  3. BME280 temp/humidity/pressure sensor
31 Posts 13 Posters 37.1k Views 17 Watching
  • signal15S
    signal15S
    signal15
    Has anyone built a node that uses the BME280 temp/humidity/pressure sensor?
    I'm guessing if I build it from scratch, the HumiditySensor example would probably be the best one to use. One thing I saw was that someone is working on an ESP8266 weather station gateway with this sensor, and in his comments, it appears that you have to do some funky stuff with moving the CE pin somewhere else or it interferes with the I2C communication for this chip. I would be doing this on a Nano, not an ESP. Are the pin changes the same?
    alexsh1A 1 Reply Last reply
    • E
      E
      emc2
      On the ESP8266 SDA and SCL native pins are used in the radio wiring, that's why you need the funky stuff.
      No pin changes necessary on nano or promini as A4 and A5 are not used. You plug it as any other I2C sensor (just be sure to feed it with 3.3V, not 5V)
      • signal15S
        signal15S
        signal15
        Awesome. I just got it working with a test sketch like 2 minutes ago. If I get a working sketch for MySensors, how can I get it uploaded to the site as an example?
        Also, if anyone has done it before, I'd appreciate any code you might have to save some time. I only get like 5 minutes here an there to work on this.
        Y 1 Reply Last reply
        • E
          E
          emc2
          This should work, it removes the 2-3 ESP8266 config lines:
           * Version 1.0 - Henrik Ekblad
           * Pressure sensor example using BMP085 module
           * http://www.mysensors.org/build/pressure
          #include <Wire.h>
          // BME280 libraries and variables
          // Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code
          // Written originally by Embedded Adventures
          // https://github.com/embeddedadventures/BME280
          #include <BME280_MOD-1022.h>
          #define BARO_CHILD 0
          #define TEMP_CHILD 1
          #define HUM_CHILD 2
          const float ALTITUDE = 23; // <-- adapt this value to your location's altitude (in m). Use your smartphone GPS to get an accurate value!
          // Sleep time between reads (in ms). Do not change this value as the forecast algorithm needs a sample every minute.
          const unsigned long SLEEP_TIME = 60000;
          const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
          enum FORECAST
            STABLE = 0,     // "Stable Weather Pattern"
            SUNNY = 1,      // "Slowly rising Good Weather", "Clear/Sunny "
            CLOUDY = 2,     // "Slowly falling L-Pressure ", "Cloudy/Rain "
            UNSTABLE = 3,   // "Quickly rising H-Press",     "Not Stable"
            THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
            UNKNOWN = 5     // "Unknown (More Time needed)
          float lastPressure = -1;
          float lastTemp = -1;
          float lastHum = -1;
          int lastForecast = -1;
          const int LAST_SAMPLES_COUNT = 5;
          float lastPressureSamples[LAST_SAMPLES_COUNT];
          // this CONVERSION_FACTOR is used to convert from Pa to kPa in the forecast algorithm
          // get kPa/h by dividing hPa by 10
          #define CONVERSION_FACTOR (1.0/10.0)
          int minuteCount = 0;
          bool firstRound = true;
          // average value is used in forecast algorithm.
          float pressureAvg;
          // average after 2 hours is used as reference value for the next iteration.
          float pressureAvg2;
          float dP_dt;
          boolean metric;
          MyMessage tempMsg(TEMP_CHILD, V_TEMP);
          MyMessage humMsg(HUM_CHILD, V_HUM);
          MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
          MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
          float getLastPressureSamplesAverage()
            float lastPressureSamplesAverage = 0;
            for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
              lastPressureSamplesAverage += lastPressureSamples[i];
            lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
            return lastPressureSamplesAverage;
          // Algorithm found here
          // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
          // Pressure in hPa -->  forecast done by calculating kPa/h
          int sample(float pressure)
            // Calculate the average of the last n minutes.
            int index = minuteCount % LAST_SAMPLES_COUNT;
            lastPressureSamples[index] = pressure;
            minuteCount++;
            if (minuteCount > 185)
              minuteCount = 6;
            if (minuteCount == 5)
              pressureAvg = getLastPressureSamplesAverage();
            else if (minuteCount == 35)
              float lastPressureAvg = getLastPressureSamplesAverage();
              float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
              if (firstRound) // first time initial 3 hour
                dP_dt = change * 2; // note this is for t = 0.5hour
              else
                dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
            else if (minuteCount == 65)
              if (firstRound) //first time initial 3 hour
                dP_dt = change; //note this is for t = 1 hour
              else
                dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
            else if (minuteCount == 95)
                dP_dt = change / 1.5; // note this is for t = 1.5 hour
              else
                dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
            else if (minuteCount == 125)
              pressureAvg2 = lastPressureAvg; // store for later use.
                dP_dt = change / 2; // note this is for t = 2 hour
              else
                dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
            else if (minuteCount == 155)
                dP_dt = change / 2.5; // note this is for t = 2.5 hour
              else
                dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
            else if (minuteCount == 185)
                dP_dt = change / 3; // note this is for t = 3 hour
              else
                dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
              pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
              firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
            int forecast = UNKNOWN;
            if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
              forecast = UNKNOWN;
            else if (dP_dt < (-0.25))
              forecast = THUNDERSTORM;
            else if (dP_dt > 0.25)
              forecast = UNSTABLE;
            else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
              forecast = CLOUDY;
            else if ((dP_dt > 0.05) && (dP_dt < 0.25))
              forecast = SUNNY;
            else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
              forecast = STABLE;
            else
              forecast = UNKNOWN;
            // uncomment when debugging
            //Serial.print(F("Forecast at minute "));
            //Serial.print(minuteCount);
            //Serial.print(F(" dP/dt = "));
            //Serial.print(dP_dt);
            //Serial.print(F("kPa/h --> "));
            //Serial.println(weather[forecast]);
            return forecast;
            metric = getConfig().isMetric;
            Wire.begin(); // Wire.begin(sda, scl)
          void presentation()  {
            sendSketchInfo("BME280 Sensor", "1.6");
            // Register sensors to gw (they will be created as child devices)
            present(BARO_CHILD, S_BARO);
            present(TEMP_CHILD, S_TEMP);
            present(HUM_CHILD, S_HUM);
          // Loop
            // need to read the NVM compensation parameters
            BME280.readCompensationParams();
            /* After taking the measurement the chip goes back to sleep, use when battery powered.
            // Oversampling settings (os1x, os2x, os4x, os8x or os16x).
            BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient, higher numbers avoid sudden changes to be accounted for (such as slamming a door)
            BME280.writeOversamplingPressure(os16x);    // pressure x16
            BME280.writeOversamplingTemperature(os8x);  // temperature x8
            BME280.writeOversamplingHumidity(os8x);     // humidity x8
            BME280.writeMode(smForced);                 // Forced sample.  After taking the measurement the chip goes back to sleep
            // Normal mode for regular automatic samples
            BME280.writeStandbyTime(tsb_0p5ms);         // tsb = 0.5ms
            BME280.writeFilterCoefficient(fc_16);       // IIR Filter coefficient 16
            BME280.writeMode(smNormal);
            while (1) {
              // Just to be sure, wait until sensor is done mesuring
              while (BME280.isMeasuring()) {
            // Read out the data - must do this before calling the getxxxxx routines
            BME280.readMeasurements();
            float temperature = BME280.getTemperatureMostAccurate();                    // must get temp first
            float humidity = BME280.getHumidityMostAccurate();
            float pressure_local = BME280.getPressureMostAccurate();                    // Get pressure at current location
            float pressure = pressure_local/pow((1.0 - ( ALTITUDE / 44330.0 )), 5.255); // Adjust to sea level pressure using user altitude
            int forecast = sample(pressure);
            if (!metric)
              // Convert to fahrenheit
              temperature = temperature * 9.0 / 5.0 + 32.0;
            Serial.println();
            Serial.print("Temperature = ");
            Serial.print(temperature);
            Serial.println(metric ? " °C" : " °F");
            Serial.print("Humidity = ");
            Serial.print(humidity);
            Serial.println(" %");
            Serial.print("Pressure = ");
            Serial.print(pressure);
            Serial.println(" hPa");
            Serial.print("Forecast = ");
            Serial.println();
            if (temperature != lastTemp)
              send(tempMsg.set(temperature, 1));
              lastTemp = temperature;
            if (humidity != lastHum)
              send(humMsg.set(humidity, 1));
              lastHum = humidity;
            if (pressure != lastPressure)
              send(pressureMsg.set(pressure, 2));
              lastPressure = pressure;
            if (forecast != lastForecast)
              send(forecastMsg.set(weather[forecast]));
              lastForecast = forecast;
            sleep(SLEEP_TIME);
          signal15S 1 Reply Last reply
          • signal15S signal15
            alexsh1A
            alexsh1A
            alexsh1
            @signal15
            I have this sensor working on Arduino Mini Pro. I am sure you can make it work under ESP8266
            • E emc2
              #include <Wire.h>
              #define HUM_CHILD 2
              enum FORECAST
              float lastHum = -1;
              float pressureAvg;
              float pressureAvg2;
              float dP_dt;
              boolean metric;
                minuteCount++;
                  minuteCount = 6;
                  else
                  else
                  else
                  else
                  else
                  else
                  forecast = UNKNOWN;
                  forecast = CLOUDY;
                  forecast = SUNNY;
                  forecast = STABLE;
                else
                  forecast = UNKNOWN;
                return forecast;
              // Loop
                while (1) {
                if (!metric)
                Serial.println();
                Serial.println();
                  lastHum = humidity;
                sleep(SLEEP_TIME);
              signal15S
              signal15S
              signal15
              @emc2
              I'm getting some problems compiling the code you provided above. Is this for 1.6 or something? I'm on 1.5, do I need to change some function names?
              Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void setup()':
              Mysensors_BME280:252: error: 'getConfig' was not declared in this scope
              /Users/jay.austad/Documents/Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void presentation()':
              Mysensors_BME280:258: error: 'sendSketchInfo' was not declared in this scope
              Mysensors_BME280:261: error: 'present' was not declared in this scope
              /Users/jay.austad/Documents/Arduino/Mysensors_BME280/Mysensors_BME280.ino: In function 'void loop()':
              Mysensors_BME280:328: error: 'send' was not declared in this scope
              Mysensors_BME280:335: error: 'send' was not declared in this scope
              Mysensors_BME280:341: error: 'send' was not declared in this scope
              Mysensors_BME280:347: error: 'send' was not declared in this scope
              Mysensors_BME280:351: error: 'sleep' was not declared in this scope
                 sleep(SLEEP_TIME);
              exit status 1
              'getConfig' was not declared in this scope```
              • signal15S
                signal15S
                signal15
                wrote on last edited by signal15
                Ah, looks like I just need to add "gw." in front of all of these functions and "MySensor gw;" just after the includes.
                • E
                  E
                  emc2
                  Ah yes sorry, it's for the dev branch (1.6 or now called 2.0)
                  • E emc2
                    signal15S
                    signal15S
                    signal15
                    @emc2
                    Eh, looks like there's a lot more that I have to do to get this working, like moving the presentation into the setup() function.
                    • E
                      E
                      emc2
                      If you are using 1.5 probably a lot more.
                      Easier to install 2.0, compile and upload. It will be compatible with your 1.5 gateway anyway.
                      • E emc2
                        signal15S
                        signal15S
                        signal15
                        @emc2
                        Oh, I thought that you had to upgrade the gateway as well. If that's the case, then I'll grab 2.0. Do I just go to the dev branch in github and hit download ZIP?
                        • signal15S
                          signal15S
                          signal15
                          Do you have to upgrade the files on the controller to 2.0b as well? I have a vera, and when I added this new sensor on 2.0b, all of my nodes stopped updating and the tiles for them on the Devices screen doesn't list anything about the sensor like it normally does.
                          I get these errors in the Vera logs:
                          02	05/06/16 18:54:40.167	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduino1 <0x2ac17000>
                          02	05/06/16 18:54:40.170	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>
                          02	05/06/16 18:54:40.171	Device_Service::MatchupUpnpServices no upnp service for urn:upnp-arduino-cc:serviceId:arduinonode1 <0x2ac17000>```
                          Also, the MySensors parent device disappeared from my Devices page in Vera. If I telnet to my gateway on port 5003, I only see the new sensor reporting as well, not any of my other sensors. Did the 2.0b sensor do something bad to my gateway or the Vera plugin?
                          Update: I deleted the new devices created from the 2.0b sensor in my Vera. This fixed it so the other node information showed up again, and the MySensors parent device showed up. But, my 1.5 sensors were no longer updating. I restarted them, and they started updating.
                          If 2.0 sensors are designed to be backwards compatible with a 1.5 gateway and 1.5 controller code, then there's a problem somewhere. Maybe it's with the Vera code. But, like I said, I telneted to port 5003 on my gateway, and the only thing that the gateway was receiving was the data from my 2.0b sensor. Either the gateway was ignoring the 1.5 sensors, or the 1.5 sensors stopped sending for some reason.
                          Thoughts?
                            Hmm.. I wonder if this change might have interfered with the Vera plugin.
                            https://github.com/mysensors/Arduino/commit/bbc6a221f4c153f41993207e521f5531ba853d1a
                            https://github.com/mysensors/Arduino/pull/420
                              signal15S
                              signal15S
                              signal15
                              @hek
                              Let me know if you make a change and need me to test.
                                Y
                                Y
                                yoshida
                                @emc2 or anybody:
                                Does anyone have a working BME280 mysensors arduino sketch? The code above states include mysensor.h now it is mysensorS.h, so I have renamed, but it won't compile, it says:
                                bme280:252: error: 'getConfig' was not declared in this scope
                                I have a MySensors Gateway USB
                                Version: 2.1.1 (arduino nano) with Domoticz, and I would like to use the bme280 for a battery powered outdoor temp/humidity/barometer (as DHT22 does not like battery level below 3.3V, and I would run on 2x1.5V AA)
                                • E
                                  E
                                  emc2
                                  Was modified in 2.1.1, you need to change
                                  to
                                  metric = getControllerConfig().isMetric;  // was getConfig().isMetric; before MySensors v2.1.1
                                  • A
                                    A
                                    anno
                                    wrote on last edited by anno
                                    Still a lot of errors in this sketch, did take some out but this is still in it:
                                    In file included from C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino:48:0:
                                    C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
                                    #ifndef __BME280_MOD-1022_H
                                    C:\Users\x\Documents\Arduino\libraries\BME280/BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
                                    #define __BME280_MOD-1022_H
                                    In file included from C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:40:0:
                                    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:41:21: warning: extra tokens at end of #ifndef directive
                                    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.h:42:21: warning: ISO C99 requires whitespace after the macro name
                                    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp: In member function 'BME280Class::readCompensationParams()':
                                    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:276:45: warning: iteration 20 invokes undefined behavior [-Waggressive-loop-optimizations]
                                    compParams.compArray[count] = Wire.read();
                                    C:\Users\x\Documents\Arduino\libraries\BME280\BME280_MOD-1022.cpp:275:3: note: containing loop
                                    for (count = 0; count < 28; count++) { // first 28 bytes we can process like this
                                    C:\Users\x\Documents\Arduino\BME280_sensor\BME280_sensor.ino: In function 'loop':
                                    • E emc2
                                      to
                                      Y
                                      Y
                                      yoshida
                                      @emc2 Thanks! With this modification the sketch compiled successfully. Today I had time, so put everything together, and the BME280 works with the 2.4GH radio, temp/hum/pressure all reporting like they should.
                                      Using arduino pro mini, bme280, nrf24, 2XAA Batteries. It reports to the mysensors serial gw, and then shown in domoticz.
                                      Z 1 Reply Last reply
                                      • Y yoshida
                                        Z
                                        Z
                                        Zbigniew Ko
                                        @yoshida Hello
                                        You can share your sketch.
                                        Please
                                        I can not make modifications.
                                        I still have a lot of errors.
                                        • A
                                          A
                                          anno
                                          This post is deleted!
