (humidity != lastHum)
        send(humMsg.set(humidity, 1));
        lastHum = humidity;
      if (pressure != lastPressure)
        send(pressureMsg.set(pressure, 2));
        lastPressure = pressure;
      if (forecast != lastForecast)
        send(forecastMsg.set(weather[forecast]));
        lastForecast = forecast;
      sleep(SLEEP_TIME);
    • Z Offline
      Z Offline
      Zbigniew Ko
      wrote on last edited by Zbigniew Ko
      #22
      @yoshida Thank you very much.
      As soon as I find time I will check it out.
      Yes checked, sketch works.
      Thanks yoshida.
      Please note that the library BME_MOD-1022.h consists of two parts: file-h, and file cpp.
        I am using the one from adafruit : what's the difference with this other library?
        alexsh1A 1 Reply Last reply
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @gohan I have been using both libraries with a chinese module I bought from Aliexpress. I did not notice any differences apart from size and maybe a module address, which you can change in either library.
          • B Offline
            B Offline
            bluezr1
            I used the last sketch posed by Yoshida and for some reason whenever the temp and humidity goes through a stretch where there isn't any change, it's as if the node goes into a deep sleep and doesn't come out of it until I hit the reset on a pro mini.
            I have it plunged in and not on batteries, so no need for any deep sleep. Is there anything I can change in the sketch? I'm still fairly new at this, although I'm having a blast.
            Thanks,
            Y 1 Reply Last reply
            • B bluezr1
              Thanks,
              Y Offline
              Y Offline
              yoshida
              @bluezr1 Interesting... :) I used it with a pro mini as well, and my problem was that it ate up the batteries in 2 weeks... :D So I would need more deep sleep for the same sketch :D
              But for that 2 weeks, it was working well. Temp/Hum/Baro updated every minute.
              • Y yoshida
                #27
                @yoshida did you do the modifications (remove led and regulator) recommended at https://www.mysensors.org/build/battery ?
                My storage room sensor (https://forum.mysensors.org/topic/7227/esp8266-wifi-gateway-with-rssi-for-rfm69-and-wifi ) uses the bme280. Not sure if that sketch is any help, but you are welcome to use it. It is much much simpler than the sketch posted above though.
                  Y Offline
                  Y Offline
                  yoshida
                  @mfalkvidd good question, yes I have removed the two leds I found, but I am too lame to remove the voltage regulator :( I have read here that the most consuming part is the LED(s)
                  • S Offline
                    scalpel
                    wrote on last edited by gohan
                    #29
                    @yoshida said in BME280 temp/humidity/pressure sensor:
                    >  * The MySensors Arduino library handles the wireless radio link and protocol
                    >  * between your home built sensors/actuators and HA controller of choice.
                    >  * The sensors forms a self healing radio network with optional repeaters. Each
                    >  * repeater and gateway builds a routing tables in EEPROM which keeps track of the
                    >  * network topology allowing messages to be routed to nodes.
                    >  * Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
                    >  * Copyright (C) 2013-2015 Sensnology AB
                    >  * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
                    >  * Documentation: http://www.mysensors.org
                    >  * Support Forum: http://forum.mysensors.org
                    >  * This program is free software; you can redistribute it and/or
                    >  * modify it under the terms of the GNU General Public License
                    >  * version 2 as published by the Free Software Foundation.
                    >  * REVISION HISTORY
                    >  * DESCRIPTION
                    > // Enable debug prints to serial monitor
                    > #define MY_DEBUG
                    > // Enable and select radio type attached
                    > #define MY_RADIO_NRF24
                    > //#define MY_RADIO_RFM69
                    > #include <SPI.h>
                    > #include <MySensors.h>
                    > #include <Wire.h>
                    > #define HUM_CHILD 2
                    > enum FORECAST
                    > float lastHum = -1;
                    > float pressureAvg;
                    > float pressureAvg2;
                    > float dP_dt;
                    > boolean metric;
                    >   minuteCount++;
                    >     minuteCount = 6;
                    >     else
                    >     else
                    >     else
                    >     else
                    >     else
                    >     else
                    >     forecast = UNKNOWN;
                    >     forecast = CLOUDY;
                    >     forecast = SUNNY;
                    >     forecast = STABLE;
                    >   else
                    >     forecast = UNKNOWN;
                    >   return forecast;
                    > void setup() {
                    >   // Send the sketch version information to the gateway and Controller
                    > // Loop
                    > void loop() {
                    >   while (1) {
                    >   if (!metric)
                    >   Serial.println();
                    >   Serial.println();
                    >     lastHum = humidity;
                    >   sleep(SLEEP_TIME);
                    Added to sketch @yoshida battery state send, but its not sending it, please chek it:
                    #include <Wire.h>
                    #define HUM_CHILD 2
                    int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                    int oldBatteryPcnt = 0;
                    const float ALTITUDE = 450; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                    const unsigned long SLEEP_TIME = 300000;
                    enum FORECAST
                    float lastHum = -1;
                    float pressureAvg;
                    float pressureAvg2;
                    float dP_dt;
                    boolean metric;
                      minuteCount++;
                        minuteCount = 6;
                        else
                        else
                        else
                        else
                        else
                        else
                        forecast = UNKNOWN;
                        forecast = CLOUDY;
                        forecast = SUNNY;
                        forecast = STABLE;
                      else
                        forecast = UNKNOWN;
                      return forecast;
                      analogReference(INTERNAL1V1);
                      #else
                      analogReference(INTERNAL);
                    // Loop
                      while (1) {
                      if (!metric)
                      Serial.println();
                      Serial.println();
                        lastHum = humidity;
                        // Power up radio after sleep
                        oldBatteryPcnt = batteryPcnt;
                      sleep(SLEEP_TIME);
                    S 1 Reply Last reply
                    • S scalpel
                      >  * REVISION HISTORY
                      >  * DESCRIPTION
                      > #define MY_DEBUG
                      > #include <SPI.h>
                      > #include <Wire.h>
                      > #define HUM_CHILD 2
                      > enum FORECAST
                      > float lastHum = -1;
                      > float pressureAvg;
                      > float pressureAvg2;
                      > float dP_dt;
                      > boolean metric;
                      >   minuteCount++;
                      >     minuteCount = 6;
                      >     else
                      >     else
                      >     else
                      >     else
                      >     else
                      >     else
                      >     forecast = UNKNOWN;
                      >     forecast = CLOUDY;
                      >     forecast = SUNNY;
                      >     forecast = STABLE;
                      >   else
                      >     forecast = UNKNOWN;
                      >   return forecast;
                      > void setup() {
                      > // Loop
                      > void loop() {
                      >   while (1) {
                      >   if (!metric)
                      >   Serial.println();
                      >   Serial.println();
                      >     lastHum = humidity;
                      >   sleep(SLEEP_TIME);
                      #include <Wire.h>
                      #define HUM_CHILD 2
                      enum FORECAST
                      float lastHum = -1;
                      float pressureAvg;
                      float pressureAvg2;
                      float dP_dt;
                      boolean metric;
                        minuteCount++;
                          minuteCount = 6;
                          else
                          else
                          else
                          else
                          else
                          else
                          forecast = UNKNOWN;
                          forecast = CLOUDY;
                          forecast = SUNNY;
                          forecast = STABLE;
                        else
                          forecast = UNKNOWN;
                        return forecast;
                        #else
                      // Loop
                        while (1) {
                        if (!metric)
                        Serial.println();
                        Serial.println();
                          lastHum = humidity;
                        sleep(SLEEP_TIME);
                      @scalpel - works great! Thank you!!
                      Downloaded the library from the link in your sketch and up and running i no time.
                      Here is my sketch, with some modifications:
                      • Lightsensor A0
                      • No sleep (might want to enable repeater function later)
                      • Sends every 5 minute regardless of prevoius value (I use Domoticz and want to avoid red nodes and combined nodes).
                      • Fixed node it
                      //#define MY_DEBUG
                      //Fixed ID/Parent?
                      #define MY_NODE_ID 20                     //To set a fixed ID for your node
                      //#define MY_PARENT_NODE_ID 100             //To set a fixed parent for this node
                      #include <Wire.h>
                      #define HUM_CHILD 2
                      long interval = 300000;           // interval at which to send (milliseconds)
                      long previousMillis = interval;        // will store last time data was sent
                      const float ALTITUDE = 135; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
                      enum FORECAST
                      float pressureAvg;
                      float pressureAvg2;
                      float dP_dt;
                      boolean metric;
                      //Light
                      #define CHILD_ID_LIGHT 3
                      #define LIGHT_SENSOR_ANALOG_PIN A0
                      MyMessage light_Msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                        minuteCount++;
                          minuteCount = 6;
                          else
                          else
                          else
                          else
                          else
                          else
                          forecast = UNKNOWN;
                          forecast = CLOUDY;
                          forecast = SUNNY;
                          forecast = STABLE;
                        else
                          forecast = UNKNOWN;
                        return forecast;
                        #else
                        sendSketchInfo("WeatherStation #20", "1.0");
                      // Loop
                      if(currentMillis - previousMillis > interval) {
                          // save the last time sent the data
                          previousMillis = currentMillis;
                        analogReference(DEFAULT);
                        wait(500);
                         readLightLevel();   //Read Light
                        wait(500);
                        if (!metric)
                        Serial.println();
                        Serial.println();
                      wait(50);
                      wait(50);
                      wait(50);
                      wait(50);
                      void readLightLevel()      {
                        Serial.println(analogRead(A0));
                        int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23; //To get a value ranging from 0 (dark) to 100 (bright).
                      #ifdef MY_DEBUG
                        Serial.print("Light: "); Serial.println(lightLevel);
                        send(light_Msg.set(lightLevel));
                      • R Offline
                        R Offline
                        RickyTerzis
                        wrote on last edited by RickyTerzis
                        #31
                        Hi...i am a new user here. I built a RFM69 gateway and a node.I decided to place the RFM69 node in a basement storage room. The room has been flooded a few times historically, so being able to monitor humidity in the room seems like a good idea.The room has thick brick walls, which the RFM69-433MHz radio is much more capable to handle than the nrf24. Still, I wanted to keep an eye on the signal strength. Because of this, I added code to the gateway to report RSSI from the node.
                        circuit card assembly
                        12.2k
